Question about Life Fitness 95xi Elliptical Crosstrainer
Life fitness crosstrainer changing from miles to kilometers
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: life fitness crosstrainer 9500 HR just shut down few second after start
see the video and fix it. This happen because the lack of maintenance schedule.God bless you
Posted on Apr 04, 2013
I WANT TO CHANGE KILOMETER TO MILe
Hi There,
Give this a try....go to Sportsmith.net and/or google Service Menu Life Fitness 95Ti. Once in the service menu, there should be an entry for the user to select Miles or Km.
It mentions pressing/holding the Pause Button until the Service menu appears on the display. Good Luck!
Apr 25, 2016 | Life Fitness 95Ti Treadmill 95 Ti
Tip
95Xi Crosstrainer Crank Arm Cover Replacement
About This Video
Crank Arm Cover Removal and Replacement Video for the 95Xi LifeFitness Crosstrainer
  • This video demonstrates how to remove and replace a Crank Arm Cover on a Life Fitness 95Xi Crosstrainer elliptical
Necessary Tools:
  • Philips Screwdriver
  • 5/32" Allen Wrench
  • 2MM Allen Wrench
  • T25 Driver
  • T50 Driver
  1. Remove the main shrouds as seen in the shroud replacement video
  2. Remove the outer link cover as seen in the outer link cover removal video
  3. Remove the pedal lever assembly (as seen in Sportsmith's Pedal Lever Replacement video) on the side where the crank arm cover replacement is needed
  4. Remove the two bolts holding the crank arm cover in place, and remove the crank arm cover
  5. Replace the parts in reverse order
LifeFitness 95Xi Crank Arm Cover Video Removal and Replacement
on Feb 11, 2015 | Life Fitness Crosstrainer, 9100, 9500 Rear...
Tip
95Xi Crosstrainer Shroud Replacement
Video Presentation of Replacing the Main Shroud on a LifeFitness 95Xi Crosstrainer
  • The video shows the steps involved in replacement of the main shroud on a LifeFitness 95Xi
  • Tools:
    • Phillips Screwdriver
  • Remove the (4) screws securing the main shroud to the drive frame assembly
    • There are two screws on each side
  • Lift straight up on the shroud to remove it
  • Install the main shroud in reverse order
    • Making sure the main shroud fits into the grooves of the lower shroud panels
Repair Video for LifeFitness 95Xi Crosstrainer Shroud Replacement
THhe life fitness 95XI display does not work - where is the battery located to change
under main shroud 4 screws 2 each side, then allen key to remove and replace.
Sep 21, 2013 | Life Fitness 95xi Elliptical Crosstrainer
Tip
95Xi Crosstrainer Drive Belt Replacement
Drive Belt Replacement Video for LifeFitness 95Xi Crosstrainer Elliptical
Tools needed:
  • T25 Driver
  • T50 Driver
  • 2MM Allen Wrench
  1. Remove the main shrouds as seen in the main shroud removal video
  2. Remove the left outer link cover as seen in the Outer Link Cover removal video
  3. Remove the left pedal lever assembly as seen in Sportsmith's Pedal Lever replacement video
  5. Walk the drive belt off the pulley and remove it from the unit
  6. Install the new belt around the crossover shaft first and then walk it onto the pulley
  7. Replace the remaining parts in reverse order
LifeFitness 95Xi Drive Belt Video How To Replace
Tip
95Xi Crosstrainer Pedal Replacement
Video about How to Replace the Pedal on a 95Xi Crosstrainer by LifeFitness
  • This video is about how to replace the pedal on a 95Xi LifeFitness crosstrainer
  • Tools necessary:
    • T40 Torx Driver
  • Remove the (4) torx bolts securing the pedal to the pedal lever assembly
  • Install the new pedal in reverse order
  • This completes the replacement of a pedal on the LifeFitness 95Xi
Life Fitness Crosstrainer 95Xi Video Pedal Replacement
on Apr 28, 2014 | Exercise & Fitness
Life fitness crosstrainer 9500 HR just shut down few second after start
Apr 04, 2013 | Life Fitness Crosstrainer, 9100, 9500 Rear...
How do i change a life fitness cross trainer from mph to kph
Dear Sir:You can have some pencil, and with the point of the pencil, go under the display board, in the small orifice, and with the point of the pencil press the small button, and ready. Restart the machine.
sincerely. God bless you
May 03, 2012 | Life Fitness 95xi Elliptical Crosstrainer
I WANT TO CHANGE KILOMETER TO MILE
This is in manager settings. I dont know off hand on the next gen, but on the TI it is hold pause and press clear twice then use arrow keys to navigate. I will check tomorrow and get back.
Jan 14, 2010 | Life Fitness 9500HR Next Generation...
Life Fitness 95xi Elliptical Crosstrainer Logo
22 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
