Question about 2006 BUSINESS CLASS M2
My 2006 business class freightliner just clicks when i hit the ignition switch
We changed the solenoid on the fire wall as well as the solenoid on the starter and still just get a click when we turn the ignition switch to start. Checked fuses on fender well,but found nothing wrong. Any suggestions would be appreciated. We have brought truck to be checked out, but sometimes it will just work every time. Tough one to trouble shoot. Thanks in advance, Burns
    New Friend:
  • 118 Answers
Often a poor ground at the batteries or the frame or a poor power connection at the starter can cause this issue.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/justin_3ae27a9d61d6acd4
Posted on Apr 17, 2014
2005 freightliner m2 brakelight switch location
air brakes normally have the switch in the base of the treadle valve or in an air line from that valve to the brakes
it will be a large round switch with 2 wires attached
Aug 22, 2016 | Freightliner 2005 BUSINESS CLASS M2 106
Tail lights don't work
Mate there's fuses for your prime mover and fuses for the trailer, Also you might have a faulty plug on the trailer or harness....
Mar 27, 2016 | 2006 BUSINESS CLASS M2
Will a 2002 freightliner century classic hood fit a 2003 freightliner century classic
Better ask Freightliner.
Freightliner CENTURY CLASS 120 Hood Parts ' TPI
truckpartsinventory.com > Hoods > Freightliner
Freightliner Century Class C120 BBC Fiberglass Hood Shell. Fits Models from 1997-2002 with Old.. ... Shell (Economy). Fits 2002 - 2004 Models with New.
Search Results Freightliner CENTURY CLASS 120 Hood on ...
https://www.heavytruckparts.net/search.php?...FREIGHTLINER...CENT...
Active Truck Parts Hood FREIGHTLINER CENTURY CLASS 120. More Info ... HoodFREIGHTLINER CST120 CENTURY, 2002, 1FUJBBCG92LJ79765, Hood
Oct 30, 2015 | Cars & Trucks
Truck just shuts off i changed fuel solenoid and starter solenoid it runs great when cold then just shuts down like you turned off the key
have the fault codes read
some engines with electronic fuel injectors will do that if one ore more of the injectors fail when they get hot
Sep 19, 2015 | Freightliner 2007 BUSINESS CLASS M2 106
1993 F350 turbo idi wont always start
There is a safety switch on top of the brake pedal lever or clutch lever which is suppose to prevent lurching on start-ups. It is suppose to insure that the Brake pedal is pushed OR the clutch is down before the engine will crank.
The Ignition switch is interrupted by the above cutout switches. But when Ignition is turned on, the Glow plug timer should click and cycle if Power Relay is giving it juice. So if you do not hear that type of clicking, the glow plugs will stay cold.
I would check to see if power is going to the Power Relay above the glow plug timer, and if it is getting power, does the Power Relay send it to the Timer? The starting circuit is more involved in a Diesel because the fuel must be atomized by heating it for initial starts. But you must be getting this process if jumping the solenoid results in the engine starting.
Therefore the big test is whether the small wire to the starter solenoid is dead when a foot is pressing the Brake or clutch pedal when the Ignition key is in the STARTER position.
So either your Ignition switch is bad at the STARTER terminal position or the signal is interrupted by the anti-lurch Interlock switch. It is quite common for problems with this switch being hit and broken or displaced by the Drivers' feet.
There was also no indication of whether you jumped the solenoid on a warm engine which could atomize the fuel by compression or a very cold engine which needed the glow plugs to work.
Please comment on my info and report your success.
Mar 27, 2013 | Ford Cars & Trucks
Explorer (93 xlt)wont start
Alternator just charges your battery and wont have any direct link to a starter problem. It is very important that starter wires be very snug when replacing the starter. especially the big wires. However it is the little wire that activates the main relay. I don't remember if this car has a remote solenoid or not.
If it has a remote solenoid then the main positive wire from the battery will go to the solenoid mounted on the fire wall or fender and then one big wire will go down to the starter. The start solenoid will have the battery wires hooked to it but also a little wire from the ignition switch. If you dont hear a click then either the ignition switch is bad or the solenoid is bad. Or perhaps the contact from the ignition at the solenoid is bad.
Apr 21, 2010 | 1998 Ford Explorer
96 ford explorer wont start. all power when turn key. nothing.
if it turns over from below,then its in the ignition switch and this also feeds power to the e.c.m. to make the engine fire so you either have a bad switch contact or the hot 12 volt wire to the ignition switch
Mar 20, 2010 | 1996 Ford Explorer
1995 Winstar will not turn over
try changing the solenoid it sould either be on the fire wall or on the starter itself
Jan 19, 2009 | 1995 Ford Windstar
2006 BUSINESS CLASS M2 Logo
299 people viewed this question
Top Freightliner Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Freightliner Vehicle Part and Accessory Expert? Answer questions, earn points and help others
