Question about Olde Thompson PW-500
Thread bobbin thompson pwz-500
Bobbin needs to be threaded
  • Olde Thompson Master
  • 7,365 Answers
I need to wind thread the bobbin for a husqvarna viking 500 computer sewing machine
Download your manual here: http://www.pdfsdocuments.com/husqvarna-viking-500-computer-sewing-machine-manual.pdf
Feb 02, 2016 | Husqvarna Sewing Machines
White fr 500 will not take up bobbin thread
It usually happens when the needle is bent or threaded incorrectly. If ok then the hook must be missing the thread loop, check timing.
Feb 18, 2014 | White Sewing Sewing Machines
The thread is birdnestting where the bobbin is
Birdnesting can be corrected by adjusting the bobbin tension lower. You need to check for threads stuck in the bobbin tension and clean them out. The thread should feed out of the bobbin tension with a small amount of tension. Make sure your bobbin is rotating the right direction; probably counter clockwise. Adjust the top to three and give it a try. You may need to make a small adjustment on the top tension. Your goal is to have the bottom and top tension equal just like a tug of war.
Jan 22, 2014 | Brother PE-500 Embroidery Machine
Thread is gathering under cloth
Check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out.
May 05, 2011 | Olde Thompson PWZ500
I just purchased a singer cg-550/500 and after threading the machine and inserting the filled bobbin, I was unable to bring up the bobbin thread with the needle. I followed the instructions carefully but...
if im not mistaken, the bobbin when you place it in the bottom, you have to thread it is as well to the part where the needle comes down and collects and goes back up. please re-look at instructions for placement of bobbin
Mar 05, 2011 | Singer Sewing Machines
Have a CG 500......the stitches pucker.. I have adjusted .the tension..but the only way to prevent this is to put the tension on 0............then this does not make good stitch.HELP
Try rethreading the top thread thru the tensioner. Make sure the presser foot is in the up position during threading, and as you go thru the tensioner you may need to pull the thread back and forth lightly to help it settle in the tension discs.
Also check the type of bobbin being used. Drop in bobbin machines need bobbins with rounded sides (class 66).
Feb 18, 2011 | Singer CG550 Mechanical Sewing Machine
I was sewing an overlock stitch and it just stopped pulling the bobbin thread through. I think the timing got messed up. I have switched needles and that didn't fix the problem. How can I fix the timing...
A suggestion to try:
Remove all the thread from the machine.
Check for and clean out any thread pieces, lint, etc. in the bobbin area.
ALWAYS RAISE the presser foot and rethread the top thread--verify the thread path is correct.
Rethread and install the bobbin in the machine.
Retest the machine.
Feb 13, 2018 | Singer Curvy 8770 Electronic Sewing...
We have a Thompson PW-301. I find the instruction manual very had to understand in some instances. I finally got it threaded, but the tension part I had trouble with. Once I figured that out, now it seems...
Here's some things for you to try.
* Re-thread your machine, it may be threaded incorrectly.
* Raise your feed dogs if your machine has this feature.
* When you start to sew a seam, hold on to the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting hung up in your machine.
I hope this help you.
Sep 22, 2009 | Sewing Machines
Excess bobbin thread under the fabric
I know you hate to hear this but you are probably threading it incorrectly. Make sure that the presser foot is in the up position when you thread the machine. This ensures that the tension discs are open and the thread makes it in between the disc.
Feb 27, 2009 | Sewing Machines
Sewing Machines Logo
143 people viewed this question
Top Olde Thompson Sewing Machines Experts
Tally Girl
Tally Girl
Are you an Olde Thompson Sewing Machine Expert? Answer questions, earn points and help others
