Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
Amana side by side won't make ice door water works
    Problem Solver:
  • 8 Answers
Sometimes as simple as frozen line, check little rubber line at ice maker feed. if ok you may need new controller or ic maker ez to replace either, goto repairclinic.com for info. i would buy new icemaker locally at homedepot round 27 bcks if you need 1
Posted on Jun 19, 2009
Replaced evaporator fan motor still not working
Get help from top Amana Refrigerator experts on repairs, upgrades & installations. ...open the freezer door,do you hear the fan blowing,if not hold in the door switch ... Theevaporator coils frost up in normal use and every eight hours or so the entire ...Side-By-Side Refrigerator with FrontFill Ice and Water Related Problems.
Sep 12, 2013 | Amana 22.6 cu. ft. Side-By-Side...
I have an Amanda double Door refrigerator with an ice & water dispenser. The ice machine unit's dose not dispense ice cubes,
If the unit is making ice and the water will work from the door but the does not dispense, you will need to replace the "auger motor". Here is the part to order.
Nov 28, 2012 | Amana 22 cu.ft. Side-By-Side Cabinet Depth...
I have an Amana side by side refrigerator. The ice dispenser works but when the ice slides down the chute the little door won't open allowing it to come out.
I believe your Amana DRS2663B Click Here=> 67006000 SOLENOID
has failed and may need to be checked out this is the part that opens the door for the ice dispenser. Click Here=> Amana DRS2663B Dispenser Facade Removal Instructions
As a Whirlpol Technician this is the only way to get to these parts to find exactly what is happening. Should you have other Tech questions I will be here or on our new Beta Fixya Website, Please rate if helpful, Thank You Sea Breeze
Oct 14, 2011 | Amana DRS2663B Side by Side Refrigerator
My Amana refrigerator has water and ice on the outside door. The ice works fine but I am not getting any water. I have replaced the water filter. Can you tell me what the problem is?
Did you check to make sure you have water going into the filter? Sometimes, the tiny hole used in the flow valve gets clogged at the source. Shut the valve and reopen it.
Feb 02, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Help, no water but have ice out of door on amana side by side.
The freezer temperature dial is set too cold and it is causing the water to freeze in the tube right where it enters the freezer section.If you turn the temperature selector one or two numbers warmer for the freezer it will help.
You will also have to turn the box off and let the freezer thaw real good so that the line will thaw. Once this has been done, it should work fine.
Jun 08, 2008 | Amana SXD524VW Side by Side Refrigerator
Amana Refridgerator Freezer, French Doors
Most side-by-sides have a length of hose at the bottom of the freezer that send the water to the ice maker and water dispenser. take the back off so you can see this hose, there may be a kink in it, or a clog.
May 30, 2008 | Amana ACD2232HR Side by Side Refrigerator
Amana side by side
if the unit has been runfor some time prior to connecting the water the fill tube may be frozen up, he solution is to turn off defrost overnight with door open and then turn back on, flush water through when turned back on to clear old water and air.
Sep 02, 2007 | Amana ARS9266BS Side by Side Refrigerator
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
143 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
