Question about Raymarine Boating
Fuses x5 wheel pilot
    Sergeant:
  • 415 Answers
Make sure that the fuse is not blown by checking with an ohm meter. The circuit that the wheel pilot is on may also have a breaker. Make sure that the breaker is not tripped.
If the unit keeps tripping the breaker or blowing the fuses, then the motor is going bad, or at least needs some maintenance.
Posted on May 19, 2014
Bmw x5 2008 - fuse box diagram
A 2008 BMW X5 has 2 different possibilities as thas it a split year. It can have 2 different fuse box setup based on if the vehicle was made before or after 11-2008. You can look on the driver or passenger door jamb for a factory production sticker with the exact production date. ALso a power distribution box should exist under the hood. Here is images of the passenger compartment fuse box and each fuse for both options that year.
Feb 28, 2016 | 2008 BMW X5 3.0D
HOW TO GET TO FUSE BOX UNDER GLOVE BOX ON 2003 BMW X5
  • You have to open the glove box and turn the two finger switches 1/4 turn.
    If the blower isn't working its probably not the fuse anyway. The part you need to replace is the fan speed resistor.
Aug 12, 2014 | 2003 BMW X5
Bmw x5 key won't turn
IF THE KEY NOT TURNING IN IGNITION,THAT COULD BE WORN KEY,OR WORN THUMBLERS IN IGNITION LOCK. ALWAYS PULL OUT THE IGN.KEY W/WHEELS IN STRAIGHT AHEAD POSITION.(STEERING WHEEL IN 0 POZITION). THIS WAY THE STWHEEL LOCK IT IS NOT UNDER LOAD. IF NOT WORKING,DEALER ITEM IGNITION LOCK. GOOD LUCK
Apr 04, 2014 | 2003 BMW X5
2003 bmw x5 climate control doesn't have power: what would cause this?
No power to something, no matter what, normally means a blown fuse. Check the fuse to it. The fuse panel cover has the diagram on the under side of it or would be in the operator/repair manual.
Apr 14, 2013 | 2003 BMW X5
Pair iPhone 4s with 2006 BMW x5
Key-in, Ignition On (but don't need to start the engine)Press the R/T button on the steering wheel. "Activate Phone" should display on the radio. On the iPhone search the BT device. Select your car and enter the passkey when prompt on the iphone. Make sure there is no other BT phone near-by or the old one that has paired with the car previously. There is also the maximum number of devices you can have in the BMW BT sharing. If you reach the max, you may have to clear the car BT pairing memory by removing the power to the BT unit (by removing a fuse in the rear fuse box). The info is in the manual and inside the fuse box (which tell you which fuse is for the BT.)
Feb 06, 2013 | BMW X Series & X5 1997 >2006
Which means the code of a bmw x5 2774
p2774 means Four Wheel Drive (4WD) Low Switch Circuit High
Dec 01, 2011 | 2005 BMW X5
Rear wheels appear bent on my x5
Just needs a 4 wheel alignment. Probably needs a few suspension parts as well. A good Indy shop is the place to go.
Oct 30, 2011 | BMW X Series & X5 1997 >2006
X5 dead satnav/radio display
I had the same problem with the suspension on an o2 X5 Sport,it was the stabiliser pump in the rear,Range rover is the same pump and is cheaper than the BMW part,they also do an exchange unit.
Jun 24, 2008 | 2005 BMW X5
Dell AXIM X5 Palm Pilot
Don't know if you still need it..., but you can find several manuals and a 'getting started guide' here
Jan 31, 2008 | Dell Axim X5 Pocket PC
Boating Logo
98 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
merc racing
Level 1 Expert
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
