The fan made a noise and when the tv was turned back on after 2 hours the temp light was flashing and the tv shut itself off. The lamp is ok and we have removed the fan. Can we use another fan to replace it with or do I need to purchase the exact fan from Hitachi? I have bought a fan from Allied and it seems to be almost the same except it does not have the white wire my original fan did. I may be an idiot but the amp is the same and the fan itself fits like the old. (or at least looks as if it will line up correctly)
Chances are good that it will work. The only catch is that one of the wires are monitored by the protect circuit. If the wiring is different it may not work. I would try it though. Nothing bad should happen. Make sure that if it does work that the fan is blowing in the correct direction.
Hope this helps,
Skyassoc
