Question about Gateway NE56R10u Laptop
Using laptop and it just powers off - Gateway NE56R10u Laptop
    New Friend:
    Problem Solver:
  • 12 Answers
UPDATE YOUR ANTIVIRUS,,, OR BUY A ANTIVIRUS.....SETUP YOUR WINDOWS ,,, CHECK YOUR PC CONNECTION CABLE,,, your laptop may be shutdown by overheating ,,,, try to use a cooler.
Posted on Apr 18, 2014
No power no power light. Its as if there is no power. Ive checked cord and there is power to it
Try using that ac adapter on a different computer if possible to check if it charges. Or try using a different ac adapter. If your laptop works using a different ac adapter, your ac adapter is busted. If it does the same thing using a different ac adapter it is a problem with your laptop and needs a repair.
Apr 22, 2011 | Acer Computers & Internet
Power is going to laptop but it will not turn on. Was just using it w/out power cord. Plugged power cord in and it won't turn on. Tried, Alt, ctl, delete but nothing...:(
Try switching the outlets that you're using the power your laptop. You may have a faulty outlet which could be why it isn't giving off any power to the power cord. Next, try unplugging your power cord, then taking out the battery, plugging back in the power cord and turning your laptop back on. If the laptop turns on, the problem may be with your laptop's battery. If the laptop still doesn't turn back on, put the battery back into your laptop, and see if it works. If it still doesn't work, try taking it to a place like Geek Squad in Best Buy.
Hope this helps!
-Anonymity
Feb 25, 2011 | Toshiba Satellite C655S5085 Notebook
Battery fail
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
Sep 23, 2010 | IBM ThinkPad T30 2366 Notebook
Power light illuminated but no screen. how do you reset computer
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The power button could be bad.
Sep 18, 2010 | Acer Aspire 4730-4947 Notebook
Computer wont power on although both lights come on and battery is charged
Sep 17, 2010 | Gateway MT3418 Notebook
Hp laptop won't turn on and the power pack makes a clicking noise ,can it be repaired ?
there could be a short circuit in the powe pack.
Just call HP and have the power brick replaced. try using another power pack to isolate the issue, if your laptop works using another power pack, then its your power pack that causes the issue
Sep 07, 2010 | Compaq Computers & Internet
I plugged in a laptop using a universal laptop and it fried it
Connecting a power adapter with the wrong voltage or current can be deadly for most electronics, and especially "sensitive" ones, such as laptops... If I were you, I wouldn't take the risk - and change the whole system board!
Good luck,
Pelu.
Jun 03, 2010 | HP Pavilion dv9700t Notebook PC
HP Pavilion XT983 using a Bestec Power Supply ATX 19956D Computer will not start,no fan and the LED light is on but very dull. Does this mean that the power supply is bad or could it be the Mother Board. I...
hi this could be that the power supply may not be powerful enough to run the laptop, as some laptops run 12v power, where as some use 9v power if you know someone with a power supply try using theirs, if your laptop is 9v and you are using a 9v then this could be a short on the system board, so the only thing i can suggest is try another power supply first before condemning your laptop...hope this helps please vote thanks
Mar 03, 2010 | HP Computers & Internet
Laptop won't power up
You need to replace the RAM ..
May 20, 2009 | Fujitsu LifeBook S6231 Notebook
Laptop Power Up Problem
Try booting under AC power with the battery removed.
Jun 05, 2008 | Gateway 400SD4 Notebook
Gateway NE56R10u Laptop Logo
26 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
