Question about Saeco Vienna Espresso Machine
Saeco Vienna superautomatica Machine
It grinds and packs the beans , spits out pod, I can hear the water but it never brews coffee. I tried the descale, but when I try to run the water through it spits out steam only no water.
If you open the steamer, does it work correctly? and if u request hot water does it come out?
if not, then its the pump..
Posted on Dec 30, 2007
Why does it brew weak coffee?
can depends many factors, try to grind finer coffe powder and warm well the machine before starting to brew coffee. If the grinder does not make finer coffe powder then you must contact the service, check if blades are in place before calling them...
Jan 19, 2016 | Saeco Vienna SuperAutomatica Coffee...
Trying to figure out which direction to turn the knob inside the coffee bean grinder to make my coffee weaker. Others have told me that the finer the grinds, the stronger the coffee. And the courser the...
You can run more water through the same grind you are using now or you can trun the big knob in the bean hopper to a larger #. That will make the grind coarser. You can turn the knob to a larger # anytime but to turn it to a smaller # it has to be grinding or you will damage the grinder. If you have 2 knobs in the bean hopper, you can turn the small knob down towards the -(minus) and reduce the amount of coffee in the brew unit.
Apr 17, 2011 | Saeco Vienna SuperAutomatica Coffee...
I just received a used Saeco Vienna SuperAutomatica and I can not get coffee to brew. Drive grounds are shot into discard bin
You must have 2 knobs in the bean hopper, or the grinds are more like French Press (very large grinds) If yoou just have 2 knobs turn the small one towards the minus (-) a little, and see idf that helps. If you hqve very large grinds you grinder has seperated and needs to be replaced.
Oct 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
Hi, My machine starts the process allright. It grinds and starts brewing. A few drops comes through, then it just stops and a red light shines up. I have tried to remove some parts and cleaning them. It...
Sounds like the grind is too fine. If its (the big knob) below 8 in the bean hopper, turn it to 16. You can turn the knob to a larger # anytime but you have to be grinding to turn to a smaller #. Make 3 coffee but push the button when it starts to brew to stop the brewing until you get to the third coffee and just let this one brew. If it brew correctly then turn the knob down to a # a couple higher than you had before.
Sep 21, 2010 | Saeco Vienna SuperAutomatica Coffee...
Won't brew
water puddling underneath machine indicates a broken boiler.
Machine needs to be sent in to have the boiler replaced.
Do not continue to use the machine because the seal on the boiler which is broke can end up splashing the electronic board and rendering your machine a paper weight.
Jul 06, 2009 | Saeco Vienna SuperAutomatica Coffee...
Hot water
Grinds are too fine and or the coffee chute is clogged.
Feb 19, 2009 | Saeco Vienna SuperAutomatica Coffee...
Vienna superautomactica found a spring
That spring can fit in many places:-(
I put a blowprint of the brewingunit here.
Jan 31, 2009 | Saeco Vienna SuperAutomatica Coffee...
No can not. You have to waste the beans to run descaler through the Brew Group.
For Descaler or Saeco Parts visit
Nov 06, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna Espresso Machine Logo
226 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
