Question about Weber Chill 05-161 Beverage Cooler
Need new temp control knob
Control knob broke, cant tell where setting is
    Problem Solver:
  • 4 Answers
I have nyyankee690@aol.com or call 9734923253
Posted on Dec 09, 2014
Temp control knob loose on old Frigidaire oven
my best guess its A Frigidaire wall oven, circa 1966-1970,
unsafe to use at any time if the temp controller trips the circuit breaker
could be the oven thermostat causing the trip as well
if Frigidaire are still in business
You will need to ask an electrician to fit a /tested used controller or new superseded part temp controller and knob
Oct 11, 2016 | Frigidaire Ovens
True T-49 refrigerator/freezer temperature calibration
Contact the manufacture, it is most likely going to be covered under warranty. If the knob is not removable, (check for a set screw on the side of the knob it will take a small allen wrench) Then the thermostat (temp controller) will need to be replaced, if it isn't a style that you can calibrate.
Jan 30, 2014 | True Refrigeration True T-49 2 Door Bottom...
My 2005 kia sorento will not switch from hot to cold and vise versa. the mechanic is saying its probably the "airdoor actuactor motor / mixer actuator. any advice and where to buy this part(s) for a g
Sorry for your troubles ,
Temperature Hand in dash reading NORMAL ?
Does it Turn Blue to Red if so is do you feel friction or restraint like your turning something rather than freewheeling (smooth fast turning) or Digital and or does it show that it should be warm and not cold ?
Does the TEMP change at all(even the least little bit could narrow the results down) when knob is turned?
POSSIBLE - The Actuator/Motor that switches the VENTS very well could be BAD , Temperature Switch / Climate Control Switch (hot to cold could be broke at the base and only allowing the knob to turn and not in the switch ) Thermostat may be stuck open (keeping the engine running cool and smooth but no heat , maybe just a slight TEMP change when switched from Cold to Hot ). The A/C Switch is pushed in or turned on or broke and is stuck ON
FIXES - 1st- Check FUSES - If Temp HAND Reads Normal it not your THERMOSTAT. - Change the Control Switch / Temp switch - Check A/C Button/Knob . AUTOZONE is my place of business they PRICE MATCH AS WELL!
Hope this Helps , Flaming Ratchets Auto Repair
Dec 05, 2013 | 2005 Kia Sorento
2003 mitsubishi outlander temperature control knob would get stuck while turning..and finally snapped off and broke
The source of the problem is not the knob it is the temp blend door binding. Putting to much stress on the knob. If you replace just the control head with the knob it will only break again. You need a dampener repair kit and to install you will have to remove the dash and heater core.this will slow you to access the door that is binding. Hope this was more help then it broke replace it.
Nov 09, 2011 | 2003 Mitsubishi Outlander
I have an older a/c model no. A494901 (?). The control knob broke off. Is it very hard to replace it with a new knob? And, where would I get a new knob? Thanks, -Fran O'Neill
Depending on your break is the stem leading from the settings selector switch still there or did it break to. If it broke as well you will need to replace both the selector switch and the knob. If not the knob can be obtained from your local Sears Repair Center.
Jul 05, 2011 | Kenmore Heating & Cooling
I have a tonino lamborghini watch and cant figure out how to set the time
The stainless steel band broke on my Tonino Lamborghini watch. Can anyone tell me how and where to get a new band? Or even a replacement link for mine?
Jan 07, 2011 | Bulova Watch
Temp setting worn off and difficult to set temp
call region repair center to get & order new temp control dial.
Nov 17, 2009 | Kitchen Ranges
I can not get the temp knob to transfer form cool
most likely you'll have to replace the plastic tab on the back of your controls its easy to do. You'll have to take out the radio and temp. Control unit you'll see where the cable hooks in its probably broke. For a temporary fix you can unhook the cable at the floor. Its on the drivers side by the gas pedal.
Oct 20, 2009 | 2002 Nissan Altima
2005 toyota highlander - temp control knob not working to adjust temp hot or cold - by tapping on the wheel/knob it will adjust at times. wiring concern? knob concern? dealer wants $800 for new control...
Just repair a panel for one of these, They use a 3-wire ribon 1/8 space between wire. The one I fix had the two outer wire broke loose at the heat/cool switch it had become loose from the panel which gave it enought wiggle room which allowed the wires to break I fixed buy replace all three wire from the main panel to heat/cool switch. With all 3 wire be seperate. They should not break ago.
Jul 08, 2009 | Heating & Cooling
Temp on oven is not correct
Good Evening.
I would make sure that the conversion kit was the correct kit for your stove. Also, if it is not heating properly I would call the gas company and tell them the conversion did not work and they need to double check their work (at no charge). If everything is in order proceed to the next step below.
You can try removing the Oven Temp control. There is an adjustment on the knob which will vary the temp + or - 75 degrees F or so.
Procedure: Preheat your oven for 350 degrees F. Give it a good 1/2 hour to 45 minutes and then pull the knob off (usually held on with a set screw) You will need a thermometer that will go up to 500 degrees (I use an electronic one but you can use any kind as long as it is within the ovens temp range. If the oven is underheating simply turn the oven control stem to a higher setting, say a 50 degree incrament. Wait another 1/2 hour and measure temp inside oven. Keep in mind when you open the oven door it affects recovery time, etc so 30 minutes between a measurement and adjustment should suffice. Once you have adjusted the temp control to your target temp of 350 degrees look on the back of the knob and see if there is a stop adjustment. There is a chance the temp control knob could be setup differently but the same philiosphy/procedure will be similar.- the adjustment could be on the stem itself instead of the knob.
Also keep in mind that the oven temp will fluctuate from high to low as it tries to adjust to the temp it is set at. That is why it is very important to give the oven time to cycle low to high when you incrament the temp control. Hope this helps and good luck! Gary
Mar 14, 2009 | Whirlpool SF325 Gas Kitchen Range
Weber Chill 05-161 Beverage Cooler Logo
67 people viewed this question
Top Weber Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Weber Refrigerator Expert? Answer questions, earn points and help others
