Question about Dryers
I have a Kenmore HE3 front load dryer number DADT-ELE-2406024-EL54 saying F01 and won't turn on. I cleaned the lint from hose and still nothing. Is there something else I can try before calling a tech
First said check lint screen. It was clean so I cleaned the hose in back. Now saying F01 and won't run.
    New Friend:
    Problem Solver:
  • 11 Answers
I don't have a specific answer for you, but I'm heading a lot of reports about the new electronic washers and dryers. It seems they are very touchy. If I had one, I would be sure to use a surge protector to protect the circuit board.
Posted on Apr 23, 2014
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: My whirlpool duet dryer display showing a -- --
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
TheMobilian
  • 8220 Answers
SOURCE: What is wrong with my Kenmore Elite Quiet Pak 4 HE3 Electric Dryer?
Might be a2 things: Vent blockage causing overheat OR bad thermistor. Repair clinic shows how to replace it:
PART AND VIDEO
Note: Make sure you order the correct thermistor for your dryer
Posted on Dec 05, 2012
Keep getting "AF" code even after cleaning and washing lint trap and cleaning all hoses from back of unit all the way to out of house.
your description is common when there is a blockage , or blower not moving, I would take it apart again and reassemble to make sure everything is put together correctly.
Nov 30, 2015 | Dryers
Dryer runs for about 3 minutes then won't start again. when I open door it's hotter than normal in the tub.
Hi alan cole196...
Check and clean if necessary your vent hose.
If you vent hose "seems" to be clean then,try running the dryer with the vent hose off and see if the dryer is not running hot anymore.
Make sure your lint screen is in place and has no tears or holes in it and is still firmly attached to the frame.
If you are running too hot you are not moving enough air thru the system.
It could be that the fan blade is plugged up.
The problem could be a large lint ball build up in the center of the fan or a sock,thin pants,a pen,etc. that has gotten into the fan by falling down the hole where the lint screen is normally inserted.
You have to find the air restriction to solve the problem.
It also can be a loose or worn out blower wheel/fan.
Please take time to rate me.
Sep 22, 2011 | Dryers
Dryer is extremely hot inside back of dryer, top of dryer back and the back of the unit
Hi laurie a pow...
Aug 22, 2011 | Kenmore 62872 Electric Dryer
Won't dry clothes completely. They are still damp after a 60 min cycle
check you vent hose- if plugged/crimped air can't get out with moisture- also go to HOME DEPOT or LOWES- get dryer lint brush- goes in hole where lint screen is - clean out good
May 10, 2011 | Dryers
Dryer keeps saying check filter - lint screen is clean-dryer won't run
Had the same problem. Filter was clean. Vacuumed out the area under the filter. Still had problem. Unplugged the dryer. Removed the hose vent (back of dryer) and checked the exhaust -- all clean. Plugged the dryer back in and was fine. Still going to check the vent to the outside for lint buildup.
Jan 17, 2011 | LG DLG2524 Gas Dryer
My BOSCH dryer #WTE86300US keeps stopping in mid cycle and gives the signal F3 which says to check condensation outlet and I have cleaned all the parts and cleaned hose but it will still beep after a few...
I have owned the same dryer for about a year and just started having this F03 problem. The condensation drain hose is the soft flexible rubber hose coming out of the back of the dryer and it drains into the same drain as a washer. It's easy to pull the hose off its connector at the back of the dryer and just blow hard into it to make sure there's no lint clogging the hose and reconnect it to the dryer. Next open the panel on the left of the dryer and thoroughly rinse (water only, no soap) clean the two parts behind the door (first is plastic and behind that is the condensation filter which probably is loaded with lint). Sometimes the lint in the condensation filter channels (those that run from front to back) can be quite stuck. Use a long pipe cleaner to get in there or a garden hose with a spray nozzle. Shake the excess water out of the condensation filter and dry off the outsides of two parts. Clean all the lint out the compartment where the parts go. There is one more crucial step not mentioned in the manual. Once you remove the condensation filter you will see a small plastic panel on the lower wall of the condensation filter slot. Slide a flat blade screwdriver or a blunt table knife under the panel and gently pop it open. Under the panel is a small chamber that you can't see very well where you will find a slurry of lint/water which is what clogs the condensation outlet. With latex gloves reach in there and clean it out. Use paper towel to get it all out. Blow hard into the dryer through the condensation hose to clear up any last bits. Pop the panel back in place as well as the condensation filter and the plastic part. Take out the lint filter (within the dryer drum compartment) and wash it with soap and water. Use an old toothbrush or something to clean the screens thoroughly. Rinse well and dry it completely. Clean all the lint out of the empty compartment. Put all three parts back into the dryer. Clean all lint off the door. Using paper towel moistened with white vinegar clean the two metal sensors in drum compartment on the front wall and lower left. Run the dryer empty but with heat on for a few minutes to make sure all the water is drained out. Now try drying a load. I think it's a good idea to rinse clean the condensation filter at least once a month since it collects a lot of lint. Hope this works for you.
Sep 22, 2010 | Bosch WTE86300 Electric Dryer
I recently had an ventless Bosch dryer installed (WTE8600US) and I keep receiving this message F:03 which the manual says "check hose for condensation outlet". any advice?
For the F:03 problem on the Bosch Axxis (WTE86300US) do all the things mentioned in Solution #1 above. Sometimes the lint in the condensation filter channels (those that run from front to back)can be quite stuck. Use a pipe cleaner to get in there or a garden hose with a spray nozzle. However there is one more crucial step not mentioned in the manual or in Solution #1. Once you remove the condensation filter you will see a small plastic panel on the lower wall of the condensation filter slot. Slide a flat blade screwdriver and gently pop it open. Under the panel is a small chamber where you will find a slurry of lint/water which is what clogs the condensation outlet. With latex gloves reach in there and clean it out. Blow hard into the dryer through the condensation hose to clear up any last bits. Pop the panel back in place. This should fix your problem.
Dec 13, 2009 | Bosch Dryers
Kenmore he3 model 11082822102 the check lint
remove back panal and clean hose to sensor.
Nov 19, 2009 | Kitchen Ranges
DRYER TAKES LONGER TO DRY
you could have restricted airflow from the lint screen not being cleaned, a bad blower wheel, or a bad thermostat. take the vent hose off the back and check to see if the air flows out the dryer with good force, if so your vent is probably clogged or not open in the wall. the vent hose may also be picned off from puching the dryer back to far.
Sep 17, 2009 | Whirlpool LER4634J Electric Dryer
Dryer Problem Lint light keeps coming on and dryer will not work
When you say you vacumed the lint area, did you mean the lint catcher underneath where the lint screen sits? The most effective way is to remove the 2 1/4" screws on the bottom of the lower front panel. Once you have the panel down and off, you will see a lint chute (the part under the lint screen). Remove the lint screen, 2 more 1/4" screws towards the top of the lint chute on either side and a 1/4 screw on the bottom by the black clip and youcan remove it for best cleaning and also any possible build up around your blower wheel (the white looking fan underneath the lint chute) Can you run it sucessfully without the hose attached? It could indicate a problem between where the hose enters the wall and exits to the outside of the building. (it will get very hot, humid and a little linty doing this test, but it would eliminate any kind of blockage with the venting). When you washed you lint screen did you scrub it? I usually use soap water and an old tooth brush as you can actually get a clear coating on the screen without even being able to see it. How do your seals look? (put your head in the dryer drum and you will see a grey ring both in the rear and as you look back towards yourself) Are they dammaged? Have you cleaned your moisture sensors? This can cause a false error. While you have your head in the drum and are looking back towards the front, you should see 2 silver bars. Clean them off with the abrasive side of a sponge or a fine grit sand paper. If it is still malfuntioning, drop me a note back with your model and serial numbers (loacted just inside as you open the door) and I will see what else I can come up with.
Jul 11, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
295 people viewed this question
Top Dryers Experts
