Question about Nintendo Wii Fit for Wii
Four blue flashing lights
Not allowing to even press butto A
    New Friend:
    Problem Solver:
  • 11 Answers
Have you synched it, i personally have never used the balance board, but there should be a sync button. At the bottom, push this while your wii or wii u is on.
Posted on May 30, 2014
4 ways are on and can not get them off?
The 2003 Softail TSM/TSSM's turn signal feature provides for Automatic cancellation; Manual cancellation; Four-way flashing and Diagnostics mode.
Turn signals can only be activated or deactivated with the ignition key in the "IGN" position, not the "ACC" position.
If you press the left or right turn switch the signal will activate both the turn signal operation/illumination and the automatic cancellation function. If you press the button a second time the signal will cancel. Also if you have one signal on and you press the opposite signal switch button the first set signal will cancel and the second pressed side will operate. However if you do not press the signal switch button the second time the signal will remain on and will not cancel while you are approaching the turn but will only automatically cancel after the TSM/TSSM senses that the turn has been completed because when the signal switch button is depressed the TSM/TSSM starts to count to twenty after which it will cancel the signal function if speed is not reduced below 7 MPH but as long as the speed of the motorcycle is above 7 MPH or is stopped the signals will not cancel until speed is resumed to above 8 MPH at which time the 20 count will resume and the signal will cancel after the end of the 20 count. The signals will also cancel within two seconds after the bank angle sensor in the TSM/TSSM senses more than a 45 degree lean of a turn action after which the motorcycle returns to a normal upright riding position. As well the TSM/TSSN will calibrate itself after it senses that he motorcycle has been ridden for one quarter of a mile or four tenths of a kilometer at steady speeds in an upright position. ON
The TSM/TSSM also flashes the signal simultaneously as four way flashers whenever the ignition is set "ON" , the security system is not activated and both signal switch buttons are simultaneously depressed. If you have to leave the motorcycle where it is with the four signal lights flashing they will continue to flash for two hours if while they are flashing you turn off the ignition switch and activate/arm the security system but if you turn the ignition switch is turned on, disarm/deactivate the security system and depress both signal light switch buttons simultaneously the four lights will cease to flash before the two hour period is up.
An auto arming feature that is not always active on domestic motorcycles but is user selectable on these models but that is always active on HDI models Auto-arming requires that the four-way flashers be activated within 30 seconds of key OFF or after the vehicle has been disarmed. This allows a vehicle to be left in a secured state with the four lights flashing until they are turned off as described above.
If the four way flashers are not turned of before the security system is disarmed/deactivated then the TSSM will stop four way flashing for one second and then per flash the lights one time to signal that the system has been disarmed/deactivated and then after one more second the four way flashing will resume.
When there is a burned out light bulb on one side of the motorcycle, the remaining light on that side and the turn signal indicator light on that side will flash at double the normal rate after the fifth flash so if that happens check your signal light bulbs.
As the TSM/TSSM also diagnoses for signal wiring short circuits and opens AND for stuck signal light switches if there is a stuck turn signal light switch the automatic turn signal cancellation feature will not work and the signal will continue to flash AND if there is a stuck turn signal switch the four way flashers will only be activated if both of the turn signal switch buttons are held in for more than one second so if the four way flashers are on when a signal switch becomes stuck you may have to hold them in for a longer period of time to cancel them also.
Otherwise if you are having turn signal or four way flasher problems you should check for TSM/TSSM trouble codes.
Jul 11, 2014 | 2003 Harley Davidson FLSTF Fat boy
My sony cmt-nex3 has the standby light flashing, but when i press the on butto, it doesn't turn on
Check the back for speaker wire shorts, next! there may be a short in the audio output chip or surrounding parts in the stereo, this is more suited for a technician to sort out.
Jul 03, 2012 | Sony CMT-NEZ3 Shelf System
When trying to pair my plantronics voyager 50 to my iphone, i am attempting to get the blue and red light to flash by pushing the up volume and the call button. but no flashes occur, even after 60 seconds...
  1. Turn on Bluetooth within your phone. Put phone into pairing mode.Put headset into pairing mode - With headset on, press and hold call button and the volume up simultaneously until the headset begins to flash red and blue.
  2. Pick the headset for Plantronics when prompted. Enter "0000" (four zeros)
  3. you should now have a continuous blue light blinking.
  4. Choose "Yes" if your phones asks if you want to bond to the Voyager 510 bluetooth headset.
Good luck from Headsets Direct - 800-914-7996.
Aug 13, 2011 | Plantronics 510 Voyager Headset - PLN-510...
We forgot our password to the router and we need to take the password off how would I do that?
Hi janiemae97,
This is how to reset your Belkin Wireless Router:
1.) Press and hold the 'Reset' butto for at least 10 seconds (It's located at the back righ beside power adapter port) then release it.
2.) The lights on the Router will momentarily flash.
3.) The 'Power/Ready' light will begin to blink.
4.) When the 'Power/Ready' light becomes solid again, the restore is complete.
Additionally, you can download the manual of your router HERE.
Hope this helps. Thanks
Feb 22, 2011 | Belkin (F5D8231-4) Wireless Router...
I cant pair my jabra bluetooth to my evo!
First, put the headset into pairing mode. To do this, remove it from the Stone charger and press and hold the answer/end button until the lights flash four times slowly - this indicates that the unit is off. Then, press and hold the answer/end button again - you'll soon start to see lights flash - hold the button until the green light is on steady and the blue light is flashing. This is pairing mode. Now your Evo should be able to "find" the Stone to pair with it from within the Bluetooth menu on the phone.
Jan 20, 2011 | Jabra Stone Bluetooth Headset
I bought a new key fob for my audiovox aps 686 and have no clue how to program it. I looked at unit under the dash have found no buttons to reprogram it. Anybody know?
Did the unit have anything plugged into the blue two pin port? If so, trace that wire (black & gray) to the programming switch. Once you have located the switch, turn key on, press and release the button three times. The parking lights will flash once. Press the lock button on the new remote. Press and release the programming button once (two flashes), press unlock button. Press and release probramming button once( three flashes), press remote start button. Press and release programming button once (four flashes), press option button. Turn key off. test system.
Nov 30, 2010 | Prestige Remote Start
New crown compatible wii fitness board will not sync with wii console. board only blinks a few times then switches off
Have new crown compatible fitness board, new batteries inserted, inserted Wii fitness disc, choose training, then trial, choose hula hoop game, used remote press A to start.
Screen says place me on a flat floor and press POWER button before stepping onto me
Followed the instructions power button flashes blue, as do the four corners then the lights go out - then nothing happening, still have the same message place flat on floor etc....
Have also tried the Wii Balance Board Check - followed all instructions last one says please turn on power. Pressed button flashes blue as do four corners then they go out
Am I doing something wrong or Is this a faulty board ?
Thanks
Sep 27, 2010 | Video Game Consoles & Games
One of our TV's was being accessed by someone in the neiborhood. I found in the manual how to change the remote code. After doing this the TV is locked on one channel. I did reboot. The remote is working...
Hi! I will be more than glad to assist you in this concern. Lets Isolate the problem, press 1st the sat button once on the remote that is giving you a problem. the sat button should light up and check if you could pull up the guide or can change the channels. if there is still no response, bring with you the remote conrtol that is giving you a problem on tv1, turn on the tv and it should show a picture, go to the fron tpanel of the receiver and press the power button once to turn off the green light, once its off, the tv will go into a black or snowy screen, press the up button on the front panel of the receiver until it shows the system information. look for the primary and secondary remote address, ex, primary remote address is 1 on the white box and 1 on the green box, secondary remote address is 2 on the white box and 2 on the blue box, how to reprogram the remote, press and hold the sat button on the remote that is giving you a problem and wait until all lights lit up, once it lit up release it and press any number from 1 to 15, but lets choose 9, then press the pound button (#) that is under number 9, once you press pound button, the sat button should flash 3 times, then after it flash, press the record button, that is under the cancel or view tv button., you will notice that the secondary remote address was change from 2 to 9. to save the setting, get the remote1, select done on the screen and it will show a black or snowy screen. to check the remote 2 if it works, press the sat button once and the the big red power butto, the blue light should turn on if there is no blue light but there is, the blue light will turn off, then before you go to the tv2 location make sure that blue light is on and then check on the tv2 location if you could change the channels now. just incase that the problem is still there, check the remote antena on the back of the receiver, make sure that its on the upright position to broadcast the uhf signal properly.. that should fix the problem. if just incase the problem still exist, call 1800-333-3474 ask for a replacement of the remote..pls feel free to get in touch..if you have any query
Jul 04, 2009 | DISH Network 322 DTV Receiver
Need passkey to connect my tb20el bluetooth to my phone
for tb-20el:
1. ensure that your phone's bluetooth feature is on
2.Ensure that the headset is off(press and hold button on your headset (called multifuntcion button) for 2-4 sec, teh indicator light will flash red)
3. press and hold the multifunction button for 6-8 seconds until the indicator light alternately flashes blue and red
4. set your phone to find new device
5. Ente rpin '0000' (four zero) then press OK or yes
6. this should complete the pairing.
Apr 14, 2009 | Motorola Mobility H700 Wireless Headset
Error number 1700 canon s9000 printer
knowing printer manufacturers I doubt they even have a sensor to detect that its full at all, they probably based on something crumby like print count. here are some instructions to reset the waste ink tank, the instructions vary so try them until one does the job :
Waste Ink Tank Reset
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice, then release all buttons
5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
6: Press Power to set data
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
1. power off Printer
2. Push and hold resume button and push power button
3. Hold Power button and release Resume button
4. Push Resume button twice ( 2x ), and now release resume button and power button
5. Green light will blinking and stop.
6. When green light on, push resume button 4 x
7. Push Power button and printer will off, if that isn't off, push power butto again until print off position.
Aug 20, 2008 | Office Equipment & Supplies
Nintendo Wii Fit for Wii Logo
52 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
