Asrock 3 beep code - Computers & Internet
    Brigadier General:
  • 3,400 Answers
Http://pcsupport.about.com/od/nonworkingcomponent/ht/beepcodestb.htm
PROBERLY BAD MEMORY (RAM).
TRY TO RESEAT AND CLEAN THE RAM ,SHIFT PLACES.
Posted on Apr 18, 2014
No video on asrock p4i45G motherboards
Hello the homepage is here:
http://www.asrock.com/mb/Intel/P4i65G/?cat=Manual
3 short beeps: base 64 k ram failure.
If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Read more here:
http://www.computerhope.com/issues/ch000996.htm
Beep codes:
http://www.computerhope.com/beep.htm
The fault could also be: power supply, or bad capacitors on the mainboard.
Good luck
Nov 26, 2012 | Asrock P4i65G Motherboard
I have A desktop motherboard model asrock m266a,when i start it it will have 3 long beeps and stops for a while and another 3 long beeps
Usually 3 beeps indicates a problem with Ram, storeage. If you have more than one stick, you can pull them out, then replace one at a time back in, in your different slots , and restart each time, and see results. you may want to pull out all sticks and restart and see if code is the same.
May 03, 2011 | Asrock M266A Motherboard
Hi, just swaped out a harddrive now my Mainboard *4 core Duel Sata2* does a single beep, pause then rapid beeps. can you help
Please count the number of rapid beeps. 3 short beeps is a memory error. 8 short beeps is a display memory error. 9 short beeps is a ROM Bios checksum error and 10 beeps is a CMOS shut down read/write error.
The solution will depend on the error. For a memory error, remove all of the memory sticks then reinsert each one separately and reboot the computer. If the board continues to beep 3 times, that stick is bad or the memory slot has failed.
The complete beep code list is provided here: http://www.asrock.com/support/qa/TSDQA-01.pdf .
I hope this helps.
Mar 27, 2011 | Asrock P4I45GV R5 Motherboard
What does a AMI bios beep code of one long and 9 short
AMI BIOS beep codes Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code
Descriptions
1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed
Jun 01, 2010 | Asrock 939SLI32-eSATA2 (939SLIESATA2)...
3 beeps when i boot my pc with ram but no beeps when i boot without ram
Here is the info I found on the Asrock website. This would be a normal code if you have no RAM in the system.
Beep Code Descriptions 1 short Memory refresh timer error. 2 short Parity error. 3 short Main memory read / write test error. 4 short System timer failure. 5 short Process error. 6 short Keyboard controller BAT test error. 7 short General exception error. 8 short Display memory error. 9 short ROM BIOS checksum error. 10 short CMOS shutdown Read/Write error. 11 short Cache Memory bad.
Apr 14, 2010 | Asrock K7S41GX Motherboard
Asrock p4vm8 beep codes
How does it sound? Does it beep with memory card seated? one long- 3 shorts beep bad graphic card, one long repeated 3 times bad memory card
Apr 12, 2010 | Asrock P4VM8 Motherboard
3 beeps
This pages lists ASROCK beep codes and says it's a memory read/write error.
Nov 14, 2009 | Asrock K7S41 Motherboard
Asrock K7S41/K7S41GX problem
2 x DDR DIMM slots
- Supports DDR400/333 non-ECC, un-buffered memory
- Max. capacity of system memory: 2GB
3 beeps is usually either video card related, or memory. be sure your memory is UN buffered, and DDR400 or 333 DIMM not DRam.
Remove and re-seat your video card as well.
there should be a troubleshooting guide in your install manual stating the designation of 3 beeps.
Dec 22, 2008 | Asrock P4VM890 Motherboard
Asrock motherboard
Look HERE for a list of bios beep codes
May 18, 2008 | Asrock P4VM800 Motherboard
Error signal ASRock P4VM800
When you open to you're bios menu, either at the top or at the bottom of the screen will be a name of you'e bios. In you're case the name is at the bottom of your bios menu. (American Megatrends Inc.). Or for short AMI You could search google for, AMI bios beep codes.
And you can click on this link, which shows what AMI say's about 3 beeps.
http://www.bioscentral.com/beepcodes/amibeep.htm
You need to test you're memory. (Only if cleaning the memory has did not change the beep error beeps).
First remove you're memory & blow out the DIMM slots with canned air. Clean the copper on the memory with house hold alcohol on a lightly dampend cotton swab. (Let it dry), (Do not touch the copper with you're fingers. Re-install you're memory.
If you have more than one DIMM. Remove the bank farthest from the CPU & boot the PC. Did you hear the 3 beeps? Remove the the next bank & re-install the one you removed first in to the slot closest to the CPU. Boot the PC, again did you hear the 3 beeps?
If I can be of more service, just post back & let me know how thing go.
Good Luck!
Mike
Apr 27, 2008 | Asrock P4VM800 Socket478/SAT/A&V&L/Modem...
Computers & Internet Logo
David Payne
David Payne
