Question about AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90
Testing a capacitor for a single phase motor
How to test a capacitor for a single capacitor start motor. Capacitor rated 20 micro farads
2 Suggested Answers
erpaalai
  • 999 Answers
SOURCE: wiring a 220v single phase motor and capacitor
Black and white are usually power. an ohmmeter will confirm. Brown are for capacitors. There is almost always a diagram on the motor someplace. Eric
Posted on Jun 17, 2009
Air compressor 2hp 230v 1ph motor. I need to know how to test a starting capacitor. Thanks
IF you don't have a special meter, that costs more than the capacitor, just replace it. The meter is called an ESR meter and they are $$
Aug 26, 2017 | Air Tools & Compressors
Tip
How to Reverse the Rotation of Single Phase Capacitor-Start Electric Motors
Reversing the rotation of electric motors can be done easily with 3-phase motors. This can be easily achieved by swapping the connection of any two motor leads. But 3-phase motors are usually found and used for industrial purposes. The ones found and used in our homes, from water pumps to electric fans, are single phase capacitor-start type motors. Unlike 3-phase motors, reversing the rotation of single phase electric motors is no easy task. Swapping any two motor leads will not result in the reversal of the motor rotation. Analysis of the motor windings and connections are necessary before any modification can be done to achieve the desired result. Let's take a 3-speed single phase capacitor-start electric motor with electrical diagram shown below as an example. Make sure the motor is disconnected from the power supply before attempting to follow this tip. This tip is intended only for individuals with electrical knowledge, necessary tools, and understand the risks associated with handling electrical equipments and devices.
The first step in the process is determining the start winding which is connected to the line (AC white) and to one side of the start capacitor. To accurately determine the start winding, disconnect all motor leads from the start capacitor and the speed switch for multi-speed motors and then setting your ohmmeter to the lowest scale (R x 1), measure the resistances between the AC white line and each of the motor leads connecting to the start capacitor. The one with the least resistance is the starting winding lead.
Once the start winding lead going to the capacitor is determined, reconnect the capacitor then connect the black AC line to the found start winding lead (marked X). Connect the white AC line to L of speed switch, the motor lead formerly connected to AC white to 3, red to 2, and white to 1 as shown below. Leave the green/yellow ground wire connection as is.
Below are the wiring modifications for 2-speed and single speed single phase capacitor-start electric motors.
on Jan 11, 2011 | Dryers
I have a 166-0138 capacitor which is obsolete what can I replace it with
166-0138 is a fasco motor number not a capacitor. if you need a capacitor they are typical items that are rated in voltage and micro farads. you can replace the capacitor with one of the same rating from a hvac supply house.
Mar 17, 2016 | Dayton Permanent Split Capacitor Motor Fan
Replace compacitor on Carrier 5 ton 3 phase AC
Your 3 phase unit should not have a capacitor. I'm guessing it's single phase. If it's a single capacitor than the compressor should not be going to it also. To test the motor, common to start plus common to run should equal the ohms you get between start and run. For instance, 1.2 ohms+ 2.2 ohms= 3.4 ohms. Follow the wiring diagram on the inside of the door, send model number!!
Aug 29, 2017 | Carrier Heating & Cooling
On a call for cooling from either indoor thermostat, the respective indoor unit operates properly and the outdoor fan starts but the compressor does not. A click is heard as if the compressor is trying to...
Could be your capacitor in the outside unit. If you have the right tools and are experienced working with high voltages then you can test to see if that is the problem.
***CAUTION***
Anytime you are working on or around electricity you run the risk of shock and or death. If you are not competent working with high voltage and using electrical test equipment, please consider consulting an expert before you open an electrical panel or appliance. You assume any and all liability by continuing with this diagnoses process.
***WARNING***
Capacitors hold a large electrical charge even after power has been removed from them and will discharge upon contact with your skin. This is enough to stop your heart and cause death. If you are not confident in your abilities to work with these devices then please leave any testing or repairs to a professional.
The capacitor is inside the outside unit and you have to remove the cover to see the inside of the electrical compartment. You will need to discharge the capacitor before you start working around it. To do this take a screwdriver or other long metal tool with an insulated handle and cross the three terminals on the capacitor to ground. You then remove the wires to the capacitor terminals, taking note of which wire goes to which terminal.
Capacitors are rated in Micro Farads (marked by a µF symbol) and a dual capacitor, shown in the image below, will have two ratings listed like this "35/5µF" or something very similar. You must have a multimeter that reads micro farads " µF " to check a capacitor.
You do that by placing one probe on the C or COM terminal and the other probe on the FAN terminal and it should read the small number of the rating, for example if your capacitor is rated like this: 30/7.5µF then the fan rating will be the smaller of the two numbers. In this case the 7.5µF (seven and a half Micro Farads). The HERM terminal is the one for the compressor and will be rated the higher of the two numbers, I.E. the 30µF on the capacitor. Check them both and of they are more than 6% lower than they are supposed to be then the capacitor is weak and needs replaced. If you read 0 (zero) then the capacitor is bad and needs replaced.
shamoke_15.jpg Full sized image
Jun 25, 2011 | Mitsubishi MSZ-A15NA Split System Air...
My outside condensing unit fan will not move without a push with a stick. It will work for a while and then stop. could this be the relay?The brand is GE Industrial Motor Model # 5KCP39EGT974S and the unit...
You fan motor either needs a new capacitor or the motor is bad. Most of the time it will be the capacitor though and if you have the tools you can test it yourself.
*CAUTION* Capacitors hold a largeelectrical charge and will discharge upon contact with your skin. This isenough to stop your heart and cause death. If you are not confident of yourabilities around these devices then please leave any testing or repairs to aprofessional. The capacitor is inside the unitand you have to remove the cover to see the inside of the electricalcompartment. You will need to discharge the capacitor before you start workingaround it. To do this take a screwdriver or other long metal tool with aninsulated handle and cross the three terminals on the capacitor to ground. Youthen remove the wires to the capacitor terminals, taking note of which wiregoes to which terminal. Capacitors are rated in MicroFarads (marked by a µF symbol) and a dual capacitor, shown in the image, willhave two ratings listed like this "35/5µF" or something verysimilar. You must have a multimeter thatreads micro farads to check a capacitor. You do that by placing one probeon the C or COM terminal and the other probe on the FAN terminal and it shouldread the small number of the rating, for example if your capacitor is ratedlike this: 30/7.5µF then the fan rating will be the smaller of the two numbers.In this case the 7.5µF (seven and a halfMicro Farads). The HERM terminal is the one for the compressor and will berated the higher of the two numbers, I.E. the 30µF on the capacitor. Check themboth and of they are more than 6% lower than they are supposed to be then thecapacitor is weak and needs replaced. If you read 0 (zero) then the cap is badand needs replaced.shamoke.jpg
Jun 18, 2011 | GE Heating & Cooling
I have a busted 0.77mfd capacitor in my samsung microwave oven. there is only 1 capacitor available in town here in our place. its a 0.9mfd capacitor. is it ok to use this rating? if not, please help me...
If the 0.77 micro-farad cap has a tolerance of +/- 20%, then you're ok. But a tolerance of
+/- 10%, +/- 5%, or +/- 1% would exclude the 0.9 micro-farad capacitor as a replacement.
The tolerance colors that qualify are black and gray, see the capacitor color code reference at:
http://www.electronics-tutorials.ws/capacitor/cap_5.html
Mar 26, 2011 | Samsung Ovens
I would like to connect a pressure switch to the motor starter
hi! there, single phase compressor motor need a starting capacitor base on the rated capacity in horse power,you can check this on the tag of the compressor motor how many horsepower was indicated,it should be for single phase motor starting capacitor has a capacity of micro farads.for a 1 horsepower = 15 to 18 micro farads stating capacitor if you have more than 1 horsepower you can basically proportion the value of capacitor you need or ask the dealer how much capacitor you need on your motor the connection of pressure switch with a four terminal should be connected both on common line L1 and running capacitor line L2 .if you open the cover of pressure switch there are 4 terminals,2 terminals are connected when normally close or no pressure they connected on series connection on the common line one terminal connected to common line of the compressor and the other terminal on L1 to the pushbutton switch to L1 supply line.the 2 other terminals also connected in series withe line capacitors L2 to yhr power supply line.hope this will help you a lot.just rate my fix thanks a lot.
Apr 20, 2010 | Air Tools & Compressors
Blower motor doesn't start with capacitor installed!
you need a meter that will measure uf (micro farads) it should read within about 10% of the rating 12.5uf otherwise you could charge it with an insulation tester (megger) and short the terminals with an INSULATED screwdriver to see if it discharges.
Dec 21, 2009 | Goodman CKL24AR24 Air Conditioner
Dusty smoking smell, stops working, trips out power in house.
you forgot to say if it is a 3 phase machine
if it is 3 phase then a phase in the unit is overheating and that will stop the machine then blow the breaker as all phases have to draw equal current
if it is a single phase then the start/ run capacitor or centrifugal start run points are not breaking at speed and so the start windings are overheating and causing the breaker to trip
Take it to an electrical motor rewind shop and have it properly tested with test equipment
Oct 21, 2017 | Hoover F6212-900 / F6215-900 SteamVac...
AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90 Logo
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Colin Stickland
Colin Stickland
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
