Question about Mr. Coffee Classic 12-Cup Coffeemaker - Cocoa (MRX35)
Spring fell out of filter basket now will not stay in place
2 Suggested Answers
SOURCE: Need parts diagram of Mr. Coffee CG12 filter basket assembly
I found the missing vinyl washer.
Posted on Oct 03, 2009
Have a Mr Coffee model #BVMC-PSTX91. The filter basket has a spring loaded release that has fallen off - how do I put back on? cannot figure out how to put the spring and extra plastic piece on?
without seeing it (a picture) that is a difficult question to respond to. it may have possibly broken or a piece of plastic needed to keep it in place broke - or the spring is defective. suggest get a new basket. (or go to the store, or find a neighbor with a similar model - and look at his basket, take a pic of the spring mechanism with your cellphone and go home to fix your own.)
regards,
Jan 27, 2017 | Coffee Makers & Espresso Machines
Overflow in basket
Steven, I think it`s not the filter or the coffee just that more water is flowing into the basket then it can process. I would try lesser quantity of water first to see if it overflows. Try first with filter only and then with coffee. And before you do all that, your machine should be under warranty and may be returnable to the store. Do that and save the trouble of fixing it.
Mar 22, 2014 | Black & Decker CM1050B
FCP-240,280,412 Farberware Percolator, 3 Prong Cord is too heavy for the percolator. It sometimes comes loose and we have cold coffee. Also the Spring on the Pump Tube does not stay in place. Any Help?
HI, on the plug, is it the part that pluges into the wall or the pot. By the model # you have 3 China pots. On the pump just below the coffee basket, take a pair of pliers and put the basket on the tube , now just make small crimp just below the basket,just enough to make it out of round., you will make it so the crimp will not let the spring or basket go by. If it is the plug going into the wall just bend the 2 flat outward so the plug fits snug. Good luck . Ron
Jun 20, 2010 | Coffee Makers & Espresso Machines
Overflows
The two most common reasons for overflow have to do with the caraffe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and caraffe lid are making the proper contact with each other so that the center knob on the caraffe lid pushes slightly up on the filter basket spring. Make sure the caraffe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the caraffe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the caraffe lid - call Cuisinart as they should be able to order these parts for you.
Sep 29, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
The cuisinart repeated;y clogs and sprays water
The two most common reasons for overflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Sep 07, 2009 | Cuisinart DCC-1200 Coffee Maker
My coffee maker, Cuisinart dcc 1400 only boils water, does not make coffee. It is one week old. I have a water filter in the plastic filter holder filled with coffee.
The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Aug 10, 2009 | Cuisinart Coffee Makers & Espresso...
Door spring came off filter basket door on Krups FME4 coffee mak
yhere should be a little post th spring goes on in the vack of the basket ...out in pkace hold untill in place
Dec 10, 2008 | Krups FME4 Coffee Maker
Mr. Coffee Classic 12-Cup Coffeemaker - Cocoa (MRX35) Logo
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Henry  Thomas
Henry Thomas
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
