Question about Singer 5050 Mechanical Sewing Machine
NEED INSTRUCTIONS FOR OILING INNER WORKINGS
I ACCIDENTALLY LEFT MY MACHINE ON OVERNIGHT; THE LIGHT BULB AT LEAST. I SMELLED THE HEAT, LIKE AN ELECTRICAL OVERHEATING, FROM THE MACHINE, NOT KNOWING IF IT WAS THE LIGHT BULB OR WHAT THAT OVERHEATED. I HAVE HAD THIS MACHINE FOR ABOUT 15 YEARS OR SO AND IT HAS BEEN GREAT. AFTER NOTICING THE SMELL, I UNPLUGGED THE MACHINE, THEN PLUGGED IT ALL BACK IN TURNED IT ON, AND IT SEEMS TO WORK FINE, BUT I THINK I STILL SMELL THE ELECTRIC "HEAT" SMELL. I HOPE THAT IF I GIVE IT AN OILING WITH 3 IN 1 OIL, IT WILL BE FINE. IT HAS NEVER BEEN SERVICED OR OILED IN THESE YEARS AND SOMETIMES I BELIEVE A LITTLE TLC CAN BRING THINGS BACK. PLEASE HELP ME FIND OUT WHERE AND HOW MUCH OIL EACH LOCATION NEEDS. THANKS.
  • Katie Lynne Dvo
    Katie Lynne Dvo Apr 17, 2014
    If it smells like it's burning, I would take it apart and make sure no small parts have melted or burned before oiling it.
    New Friend:
    Problem Solver:
  • 7 Answers
Oiling after something overheated isn't the solution. It may be needed due to the age of the machine, but not until you locate what exactly is making the smell, which may be the plastic near the bulb. I would take the cover off and sniff around to locate where the smell is coming from before oiling.
Posted on Apr 20, 2014
SparkGap
  • 363 Answers
SOURCE: Squeeky machine
I looked at the basic manual for your machine here: http://www.singerco.com/accessories/manuals.html (type the model number in the manual search box) and it doesn't show exactly where to oil. If you can get a small can of light oil with a fine spout (like 3 in 1 or similar) then just put a tiny drop of oil on each pivot and spindle. You should be able to see where there was once oil before. Use only a tiny amount or it will make a mess.
Posted on Sep 26, 2007
  • 25 Answers
SOURCE: Where does the oil go?
To oil machine.....Remove the bobbin case.Snap the two retaining arms outwards.Remove the hook race cover (circular ring ) and the hook ( half semi circular) and clean with a soft cloth.Lubricate right hand side wall ( 1-2 drops of oil) turn hand wheel a few times until the hook race is in the left position...replace hook..replace hook race cover ( smooth end to the bottom) and snap back the two hook retaining arms and insert bobbin case and bobbin.
Posted on Jun 02, 2009
  • 1116 Answers
SOURCE: I need to know how to oil this machine. It was
You can download or view the manual here - http://sewingonline.co.uk/instructions/singer457/
You can also purchase the manual at the Singer Company website for $15.00
Posted on Apr 18, 2010
  • 29 Answers
SOURCE: Singer Samba 6 sewing machine
It would be wise to have the machine cleaned & serviced. Do you have a manual for it? Did it come with oil at one time? I found a free manual at
http://homeappliance.manualsonline.com/manuals/mfg/singer/7442.html
You have to register (free)...choose to skip the popups (2)...and you can save the manual to your hard drive.
I checked the manual...you don't need to oil the machine...but page 61-63 shows cleaning...and it's basic. You take the two screws from the throat plate, remove the bobbin case & brush the inside of the machine bed out...I use a small artists plastic bristle brush, or a small childs tooth brush.
Hope this helps.
Posted on May 14, 2010
Testimonial: "Hi, thanks a lot. I don't know if it came with the oil, we assumed that it maybe needs oil (my father knew this from the old machines ;-) ) Again thank you very much for your quick answer!"
  • 1788 Answers
SOURCE: I'm trying to clean and oil my singer 3820. Can
Go to www.singerco.com and click on support and download your manual for free. It will tell you where to oil your machine. Look on page 40. Good luck happy sewing
Posted on Oct 10, 2010
Need the light bulb for the 6005 Elna. I've had this machine for many years and its been a real work horse, but now the light bulb has gone out in it.
Looking here, it looks like a capless bulb like in cars.
Lamp Socket Unit Elna 395723 43
In fact it is, a 12 volt 5 watt capless auto bulb
Changing the Light Bulb The sewing light is located behind the face plate. Unplug
the machine. Remove screw cap and screw. Pull away
face plate.
Pull out light socket. Pull out light bulb. Push in light bulb
with pins aligned to holes in light socket. Push in light
socket.
Replace face plate, screw and screw cap.
NOTE: Only use same type light bulb rated 12 Volts, 5
watts
6005 Elna light bulb Google Search
similar
ELNA 6200 Instruction Manual Changing The Light Bulb Feed Dog
Feb 05, 2018 | Sewing Machines
How to change light bulb on my singer 7466 sewing machine
Here's a manual for your machine:
http://homeappliance.manualsonline.com/manuals/mfg/singer/7466.html
Didn't find instructions re the light bulb but best guess is that the cover on the left side needs to be removed. Looks like there may be a screw that holds the cover in place.
Jun 11, 2016 | Singer 7466 FS, Free $30 Car Vac* FULL...
Bernina Record 930 electronic sewing machine will not zigzag
How long has it been since it has been cleaned and oiled? Mechanical machines, like the 930, need frequent oiling with fresh, good quality oil. (You may want to pick up some Bernina oil for CB Hook machines.)
Apply only 1-2 drops of oil in each spot (look for oil ports--little holes where oil should be placed). Do NOT oil in the middle of the needlebar. This is where the basting stitch mechanism resides and if you oil it, the basting stitch may lock up requiring service.
A good suggestion for oiling is to gently rotate the handwheel and watch where metal rubs against metal. Apply a couple of drops of oil in each spot. Do NOT oil the metal cams, the two plastic gears, or the belt. Next, gently move the selector levers and apply oil there too.
If it has been quite some time since you've oiled, you may have to re-apply oil to get things lubed again. If the zig-zag is still not working, you can direct a handheld hairdryer into the internal mechanism and apply heated air. (Be careful, the metal can get hot to the touch!) Repeat the oil and heat until the zig-zag selector begins to work.
The other part that may be frozen is the upper left side where the light bulb resides (you'll have to remove the screws that hold the covering on). Set the machine to zig-zag and move the handwheel and watch where things move there, also work the lever to raise/lower the presser foot. Again, AVOID the middle of the needlebar==basting stitch mechanism.
Your machine should be oiled every time you finish a big sewing job, every time you install a new bobbin, or every six months if not in frequent use. The bobbin race should be oiled more frequently. When you are familiar with your machine, you will recognize the change in the machine's sound and know that it needs some TLC--cleaning/oiling.
Nov 13, 2015 | Bernina Sewing Machines
How to oil my brother xl-3100
Consult your owner's manual for maintenance instructions. Use only good quality sewing machine oil--not old brown, foul-smelling oil, 3-in-2, WD-40, or cooking oil. Apply only 1-2 drops of oil as instructed.
Oct 09, 2015 | Brother Sewing Machines
I replaced the lightbulbs on my machine, but they do not come on when I power on the machine. What could be the problem?
I don't know what model you have, but on my Bernina there is a button that turns off the lights. You could accidentally have pressed it, and then the lights are out forever until you hit it again!
On mine, the button is found on the back of the machine, on the left (needle) side, at the top. It has a picture of a light bulb on it. So, if you are in front of your machine, stand up and peer over the top of the machine on the back toward the left end and look for a push-button. If you don't see one, then please reveal your model number. Let me know if this helps! Laurie
Oct 16, 2014 | Bernina Sewing Machines
Burning smell
The light may have oil on it or be too close to the plastic housing. Bend the light socket to be as far from the plastic as possible. You may need a lower wattage bulb.
Jun 30, 2013 | Brother CS5055PRW Project Runway...
I can't find a button to turn on the light on my Designer 1
There is no button to turn on the light. When the machine is turned on, the lights come on. If they are not working it means that one of the bulbs needs replacing. If one bulb blows, neither light works. The bulbs are readily available from auto spare parts shops. See page 110 of your manual for instructions on how to replace the bulb.
Nov 07, 2010 | Husqvarna Designer I
Needle position wheel jammed on Elna supermatic
DO NOT TRY TO FORCE THIS If penetrating lubricant left overnight does nort resolve this, then live with it and.....Leave it alone.....it happens through lack of use and has become seized through electrolytic action of the steel and aluminium.
I had one in the workshop last week and when the wheel broke, that was the end, because it is the lynchpin to all other movement of the needle arm. To replace the plastic wheel requires that it move, so it is a hopeless scenario....just learn to live with the needle where it is and think about replacing the machine eventually, we all need to look forward to retirement.
Aug 02, 2009 | Sewing Machines
Electrical problem?
Neither the needle up/down or the LED for the stitch selector will work if the bobbin winding pin/holder is pushed to the right (meaning pushed into the winding position). If you accidentally left the winding pin/holder pushed over, you will lose the functions of both the LEAD and the needle up/down button! (Neither of these functions can work while in bobbin winding mode!)
Nov 04, 2008 | Janome 4623 Mechanical Sewing Machine
Singer 5050 Mechanical Sewing Machine Logo
96 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
