Question about Panasonic KX-TG4500 Phone
2 LINES PICK UP ON PANASONIC KX-TG4500
WHEN WE PICK UP LINE 2 OR LINE 3 THE OTHER ONE PICKS UP ALSO, AND WHEN A CALL COMES IN ON LINE 2 OR LINE 3 IF WE PICK UP THE CALL THERE IS A DIAL TONE AND BOTH LINES RING AT THE SAME TIME.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 91 Answers
Sounds like you have the cords into the back of the phone mixed up. If you have a cord with 1 and 2 plugged into 1/2, great. But then if you have another jack also with 1 and 2, but plug it into 3/4, now you answer line 3 on second phone and line 1 lights up on first phone. Or line rings line 1 here and line 3 over ther. Gotta keep that straight and the jacks have to have identical lines.
Posted on May 07, 2014
Slinteriors
  • 8617 Answers
SOURCE: answer too fast
Here is a link where you can download the user manual for free which will explain how to set the phone to answer after a certain number of rings. Just go to the link its already set up just click on the download link.
http://www.retrevo.com/s/Panasonic-KX-TC1743W-Telephones-review-manual/id/2914bh651/t/1-2/
Posted on Mar 23, 2008
  • 8 Answers
SOURCE: Panasonic KX - T 7730
look.................. a *****
Posted on Jun 25, 2008
cnavarro
  • 2460 Answers
SOURCE: change the ring tone of Panasonic KX-T7730
I think it can be done. Just exchange the phone for a 7633 and change out the TA for a TDA-50.
Piece of cake.
Carl
Posted on Aug 25, 2008
  • 12 Answers
SOURCE: i have no dial tone on one line. call my number and it rings
IT IS DUE TO NETWORK FAILURE OF THAT LINE
Posted on Jan 05, 2009
cnavarro
  • 2460 Answers
SOURCE: can not get kx-t7885 to get a dial tone
How are you trying to get an outside line? By dialing 9? If the host system happens to be a TA series, you have to tell it how many lines you have, or that you don't have lines that have hardware ports but no dial tone, since systems select outside lines from the top down.
From System programming, program 400 defines connected lines.
Carl
Posted on Nov 22, 2009
Panasonic KX-TG6711E Cordless phone
Have you check another phone jack in the home? sometimes it is a bad jack that cause it not to work
May 13, 2014 | Panasonic KX-TG4500 Phone
I need to know how to pick up another extension I have Panasonic KX-7730 corded phone.
If it's wired to a TA series cabinet, you can do it in 2 ways. On the intercom 40 picks up the ringing phone(s) in your group, and 41xx picks up the specific ringing phone. In a small office, 40 usually works fine.
Carl
Oct 04, 2010 | Panasonic KX-T7730 Corded Phone
Hi: I have a Panasonic KX-T7420 phone. When one of the incoming lines is ringing and I pick up the handset, it picks up the intercom and not the incoming line. Is there a way to get the thing to answer...
There are 2 things that would prevent you from being able to answer a ringing phone by picking up the handset. Your phone has to be ringing, and you need to set preferred line ringing on incoming calls.
The second part is easy. Press PROGRAM 99 and dial 22 STORE on your phone. Now when a call rings on your phone you can pick it up. If you can't, then your phone is not ringing.
Ringing is set in system programming.
Carl
Aug 04, 2010 | Panasonic KX-T7420 Corded Phone
I work for the Western Regional Day Report Center in Huntington, WV and we are using one of you Panasonic KX-TG4500 phones and Line 1 will light up when a call comes in, but WILL NOT RING. Now lines...
Check to see if the ringing volume is turned down,
On the base unit press the menu button and scroll to ringer settings using the up and down arrow keys, press the enter key.
Scroll down to ring group and press enter.
Press the left or right arrow keys to select the line desired.
press the down arrow key to move to Ext #.
Enter in the disired extension number starting with the base as Ext 0.
press enter to save.
Apr 05, 2010 | Panasonic KX-TG4500 Phone
How do you plug in the phone and make sure all four lines work?
The easiest way is to make 4 outgoing calls and placing the calls on hold. You should have 2 cords with 2 lines on each one. If you look at the bottom of the plastic connector that goes in the phone. It must have a minium of 4 copper pins. Hope this helps.
Feb 26, 2010 | Panasonic KX-TG4500 Phone
I have the kx-tg 4500 4 line base unit phone. Line one flashes but does not ring or display caller. The other lines work fine. The handsets show no activity ie they don't even flash if a call comes in on...
I had the same problem once, turned off the base unit from power cord and the phone line and all connected handset units, then turned it back on & it worked.
Aug 05, 2009 | Panasonic KX-TG4500 Phone
Phone calls come in on line 2 rather than line 1 and, therefore, the calls will not roll over. Can I reassign the lines the call comes in on? The phone company swears nothing is wrong with the wiring.
do you have two seperate lines to the house, both going to the same box? If so, locate your phone box(usually a small plastic box on the outside of the home) open it up, then openthe second panel inside the box. you should see two sets of wires coming in. on newer boxes they have phone jacks inside with short plugs to them. reverse these and that should change your lines. these are the output jacks. if you have seperate boxes for each line you'll have to change the input lines to the other boxes. if they are close together and you have enough slack it's not hard. if they are far apart, then it gets in to running wire to them. take a look and see if it is the easy way. hope this helps
Jul 23, 2009 | Panasonic KX-TG4500 Phone
Panasonic base unit went dead
THROW IT AWAY.  I HAVE THE SAME PROBLEM AND PANASONIC AFTER SALES "SERVICE" PEOPLE  HAVE BEEN COMPLETELY USELESS!
Mar 10, 2009 | Panasonic KX-TG4500 Phone
First line does not ring..
Hit the reset button on the bottom of the base unit and reinitialize your setup.
Jun 04, 2008 | Panasonic KX-TG4500 Phone
Panasonic KX-TG4500 Phone Logo
131 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
