Most units of this type have a "dimmer" for the display. Have you checked this? If you have the product manual, there will be a section in it detailing how to change the setting. If you don't have the manual, download one the Bose website.
Hello
If you have the original remote
check the display button or dimmer button.
If you don't get any illumination from the display screen, that means that display florescent is at the end of life needs to be serviced.
Regards.
Rotating blinking lights in the display is probably an indication that the Wrinkle Prevent option has been selected. Wrinkle Prevent will continue to tumble the dryer without heat after the cycle has ended to help prevent wrinkles from setting in. When this option is selected by pressing the Wrinkle Prevent button on the control panel, the display will count down the estimated cycle time; when the cycle ends, the display will show lights blinking in a circular (or actually rectangular) motion.
To deactivate, simply press the Wrinkle Prevent button again so the light is not illuminated.
1. Turn key in ignition switch to position "1". 2. Press either Menu Button repeatedly until the basic kilometer or miles display is shown on the multifunction display . 3. Press the Reset/Illumination Button 3 times. (You'll hear an audible beep and the voltage is shown on the multifunction display.) 4. Turn key in ignition switch to position "2". 5. Press the lower Display Button. (The Service Display appears with miles remaining/exceeded etc.) 6. Press the Reset/Illumination Button 1 time. (The Oil Type menu appears in the multifunction display.) 7. Select the engine oil grade by pressing the +/- Buttons. (You may have only 1 option or multiple options depending on your engine.) 8. Press the upper Display Button. 9. Press the Reset/Illumination Button for 3 seconds to confirm. 10. Press the upper Display Button to return to the Service Display menu. 11. Press the upper Menu Button to display the kilometer or miles reading. 12. Turn key in ignition switch to position "0".
Please post back with any questions. Best of luck. Greg
It's possible that the "illumination" wire is not connected or connected improperly. It's also possible that the front panel electrical connections are not making proper contact. Remove the front panel and gently clean the contacts with a pencil eraser.
Also, the CDX-C680 allows you to select either green or amber illumination. One or the other may be defective. Try changing it. Press SHIFT - press "3" (set up) three times - press "5" (right arrow) to change the setting. Also check the setting for "dimmer". ON will result in a dimmed display at all times. AUTO will dim the display whenever the headlights are turned on (if the wiring is connected properly). OFF will result in the brightest display at all times.
Could need to be reset. Try unplugging it for a couple of Min's. it may reset itself. If not send me a message and I'll check the service manual for the reset procedure on Monday when I go to that hell they call work.
Is the display saying NOT READY, or is it not comming on.
If the display is blank there is a known problem with those displays and Xerox will replace them free of charge.
If you have a blank display, call 1-800-835-6100.
If I am misunderstanding the issue provide more details please.
