Hotpoint WMA54 motor removal to replace brushes
  • 108 Answers
SOURCE: hotpoint aquarius wma50
You should be able to do both without disturbing the motor.
To do the brushes - about half an hour...
1. UNPLUG the washer.
2. check you've unplugged.
3. Tip the machine carefully up so you can get to the underside
4. Pull cables off the existing brushes.
5. Remove the brushes with a cross head screwdriver. Each brush as two screws holding in on, but the brushes are keyed into the motor chassis. They are fiddly.
To do the belt. + as long as your patience lasts...
3. Open the top of the machine - see the sides of the lid about 10 cm from front, remove plastic cap on each torx head, undo torx. (torx set required)
4. Remove concrete block from top - large spanner is required - remember the sequence so you can replace later.
5. Lean over the drum and see the large drive wheel. To pop the belt off, turn the wheel forcing the belt to the edge of the wheel. It will eventually come off.
6. to replace belt - see motor shaft at bottom of unit. Dangle belt round shaft of motor and gently pull so it does not come off.(This is not easy!)
7. At the same time Ease one side of the new belt back on to drive wheel on the back of the drum.
8. Turn Drive wheel until belt is on.(This is not easy and requires alot of hand strength)
9. Replace concrete block with bolt and spanner in reverse sequence you removed it.
10. replace lid, torx and cover for torx.
Posted on Mar 13, 2008
early1234
  • 871 Answers
SOURCE: Hotpoint Aquarius 1100 WD61P (analogue) washer dryer, sparking motor (and stopping)
you seem to know what your doing. yes you do have to remove the motor in order to remove those carbon brushes, while your at it, you can also adjust the screwing/bearings of the bolts to hinder the machine from moving a lot.
Posted on Mar 17, 2008
barkencoa
  • 3463 Answers
The motor does not have provision for belt adjostment, it is self tensioning
To gain access to the brushes, you need to remove the motor from the washer.
Remove rear panel, remove belt, unplug motor lead, taking note which way the plug goes,undo screws securing motor, and lever motor back with a screw driver, remove motor and change brushes.
Posted on Feb 12, 2009
amgm
  • 32 Answers
SOURCE: Hotpoint Aquarius WMA54 very noisy during spin
Hi, if your H/P is noisy on the spin cycle, just open the door and turn the drum a few times. If you feel some play, or kind of loud huming noise, then it is the bearings, very, very common on H/P WMA's.
  • 82 Answers
SOURCE: I need to replace brushes on a hotpoint aquarius wm32
pull machine out and make sure u remover the plug completley it is still live with the plug in and switched off throught the netural feed
at the back take off the botom white pannel made of plastic look in side pull the belt off the moter
there should be 2 10mm bolts remove these and tap the moter and it should slide out
remove the earth wire and the moter harness plug and pull the moter out it will go you might have to turn it this way and that once out there is two screws holding each brush remove and put in the new breushes replace the moter
to put the belt on there is two screws on the lid one each side behind a oval blanking cover these are hex head screws
once off put the belt on the moter pully first then on the drum pully and gide it on by hand turn the drum and the belt will spring on open the door and spin the drum by hand to make sure the belt is on correctley replace lid and back turn on power an try if this does not work the moter has gone try ebay i did for my hotpoint cheaper than trade on there
Posted on Jun 28, 2009
My brushes on my aquarius wma54 need replacing,where is the motor and how do i change the brushes.what type of motor is it
The motor is located at the bottom rear of the washer.
Remove lower rear panel, unplug lead into motor,, remove earth wire.
Remove 2 bolts holding motor to drum, lever motor away from you to remove.
Brushes are located at the end furthest away from the pulley.
There has been more than 1 type of motor fitted to this model, so until you remove the motor, you will not know which brushes you need.
Nov 09, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
What has caused the short circuit on the circuit board by the programme dial?
Could be a problem with the motor that has caused it, usually caused by the brushes wearing down and short circuiting the armature, causing the board to blow, you need to check the brushes before doing anything else.
Oct 21, 2010 | Hotpoint WMA54 Front Load Washer
What do the brushes on the motor look like?
They are carbon brushes.there is 2 of them,the brush itself looks like lead like in a pencil,they rub on the motor as it spins providing electricity to the motor.they are spring loaded to push onto the motor.most brushes are external & you can see them but others are incased inside the motor.brushes are allways at one end of the motor with a single wire plugging on to it.
Jun 03, 2010 | Hotpoint WMA54 Front Load Washer
Drum is not turning
Could be the brushes, only way to prove it is to remove the motor and check the brushes for wear.
If they are less than 3 or 4 mm long, then they need replacing. If brushes are o/k, then it is probably a control board fault.
How to change the belt on a hotpoint wma54 washing machine
there is a rear access panel in the center of the back,remove this cover and put the new belt on the motor pulley,then over the larger drum pulley,it takes some strength unless you release the motor tensioner and retighten after the belt is on
Mar 23, 2010 | Hotpoint WMA54 Front Load Washer
My machine hotpoint WMA54 takes the water but the drum does not turn, what could be the problem? thanks
Could be motor brushes in need of replacement.
To check them, remove lower rear cover of washer.
Unplug motor and remove earth wire, remove drive belt.
Undo 2 screws securing motor to drum, and lever motor off
the mounts
Replace brushes if less than 3 or 4 mm long.
If brushes o/k, then could be control board problem.
Check all connections between module and motor.
Please rate my solutioin.
Thankyou..
Feb 01, 2010 | Hotpoint WMA54 Front Load Washer
Clothes still too wet after complete cycle
I would suggest that the filter wants cleaning.
To access it, remover lower rear panel of washer.
Locate and remove the large black hose on to the tub.
Be careful, as there will be water in the hose.
Remove and clean plastic filter inside hose.
Refit hose and filter..
I would also suggest that you remove motor and check the brushes for wear, whilst you have the rear panel off.
If there is less than 10mm showing, then they need replacing..
Please leave a rating for my fixya solution.
Thanks.
Feb 07, 2009 | Hotpoint WMA54 Front Load Washer
Nov 13, 2008 | Hotpoint WMA54 Front Load Washer
Brushs
no they dont make a noise when they are new in correct fitting of the brushes cause this.. on certain motors the brushes can be fit onto it in two ways.. check to see if you motor has more than one position method
Aug 20, 2008 | Hotpoint WMA54 Front Load Washer
HOW DO I GET TO THE MOTOR TO REPLACE BUSHES ON HOTPOINT WMA54
from the back underneath
What to do is remove the rear panel at the back get a a 13 mm socket and undue the motor and discconect the motor wiring plug and earth wire pull out the motor and undue the brushes using a pozi screw drive and replace..
however once you put the motor back in you will have to undue the top to get the belt back on//
if you need anymore help then give us a shout.
Jan 04, 2008 | Hotpoint WMA54 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
