Question about Poulan Garden
Replace fuel line poulin 35cc what size and how much hose
2 Suggested Answers
  • 16 Answers
SOURCE: fuel line replacement
I recommend remove all fuel from the tank. Remove the hose from tank to carb. take the tube with you, when getting new hose.
Posted on Jan 19, 2009
How to replace gas lines on 1994 honda night hawk
remove fuel tank , see where the lines route on the carbs and take a few pictures so you cant go wrong ! replace lines only with fuel resistant hose cut hose to same sizes !
Dec 07, 2013 | Honda Motorcycles
Won't start and appears to be leaking gas.
Replace connecting fuel line hose from tank to carberator or replace or repair fuel tank. Your do not start because too much air is getting into the fuel system. Seak a professional.
Nov 14, 2013 | McCulloch Quality Mcc1435a 14" Gas 35cc 2...
Poulin pro chain will not get gas to engine all parts are clean and it has gas
Possible plastic hose running from fuel tank to primer or from fuel tank to carb is broken or cracked. Remove cover to access the carb and inspect hoses for cracks or being broken. Also inside fuel tank the hoses can break off and not be notice from the outside. The hoses can be replaced but not easily. Small engine parts store should have fuel hose.
Nov 26, 2010 | Poulan Pro Chain Saw 46cc 20"
Homelite 10540 chainsaw 35CC chainsaw won't start when hot
Go to: http://www.drystacked com for a 12 page article on Walbro carburetor theory and troubleshooting. Check particularly, the position of the gasket in the lower chamber. Check the spark plug for blue, snappy spark when the engine is hot. If ok, place a small amount of fuel mix in the cylinder and try for start. If it pops several times, look to the fuel system. Check the fuel filter, air filter, and muffler for plugging. Does the primer bulb fill with fuel after several pumps? Check the fuel lines for decay or other damage. When the engine is hot, try not using the choke, but set the fast idle. Hope some of this helps!
Jul 13, 2010 | Homelite Garden
Rubber fuel hose off the filler line what size is it
all rubber fuel line are the same size. if you need to replace it, measure the length and ask the counter person at the auto parts place for fuel line and give them the length. they should give you the right size.
May 14, 2010 | 2005 Chrysler 300
When fueling with saw on side, fuel runs out the clear plastic hose that pushes into top of fuel tank
I suspect that this is a replacement fuel line. Husky uses rubber lines. Does the leak occur at the tank interface or does the line just hang free? If free, the end probably should go to the output side of the primer bulb. Replace this line with the correct sized rubber line. Most service shops carry various sized lines for nearly every saw. Hope this helps!
Apr 25, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Config of gas lined Mc Callogh chiansaw 3200
What little fuel system detail there is can be found here:
IPL (Chinese Mac, exploded parts list)
https://www.dixiesales.com/ipl/327/Chainsaws_32cc-35cc.pdf
Fuel Line Replacement
SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb, bulb returns excess to fuel tank. HTH
Lou
Oct 07, 2009 | Garden
How do you remove & replace the rubber hoses that run from the gas tank to the metal fuel lines? The hose goes between the frame and body of the car I can not pull or push them out, so how are you...
Step 1-Determine type of fuel line to be replaced. Rubber hoses will have clamps on both ends that should be loosened with screw driver. Nylon and steel lines will have a ferrule at both ends removed and replaced using proper size line wrench
Step 2-Using proper size line wrench or screwdriver, loosen fittings by turning counter clockwise. Catch fuel remaining in lines in a gasoline safe container.
Step 3-Remove defective fuel line and install the new line or hose opposite of removing. Take care not to strip or cross-thread fittings as this will cause leaks.
Step 4-Dispose of remaining fuel in an OSHA safe container.
hope it helps-
Aug 17, 2009 | 1995 Jeep Wrangler
Fuel line replacement
Oct 09, 2008 | Husqvarna Garden
Garden Logo
26 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
