Dyson Iron/Clear Turbine Head Assy #DY-906565-29
I need the gear and belt inside the turbine head
VacuumRepair
  • 438 Answers
SOURCE: hoover steam vac all terrain turbine gear assembly
I'd be happy to walk you through this repair. Unfortunately this is a very common problem with the Hoover SteamVacs.
Here's what you'll need to complete this repair:
- Hoover Turbine Assembly For Model F5866-900 Part # 43191001 or 90001354
- Phillips Head Screwdriver
- Flat Head Screwdriver
Step 1. Remove both the clean solution, and the dirty solution tanks from the machine, and press the handle release pedal so that the handle is laying down flat:
Step 2. With a flat head screwdriver, pry off the rotating brush speed indicator knob:
Step 3. Unscrew the silver screw that's at the very top of the see thru suction port where the dirty solution tank rests.
Step 4. Turn the SteamVac upside down so that the brushes are facing upwards. There are four clips that hold these brushes in place. You'll need to remove the brushes from the machine by squeezing the four tabs while pulling upwards at the same time. The picture actually only shows the two tabs on the right hand side being squeezed, but the tabs on the left hand side are in the exact same location:
Step 5. Once you've removed the brush block from the machine, there are 4 screws on the bottom that need to be removed. Keep the two silver screws on the very corner in place, you won't need to remove these. Remove the four screws that I've highlighted in red:
Step 6. Turn the machine back over right side up, so that the brushes are on the bottom. There are two clips that hold the top housing in place. Insert your flat head screwdriver in between the top and lower housing in the rear of the machine close to the rear wheels, and pry upwards to unclip these clips on both the left and right sides, then remove the top motor housing from the machine.
Step 7. You'll now have complete access to the turbine. Remove the two silver screws in the front of the unit that hold the turbine in place, as well as remove the front hose from the turbine:
Step 8. Once you have removed the two screws you'll be able to lift the turbine up. There's a second hose in the rear of the turbine that you'll also need to remove before you can remove the turbine completely. After you've removed the hose, take the turbine out of the machine. You'll notice to the immediate left of the turbine other hoses that connect to a black circular part. This is actually the pump that sprays the water on the floor. If you ever have the problem where the clean water solution will not spray, it's a good possibility that this part needs to be replaced.
Simply install the new turbine, reattached the hoses and two front screws. When you're putting the top motor housing back on the unit, make sure that the brush speed selector knob that's on the right side of the turbine fits through the **** in the top motor housing. Also before tighting the two screws that that hold the top housing in in front of the brushes, there's two clips. You'll need to snap the top motor housing behind these two clips. Simply push front of the motor housing until you hear it snap into place.
That's about it. If you have any trouble with this repair, please don't hesitate to use the Clarification request form here on Fixya. I'm always more then happy to answer any follow up questions that you might have. If this repair was helpful to you, please help other Fixya members with this same problem find my repair by rating it helpful. You can do this by clicking the 4 Thumbs up icons in the right hand corner.
Thank you very much,
Chris J.
GoVacuum
Posted on Apr 10, 2010
Testimonial: "Excellent description! Thanks for the great solution and pictures to help!!!!"
SOURCE: Dyson DC17 Animal does not have enough suction
Also make sure your canister was put back on securely.
Posted on Apr 20, 2010
SOURCE: turbine head of my Dyson DC08 does not spin
This response is likely too late coming, however for others the problen appears to be the same as the fault with my turbine head which was that the turbine fan had become loose on its spindle. With no pressure on the brushes, friction would allow the fan to turn and drive the brushes via the belt. The faulty part is not available separately however I have repaired mine using araldite glue. Other things to check is for a worn belt. Cheers.
Posted on Apr 28, 2010
  • 53 Answers
SOURCE: my dyson dc17 amimal's main turbine head is not
Right next to the power switch is a switch that will turn on/off the beater brush. Push firmly on this button and see if that turns it back on. It will turn itself off if it has too much resistance on it from getting tangled in something like a long carpet fiber that wraps itself around the beater brush. Check and make sure it's not bound up by something and then press the on/off button for the beater brush.
Posted on May 31, 2010
  • 20 Answers
SOURCE: My washer sounds like a turbine engine during spin
It is the bearing in the outter basket. Some of the units had 5 years on the outter baket. I am a service tech & fixed several of these.
Posted on Sep 29, 2010
Turbo head has stopped spinning
Hi Fay, it's Jack at Dyson.
If your DC39 Multi Floor's turbine head has stopped spinning, this could mean there's a blockage in the turbine head, wand, hose or lower duct hose. This could reduce the airflow passing through the machine, which in turn will affect the turbine which powers the rotating brush bar.
It's also a good idea to check the Turbine head is free of any threads, hair or other obstructions:
If you need further help once you've given this a go, you can reach our experts at the Dyson Customer Helpline by calling 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
Mar 05, 2016 | Dyson DC39 Multi floor canister vacuum...
Dyson DC54 brush bar not rotating. Have removed all the hair, cleaned the brush and replaced, still not spinning.
Brushbar not turning Clutch check - Dyson
www.dyson.com/...dyson...not.../brushbar-not-turning-clutch-chec...
DysonBrushbar not turning - Clutch check. Please ensure that your hands are clear of the soleplate and brushbar before completing this test. Clutch check.
Resetting the brush bar (Official Dyson video) - YouTube
? 3:52
https://www.youtube.com/watch?v=AiKnefEr7ns
Jan 16, 2014 - Uploaded by AskDyson
How to clear and reset the brush bar of your Dyson DC41 Mk2, DC55, ... Dyson DC41 Mk2, DC55, DC65, DC66 - Resetting thebrush bar (Official Dyson video) .... Dyson Cinetic DC52, DC54with the Musclehead™ floor tool ...
Dyson DC44 - Remove & clean the Brush Bar - An owners ...
? 4:13
https://www.youtube.com/watch?v=_0a71p84sp8
Nov 12, 2012 - Uploaded by Tom Strong Reviews
Here is the fantastic Dyson Digital Slim Mk2 DC44 Animal. (DC45 in ... Europe) Here I show how to remove and clean the Brush Barof any tr... ... It is and easy operation and one you need to do whenever the brush is not clear.
Dyson DC54 Support - Turbine head not working properly
https://www.dyson.com.au/.../dc54/dc54...not.../turbine-head-not-workin...
Dyson DC54 Support - Turbine head not working properly. ... If you cannot clear an obstruction you may need to remove the brush bar. Use a coin to unlock the ...
Jan 24, 2016 | Dyson Vacuums
The turbine head of my DC39 stopped working. The suction is super, took the brush out and disconnected the hose and looked into it, no blockage is visible looking. ideas?
hi russ, it's jack at dyson.
i'm sorry to hear you're having difficulty with your dc39's triggerhead floor tool. i appreciate you've already checked for a blockage, but you may want to follow the steps shown in our online support guide just to make sure there's nothing you've missed: http://www.dyson.co.uk/support/dc39/dc39-animal/machine-is-not-working/dc39-check-extension-tube
if you find there's no improvement after running through these checks we're happy to help further - and if a replacement is needed, we can confirm if this is covered under your dyson warranty. you can reach our experts directly by calling on 0800 298 0298 (uk), 1-866-693-9766 (us), 1-877-397-6622 (ca) or 1800 239 766 (au).
Jan 20, 2015 | Dyson DC39 Animal Canister Vacuum
How do I get a new belt to repace a broken one in a DC23 turbine head
Hi there, it's Jack at Dyson.
The Turbine head's belt is not a part we would ask a customer to fit, and therefore it's not available as an individual component. It's part of the turbine drive mechanism, and we'd advise against attempting to dismantle this as it could result in damage to the Turbine head. If the Turbine head happened to fail within the Dyson warranty period we should normally be able to replace it, as long as it's been used and maintained according to the User guide. Out of warranty, a replacement Turbine head could be chargeable.
If you'd like some additional help or advice from our experts you're welcome to contact us directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Oct 07, 2014 | Dyson DC23 Turbinehead Canister Vacuum...
Dyson DC23 canister vacuum turbine head attachment stops spinning.
bearing inside the turbine has failed. cant be repaired you will need to buy a new one your local vac centre will have one
May 17, 2017 | Dyson DC23ACTUSC Bagless Canister Cyclonic...
Why does it not fit?
Hi Clint, it's Jack at Dyson.
DC24 is not compatible with the original Mini turbine head as this tool is engineered to work with the performance characteristics of our full size upright and canister vacuums.
However, we do make a Mini turbine head which is compatible with DC24 - for help ordering this, I would encourage you to contact us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA). Once we've taken the serial number of your machine we'll be able to confirm the correct Mini turbine head for your vacuum.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Nov 08, 2013 | Dyson Mini Turbine Head Universal Fit,...
Dyson turbine head
Hi Kevin, Alec from VacuumSpot here. Unfortunately Dyson don't actually sell individual mechanical components to their turbine heads, so even though it is probably a pretty easy repair you can't get the parts. In this case you will have to buy a complete new head.
May 25, 2013 | Dyson Stowaway DC23 Bagless Canister...
Dyson mini turbine head
I can't tell from the information provided what sort of issue you're having with your mini turbine head, but you may find our support guide of use in resolving any difficulties:
http://support.dyson.co.uk/support/dc11/dc11-all-floors/maintaining-your-dyson-machine/how-to-remove-a-blockage/from-the-mini-turbine-head/mini-turbine-head-not-working-
Alternatively, one of our advisors will be happy to provide assistance if you call our free Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
http://www.dyson.com
Feb 08, 2012 | Dyson DC11 All Floors Bagless Canister...
Turbine head of my Dyson DC08 does not spin
Jan 24, 2010 | Dyson DC08 Cylinder Bagless Canister...
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
