Question about KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher
Fills with water but will not start washing. pump makes a humming noise for awhile and then stops. drain cylcle then works as does the heat dry cycle. Is the wash pump the same as the drain pump?
  • KitchenAid Master
  • 3,247 Answers
The wash pumo and drain pump are different. So it is likely the wash pump is choked and trips or the motor is faulty.
http://www.searspartsdirect.com/partsdirect/part-model/KITCHENAID-Parts/Dishwasher-Parts/Model-KUDS02FRSS0/0593/0130000/W0602076/00008?blt=06&prst=&shdMod=#
It is likely the flap valve (item 5) or the chopper (item 6) are damaged and could be replaced before you get to the wash motor.
Posted on Apr 19, 2014
  • 188 Answers
SOURCE: clean light flashes cant get to start a wash cycle
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It's not as common but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Mar 07, 2009
  • 37 Answers
SOURCE: kitchenaid dishwashes makes wining noise during wash
It sounds as if there is something in the bottom part of the dishwasher arm (it sprays the water around the bottom of the dishwasher). I would suggest that you take out the baskets and then remove and clean all of the parts that water comes out of as well as the bottom drain. If this works or does not, I would also suggest that you run an empty load using 1/4 cup vinegar. Hope this helps!
Posted on Mar 16, 2009
  • 423 Answers
SOURCE: dishwasher fills but does not wash
Is your Kitchenaid Dishwasher a model KUDI02?
If yes, you need to order item 10 on the page link below:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5137276
Good Luck!
Posted on Apr 10, 2009
localwonder
  • 6784 Answers
SOURCE: Motor just hums during the wash cycle. Put it in
OK, that piece of glass may have jammed the wash impeller. this will destroy the motor windings. you will need to gain access to the circulation motor asap.the impeller is attached to the motor that is housed within the pump casing(upper). try to manually move the impeller. if its stuck, try ot remove the obstruction.
It is possible that, the motor is already damaged to the point of no return. in this case, replace the circulation motor. your drain pump should be ran by a totally separate motor(wax).
**NOTE
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
Posted on Jun 21, 2009
  • 6 Answers
SOURCE: Our Kitchenaid kuds25se fills with water but won't wash or drain.
i would check the check valve ....i had the same issue and the info within below link got be up and running again
http://fixitnow.com/wp/2008/11/14/older-whirlpool-kenmore-dishwasher-wont-drain/
Posted on Jun 25, 2009
Wash machine fills up starts cycle then stops it dont go to rinse then will start making a humming noise
it has bad cycle timemer switch in it replce with new one about 80.00 dollars
Dec 24, 2014 | Washing Machines
Kitchenaid kuds02frss1
The wash pump and drain pump are different. So it is likely the wash pump is choked and trips or the motor is faulty.
Apr 17, 2014 | Dishwashers
Kenmore washer model 12502100 goes into rinse cycle fills with water turns then stops. won't drain just stops hear humming or buzzing noise.
Try to put it on rinse on another cycle, like normal, heavy duty or delicate. If it works, then your timer is probably bad. If it doesn't work then maybe the pump. Best of luck
Mar 21, 2010 | Washing Machines
Water will not drain humming noise
Humming sound could be jammed pump.Remove th filter and check pump Blades are free, nothing is stuck in it....
Nov 25, 2009 | Washing Machines
My GE washing machine is stuck on agiation mode.
HUMMING NOISE MAYBE OVERLOAD ON MOTOR OR PUMP SO DEAL NOW WITH DRAIN PROBLEM 1ST IT MAYBE NEED TO DRAIN FILTER CLEAN
THANKS
Jul 15, 2009 | Washing Machines
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Whirpool 1100TXP Dishwasher.
is your water temp set at 120 degrees
Apr 07, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Washer keeps stopping during any cycle
the humming noise could be from two sources and it is worth while doing a few simple checks first the drain pump is jammed with a foreign object. check nothing caught in the impellor second water not available - check taps turned on. also turn water off, undo fill hoses, put in a bucket and turn water back on try on drain or spin programs to check water drainage as well
Jun 19, 2007 | Tecnik TKL9260 Front Load Washer
KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher Logo
150 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
