Question about Samsung Freezers
Freezer problem with the program
User manual
Try seaching on the internet for" 'your model' manual" (ie "???? manual" where ???? is to substituted for the actual model number of your freezer. You could also try the manufacturer's website.
or search directly on eg http://kitchen.manualsonline.com/manuals/device/freezer.html
I am sorry I can't be of help without the model number, often on the 'rating plate', a small metal sheet, which is itself often inside the freezer attached to the left wall as you look into it.
May 29, 2013 | Freezers
How tro restart my digital freezer?
Can you hear the compressor start? If not try the extreme freeze button. Check the condenser is clean and fan working ok.
Jul 24, 2012 | Frigidaire Freezers
Defrost times and adjust
http://www.turboairinc.com/TB-Service/Service%20Manual%20%20-%20April%202008/TSF-49SD.pdf
go to this site and check out the service manual. I guessed at the unit you had as you did not include the model number.
You can also go to turboairinc.com and search for more info if you need to.
Hope this gets you your answer.
Apr 15, 2010 | Turbo Air 49 cu. ft. / 1388 liter...
Refrigerator not dispensing water or ice
repairs should be performed by a qualified technician. if there isn't ice in the ice bucket located in the freezer you have a water flow problem. if there is water going to the filter and nothing out of the freezer then you have a clogged freezer replace it. if these things are ok then yes it could be the electronic control. filter failure is a common problem.
Apr 29, 2017 | Maytag Freezers
Model g22012
If its the digital display with I think 2 or 3 buttons, then you cannot re-program the control.
It is factory set and I have never been able to get any clear answers from Traulsen on the steps to re-programming it for a different setting.
Best advice I can give you is to contact Traulsen directly and ask for tech support. Once you get them on the phone, explain that you just purchased this cooler/freezer and you need a control that suites your needs. They should have one that is pre-programmed to your needs.
Jan 07, 2010 | Traulsen 46 cu. ft. Upright Freezer G22011
No owners manual
I solved the problem by avoiding this stupid website that only screws you around trying to sell you something and go somewhere else. If your stupid response program would have noticed i asked a question about a different freezer you ****.
Dec 21, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Kenore freezer running constantly
need a model #.. is this a frost free freezer or a refrigerator ?
Sep 19, 2007 | Freezers
Open Questions:
ca. 2010 GE fridge with Samsung ice maker. I have to hold the reset on the icemaker every few days to keep making ice or it quits. What's the fix? When it works, there's a loud popping every 3 seconds for about 2 minutes, then a few minutes later ice harvests into the bin. With my hand against the outside of the fridge next to the icemaker, I can literally feel each pop. I originally thought it was the ice release heater failing that caused cubes to pop loose hard, but I couldn't find anything wrong electronically when I took things apart and examined the board and connections in the icemaker. I may have missed something mechanically that's causing some part to flex and then suddenly give against the wall inside every 3 secs as the clock cycles through the beginning of a harvest? What might that be? But after reassembly it now has the added feature of harvesting a few times and then stopping altogether. We run flat out of ice if I forget to press and hold the reset button for 10 secs. every few days. Apparently the clock is cycling incompletely or something now. Could a cog be missing/broken/out of alignment in the clockworks, such that when it gets so far along it slips, but can be reset? How about the lift arm? Could it be out of position inside such that something it's connected to isn't properly repositioning when the arm drops back down? Or could all of this be related to a faulty control board elsewhere in the fridge?
Apr 19, 2017 | Samsung RS261MD 26 cu. ft. Side by Side...
Freezers Logo
75 people viewed this question
Top Samsung Freezers Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
ray gallant
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
