Question about Dishwashers
Kitchenaid kuds02frss1 Fills with water but will not start the wash pump cycle. pump motor makes a humming noise for awhile then stops. afterwards the drain pump cycle and heat dry cycle function properly. Is the wash pump and drain pump the same?
  • Dishwashers Master
  • 3,247 Answers
The wash pump and drain pump are different. So it is likely the wash pump is choked and trips or the motor is faulty.
http://www.searspartsdirect.com/partsdirect/part-model/KITCHENAID-Parts/Dishwasher-Parts/Model-KUDS02FRSS0/0593/0130000/W0602076/00008?blt=06&prst=&shdMod=#
It is likely the flap valve (item 5) or the chopper (item 6) are damaged and could be replaced before you get to the wash motor.
Posted on Apr 19, 2014
  • 641 Answers
SOURCE: wash cycle
Check first that the filter located inside the machine (on bottom) is clean. In case it clean - The problem is with the pump. It could be a blockage between pump and the tub, or just a defective pump (The pump takes suction from the tub and forces water up through the spray arms, which spray the dishes. The water then simply drops back into the tub for recirculation). Good luck !!
Posted on Jul 02, 2006
  • 1462 Answers
SOURCE: Humming noise
humming is the motor powered up but not turning. burning smell is the motor overheating. cause may be the motor capacitor which is a cheap part. try replecing it and hope thge motor survived. could also be a foreign object in the pump impellor
Posted on Mar 31, 2007
SOURCE: dishwasher pump will drain but not force water into spray arms
If the washer is not used regularly the shaft can stick to the seals and prevent the motor from spinning. This happens quite regularly for me if I don't use the washer often. You can just take off the bottom panel - after shutting off power to the dishwasher - and access the motor. you should see some fins and then just try to spin the motor by hand. It usually takes about 90 degrees of rotation before the motor breaks free from the seal. You'll have to fight through the spring-like resistance created by the seal-shaft adhesion. After it breaks free the motor spins freely and you should be all set to go. I haven't found a more permanent fix for this other than running the dishwasher more regularly.
Posted on Feb 09, 2008
SOURCE: Loud Whining/Humming noise while washing
It's noisy If your dishwasher seems noisy, check these:
Water-inlet valve
Motor
Heater fan
Pump
Water-inlet valve An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor If it's the motor that's noisy, either of these may be the "culprit:"
  • As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
  • If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
Posted on Mar 22, 2008
SOURCE: kenmore 665.17539. fills but does not wash. makes
Kenmore 665
My dishes on the top rack are no longer getting clean. I don't think any water is going to the top. The dishes on the bottom get clean but have a soap residue on them.
Posted on Jul 19, 2009
Wash machine fills up starts cycle then stops it dont go to rinse then will start making a humming noise
it has bad cycle timemer switch in it replce with new one about 80.00 dollars
Dec 24, 2014 | Washing Machines
Dishwasher hums intermitantly and after the wash cycle is completed
Sounds like you have a bearing going out. It could be in the system pump or the rotating washing arms. I would suggest getting ahold of Kitchenaid's customer support and relay when during which cycle the noise occurs and they should be able to identify whats going wrong.
Jan 22, 2014 | KitchenAid KUDE70FXPA Builtin Dishwasher
Kitchen Aid Imperial 21 has loud motor noise duing wash cycle
loud motor noises during the wash cycle usually come from a water pump. Either the water pump will stop working soon, or it will keep working for a while longer, and the unit will stop cleaning. Sometimes the pump will stop making the noise for a while before it stops.
Jan 29, 2012 | KitchenAid Dishwashers
Kitchen Aid Diswasher does not advance to the wash cycle
the hum worries me, from your discription sounds like a wash motor may be bad, or something is blocking the pump from turning, unless your are really handy, i suggest you call for service.
Sears offers what they call and SSA on their 800 # if you buy the SSA it will include the repair you need and a 1 yr warranty. good luck
Jan 07, 2012 | KitchenAid Dishwashers
My dishwasher starts fills water and never starts wash cycle?
If you hear a hum when it should be washing, the motor has seized. Replace motor. If it fills with water and stops quite, run it through a test using the tech sheet under the bottom panel to access. These dishwasher have had issues with the motor.
Oct 09, 2009 | KitchenAid 24 in. KUDU02FR Built-in...
My GE washing machine is stuck on agiation mode.
HUMMING NOISE MAYBE OVERLOAD ON MOTOR OR PUMP SO DEAL NOW WITH DRAIN PROBLEM 1ST IT MAYBE NEED TO DRAIN FILTER CLEAN
THANKS
Jul 15, 2009 | Washing Machines
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Washer fills but won't wash or drain yet it cycles KUDM24SEAL1
Check to see if power is getting to the motor. If it is then you have a bad motor. Is the motor making a noise? Some of that broken plastic could have got down into the pump and have it locked up.
Dec 16, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Dishwashers Logo
105 people viewed this question
Top Dishwashers Experts
