Question about JVC AM FM CD DET FACE CAR STEREO
JVC Marine Stereo wont power up
There is a red blinking light when faceplate is removed but the stereo will not power up. It is in my boat and has never been used.
  • kenw392
    kenw392 Apr 17, 2014
    It sounds like you may have power going to the yellow wire, but not the red one. Make sure both wires are getting voltage. The yellow wire is constant for the memory and the red wire is ignition, or switched.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 103 Answers
I agree with kenw392. I tried to post a solution earlier from my phone but it kept telling me I had illegal characters in my post, which is silly, because they were all normal letters.
Posted on Apr 18, 2014
SOURCE: Install JVC Car stereo
no power
Posted on Jul 27, 2008
SOURCE: How do I change the time on my JVC KD-G230 stereo?
its simple. hold the "sel" button until the menu comes up and it will say hours use the volume button to change it. then use the next button to go to the minutes. then you can also change other settings under this menu. hit the "sel" button again to go back.
Posted on Apr 10, 2009
  • 13 Answers
SOURCE: i need to set the clock on my jvc kd-g340 car stereo
make sure radio is on and you press and hold sel (select) button
when you see demo release the select button(you might see other option if you have access the menu options). then press the forward button until you see clock h (hour). to adjust turn volume knob. then press the fast forward button again to get clock m (minute) and use volume knob again to adjust minutes. once you are done make sure to press select again to save the time.
Posted on Apr 22, 2009
  • 232 Answers
SOURCE: JVC car stereo won't play cd
If it does it with any cd and it played before you have to clean the lense or laser. Get a cd player laser cleaner disk or cd. If you still have problems take the radio fuse off in the fuse block to restart it. Remove the fuse wait five minutes then reinstall. Also some times when you burn CDs in the wrong format the cd player will not recognize them.
Posted on May 14, 2009
  • 245 Answers
SOURCE: stereo hook up plug black and red wire has power
you also need to check for power at the yellow wire it should be +12 v unswitched which means power all the time wether key is on or off the red is +12 v switched and black is -12 v
Posted on May 16, 2009
Stereo shut down
Did you check fuse block in the car as well as the stereo fuses?
When the face plate is down does that model have any indicator lights in the rest of the deck to see if it is getting power? My old ken wood used to have a red light that blinked behind the faceplate.
Sep 06, 2014 | Kenwood KDC-X993 EXCELON Flip-Face CD/MP3...
Jvc car stereo KD-R570 flashing red
To test radio to see if its working you can bench test it. This means to combine red and yellow and run to 12V positive and Black to 12V negative. IF radio turns on, it would mean its working.
Aug 04, 2014 | JVC Car Audio & Video
CDX-M20 marine stereo problem
Same problem here. Do you recall what you did to bring up the display?
Apr 20, 2012 | Sony Cdx-m20 Marine In-dash Boat Stereo...
My receiver in my boat does not respond to any of the modes. Even the power switch does not turn off the unit. I have to cut the power to turn off the device. Any ideas?
You are using a non marine radio unit in a marine enviroment.
I am going to go out on a limb here and say that the electronics are corroded and causing a short in the unit.
Aug 21, 2011 | JVC AM FM CD DET FACE CAR STEREO
Stereo wont turn on only red light is blinking
It sounds as if you are lacking accessory power to the unit. Insure that the red wire of the Pioneer unit is receiving 12 volts with the key in the accessory and on position.
May 05, 2011 | Pioneer AVH-P5700DVD Car DVD Player
JVC KD-R610 is stuck in Protect mode
Try disconnecting your battery, reconnecting it, and resetting your stereo. If that doesn't work, the constant power (yellow wire) or ignition wire (red wire) may have come in contact with ground or isn't properly connected. Make sure everything is connected properly and try resetting your stereo. If it is still flashing "protect", the unit needs servicing Contact JVC Customer Care Center at: 800-252-5722.
Jul 22, 2010 | JVC AM FM CD DET FACE CAR STEREO
Got power to cd but no display
One idea that comes to mind is,if I remmeber correctly, that model has a removeable faceplate, try this, remove the faceplate,take some denatured alcohol on a Q-tip,clean the electric contacts on the back of the faceplate and also on the front of the deck where they mate together repeatedly for about 4 to 6 times letting them dry between each time that you swab them clean, then replace the faceplate onto the deck being sure that you are seatting the faceplate completely and properly.
This has worked for me sometimes and sometimes not, its worth a try.
Good Luck !
May 02, 2010 | Sony XPLOD CDX-GT200 CD Player
Little red light under faceplate is blinking but i cannot get it to do anything
The blinking light is the anti theft light. When face plate is off this light always blinks. As far as the system not working, make sure you have power, check with a voltmeter, then check fuses. Check the fuses on the wire harness and also where you connected the power leads to the vehicle. If you have power, make sure that all wires are connected correctly. Also, check the ports on the stereo and gps unit to make sure no pins are bent over. Sometimes this may happen. If all looks good, there could possibly be a problem with the system. Expensive to get fixed, but there are a few guys on ebay that will fix it for around $150. Might be worth it, but you need to talk to them about that.
Jul 11, 2008 | Pioneer AVIC-N2 Car DVD Player
Is this considered clipping in marine boat stereo help!!!!
if your radio is puiing more power your ground might not be good enough, use the same spot but remove the ground and rough it up a little on the base with some sand paper or add a metal o ring to get a better ground.
Jul 30, 2007 | iLO XM-MP3-CD Car Stereo
JVC AM FM CD DET FACE CAR STEREO Logo
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
