Question about Sony Televison & Video
Rdr-gx330 Stuck at welcome, unfinalized disc is inside, I have attempted pressing the power button for 15 seconds which recycles the power, I have tried the power+eject+stop to get the dvd out, nothing at this time is working as it has in the past. Any other suggestions on how to get past the frozen welcome or at the bare minimum get the disc out. I cannot seem to find any options for a manual eject.
SOURCE: DVD Tray will not open
I purchased this unit back in Mid November to make DVD's of my kids old VHS tapes. To date I have probably have made 400 DVD's. Sunday we came home from being gone all day and the unit was locked up. I tried the reset button, unplugged the unit etc to no avail. I unplugged the unit all Sunday night and looked at it again on Monday morning. I was ready to take the unit back to Best Buy and the unit ejected the DVD and has worked for 2 days (Recorded another dozen DVD's). Tonight while reading the paper a message came on my monitor that there was a problem with the disk and instructed me to push the "enter" button which shut the unit off and was suppose to recover the disc. The recorder is now locked up again. A number of 000000's flashes accross the display and the unit constantly cycles off/on. So it is trying to recover but is obviously not being successful. I am going to try the same thing tonight. I am not sure if I have a bad set of blank DVD's. They are Sony -DVD R, same ones I have been using all along. I do remember having this "Error" message when I first started this project and I had to unplug the unit to resolve but it didn't lock up and I haven't had any issues until Sunday. Seems like something in the software is screwed up. It is frustrating that there doesn't seem to be a manual way to eject the disk??!!
Posted on Jan 16, 2008
SOURCE: Disc won't eject, stays in "RECOVER" mode
I have a panasonic DMR E-60 and had the same problem. What I did was remove 2 side screws and 3 rear screws and lifted top cover off. Then if you are facing the front of the unit to the right of cd unit there is a little nipple that locks the mechanism. Push that in, which would be to the left if your facing the front of the unit. Then press the eject button. Mind you it must be plugged in to power. Be careful not to touch any of the green boards or metal. Hope I was clear. I sent it to panasonic but they wanted 40. just to look at it and up to 140.00 to fix it.
Posted on Jun 03, 2009
  • 5 Answers
SOURCE: My DVD Recorder Won't Start
Sometimes, the Sony documentation recommends unplugging the DVD Recorder for at least 30 minutes, instead of the regular 15 seconds. I know this timing makes a difference on DVR's.
Posted on Jul 23, 2009
SOURCE: SONY RDR GX120 stuck on WELCOME message
I have similar problem. I found that if I remove the outer casing (disconnect from mains supply first) and disconnect the DVD cable to the units circuit board then power up again it would clear the problem, but on reconnecting it then trying again the ‘Welcome’ message returned as before. I’m guessing it’s a problem with the DVD drive or its connection. The only other thing I have noticed is, if you do manage to clear the ‘Welcome’ message and leave the unit switched on with the standby button the unit works as normal.
Posted on Oct 12, 2009
  • 945 Answers
SOURCE: welcome screen locked, tray doesn't open, pwers off rdr gx330
The manual for your dvd is on the sony website
http://esupport.sony.com/US/perl/model-documents.pl?mdl=RDRGX330&LOC=3
Go to F&Q and see disc stuck.
Posted on Oct 19, 2009
RDR-HXD890 gets stuck in update mode
"If your recorder is stuck with UPDATE in the display you will need to hold the Power button for more than five seconds to perform a "soft" reset. It will switch off for a few seconds, then quickly and before it powers itself back on again , TAP THE POWER BUTTON 2 OR 3 TIMES , and it should say WELCOME and will then go to a black screen with no freeview channels
if you use easy setup and select location FRANCE or BELGIUM it wont lock up on epg update and will allow you to operate the machine
but epg wont work
this is a temporary fix until Sony provides a fix for epg problem.
Mar 07, 2014 | Computers & Internet
The disc is stuck in mt sony rsr-gx330 how do I get it out without taking it apart
Have you tried pulling the plug then putting it back turn it on then press OPEN disc at the same time.
Jul 08, 2011 | Sony RDR-GXD360 DVD Recorder
It gives me the message "No disc", even though the
There problem with Lens block first you need to clean the optical with cleaning disc.After that check its work fine if not then need to replaced optical block.
Oct 30, 2010 | Sony RDR-GX330
Sony dvd recorder will not open
Well while the unit is on and the Welcome is frozen push and hold in the power on button for about 15 seconds or so until the power goes off. Then release the power button. The unit will go on and the Welcome will eventually blink and the unit will eventually cycle into power off with just the clock showing. Then unplug the power and wait, unplugged for a few days to let the memory capacitor discharge..... If further you have the same problem then you need to repair it....... Please post comments for further help or information...........
Good Luck!!
Mar 27, 2010 | Sony RDR-VX560 DVD Recorder/VCR
Can't get subtitles to turn off on my Sony RDR-GX330
Push the 'Subtitle' button (It's under the 'Input Select' button right side) on the remote keep pushing it until it gets to Subtitle Off.
Jan 29, 2010 | Sony RDR-GX330
My dvd player rdr-hxd860 seems to be frozen on 'welcome'
I've had the same problem. I've actually unplugged the unit and it's been unplugged for probably about two weeks. When I reconnected the power this morning the problem persisted where the DVD Recorder was stuck on the Welcome Screen. As a last ditch effort I pressed and held the power button for 10 to 15 seconds until the word "Welcome" dissapeard of the screen and back on. This seems to have reset the unit. I know I should have tried this a long time ago. So much for reading the instruction manual! I'm just glad it's working again!
Nov 17, 2009 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Disc tray on RDR-HX720 doesn't open and display
1 of 2 things
can you hear the motor running inside the player ????
there is usualy a snall pin hole under the tray insert a paper clip into this hile and push it in if tray starts to auto open it might be just a dry set of rails
if rails asumed dry open unit and coat the rails with anti seize and try again with the switch on front cover
Aug 03, 2009 | Sony (RDR-HX710) DVD±RW Dual Layer...
Jun 25, 2009 | Sony RDR-GX300 DVD Recorder
Scheduled recording stopped
first clean it.since you had recorded and stop, try another disc.
May 08, 2009 | Sony RDR-GX300 DVD Recorder
Televison & Video Logo
57 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
