Question about HP Photosmart 7510
Paper feed jam
Will not copy or scan. says I have to put the sheet to be copied all the way into the document feeder. I have nothing in the feeder. I am trying to copy by putting the document on the glass
maverick24
  • 56 Answers
SOURCE: Document feeder works for printing but not for scanning
Hi, When you had the doucment feed jam were you able to clean or remove any paper that might be blocking the paper to be scanned? It sounds like there is paper still in the document feeder , I would open the DF and check very closely to make sure no paper is in the way!Good Luck!
Posted on Dec 03, 2007
IB4G2008
  • 3587 Answers
SOURCE: "Scanner Failure" message
sure..new drivers might make this happier..
check your warranty here for FREE
Posted on Feb 23, 2008
  • 1894 Answers
SOURCE: Problem with scanning both from the auto feeder and from scanner glass
this is what HP has to say
This document applies to all HP product models. Issue When the product is turned on or in the middle of an operation, an unexpected noise occurs, such as clicking, thumping, or grinding. Blinking lights and error codes might accompany the noise. NOTE: Noises can be caused by a number of things. This document focuses on isolating, identifying, and resolving known causes of product noises. Solution Noises are subjective and can be difficult to describe. Some noises are normal to the operation of the product and might include the following:
  • The product might make humming and buzzing sounds as the carriage moves around on the right or left side of the product while cleaning the ink cartridges. This is normal when a product is turned on, before and after printing, after a product has been on standby for some time, after replacing an ink cartridge, or in the middle of a large print job.
  • During a print job, the movement of rollers, gears, carriage, and paper (paper feed and ejection) creates some noise.
  • During a print job, if the product is printing in the fast or draft mode, the noise level might be higher than when using the best or normal mode.
  • At the end of the print job, a louder clicking noise occurs as the paper is pushed to the output tray.
  • At the end of a print job, a noise emanates from the left or right side of the product as the pens are capped. The product might try to do this a couple of times.
Abnormal noises are a symptom of a problem. The most accurate way to determine the origin of a noise is to isolate where it comes from and when it occurs. Use the following steps to try to isolate the noise issue. NOTE: Error codes might indicate the source of the noise. Make a note of any error code or blinking lights that appear. Step one: Check for loose or broken parts
  1. Raise the cover of the product.
  1. Check inside for loose or broken parts.
  2. If there are broken parts, the product needs to be serviced.
  3. Step two: Make sure that accessories are installed correctly
  1. Press the power button (c00636182.gif ) to turn off the product.
  2. Remove the power cord from the back of the product and unplug the power cord from the power source.
  3. Check any accessories (duplexer, envelope feeder, automatic document feeder (ADF)) to make sure each is installed and seated correctly.
  4. Plug the power cord into the back of the product and plug the power cord back into the power source.
  5. Press the power button (c00636182.gif ) to turn on the product.
  6. If the noise still persists, remove each accessory one at a time to try to determine if the noise is associated with a single accessory or a combination.
  7. If the noise stops when a specific accessory is removed, that part might need to be replaced. If possible, exchange the accessory with a known good one or a new one to determine if the noise is associated with the accessory. NOTE: If the product is fully functional with the accessory in place, the noise might be normal.
  8. If the noise persists, proceed to the next step.
Step three: Check connection with computer Turn off the computer to determine if the computer is the source of the noise. If the noise persists, proceed to Step four. If the noise stops when the computer is turned off, try to isolate any issues with connectivity:
  2. Disconnect the USB cable from the product.
  3. Unplug the power cord from the wall outlet and from the back of the product.
  4. Wait a couple of minutes to allow static to be discharged.
  5. Plug the power cord into the wall outlet and plug the power cord into the back of the product.
  6. Connect the product to a different USB port.
  7. Turn on the computer.
  8. Press the power button (c00636182.gif ) to turn on the product.
  9. If the noise persists, service the product.
Step four: Check for a paper jam Paper jams can prevent the internal components of the product from moving, which can create unusual noises.
  2. Disconnect the power cord from the back of the product.
  3. Remove the rear access door.
  4. Remove any paper that is inside the product by pulling it out through the rear access door and then securely replace the rear access door.
    1. If a paper jam cannot be removed from the back of the product, raise the product cover, carefully remove the paper jam from the front of the product, and then lower the cover.
    NOTE: Remove any paper jam carefully as it is possible to damage the product when removing a jam from the front of the product.
    1. Reconnect the power cord to the back of the product.
    2. Reload the paper in the paper tray.
    3. Press the power button (c00636182.gif ) to turn on the product.
    4. Try to print. If a jam is cleared and the product prints, but the noise persists, proceed to the next step.
    5. Step five: Make sure that the carriage moves freely
    2. Disconnect the power cord from the product.
    1. Make sure that the ink cartridges are locked into the carriage and have not come loose. Also make sure that there are no obstructions under or around the carriage to prevent it from moving.
    2. Close the product cover and reconnect the power cord.
    4. If the noise persists, proceed to the next step.
    5. Step six: Plug the product into a wall outlet
    If the product is plugged into an uninterruptible power supply, that source might make a beeping or whistling noise.
    1. Unplug the power cord from any power strips or surge protectors.
    2. Plug the power cord directly into a wall outlet instead.
    3. Press the power button (c00636182.gif ) to turn on the product. If the noise persists, proceed to the next step. If the noise stops when plugged directly into a wall outlet, the power strip or surge protector might not be allowing sufficient voltage to reach the product and might need to be replaced.
    Step eight: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
    Comments by scrodamoon in premium
    Posted on Aug 05, 2008
    • 105 Answers
    SOURCE: document feeder appears broken in my HP officejet 7310
    I'm sure this will solve your issue.
    all the best.
    Posted on Oct 05, 2008
    • 72 Answers
    SOURCE: when trying to copy papers do not feed but if you scan they will
    HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam ISSUE: How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam SOLUTION:
    • Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
    2. Remove any jammed media with care.Take out the page gently. NOTE: Take care not to tear the paper. c01075162.gif
    3. Close the ADF cover plate.
    • Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
    1. Open the ADF cover plate. NOTE: Check whether all packaging straps inside the ADF are removed. c01075163.gif
    2. Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside. c01075164.gif
    3. Lift the green handle, and rotate the paper picker until it is opened. c01075165.gif
    4. Gently remove the page without tearing it.If you feel resistance, go to the next step. c01075166.gif
    5. Open the ADF cover plate, and loosen the media gently with both hands. c01075167.gif
    6. When the media are stopped, pull the media out gently along the shown direction. c01075168.gif
    7. Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055). c01075169.gif
    9. Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur. c01075171.gif
    Have a good day
    Posted on Jun 22, 2009
    Horizontal line on printed page
    When you use the flatbed the copy is perfect because the ccd sensor is under the glass cover and obviously is free form dust/ dirt.
    On the other hand if you use the feeder the ccd sensor is located in between the roller assembly (not sure exactly for this model).
    This means that the page is scanned by the ccd in the feeder, any dirt on the ccd will appear as a black line. I assume that you are feeding papers from the side and not from the top that is why you get a horizontal line.
    A quick test to see if the ccd sensor is dirty is to feed the paper from the top side to the feeder. If you get a vertical line it is a proof that your ccd sensor needs to be cleaned.
    The worst case is that the sensor in the feeder assembly has a tiny spot that is damaged and it is causing the black line.
    So , first try the test, then open the feeder assembly, locate the ccd and clean it. Hope that this helps.
    Aug 31, 2016 | Samsung Xpress SL-M2675FN Laser...
    Can't work out how to use the multiscan? I press scan and it comes up with multiscan and I put the first piece of paper in but don't seem to get asked for any more sheets and it therefore just scans one...
    Anita,
    Put the pages in the "multiscan" all at once, not just one sheet at a time. The Automatic Document Feeder (ADF) will feed one sheet of your document at a time untill all of the pages are scanned...
    Thanks for using FixYa!
    Oct 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
    The copy paper feed misaligns and jams, what's the fix? Jack
    to fix misalign and paper jam problem, follow this steps.
    Load one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.
    NOTE: If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water.
    If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually.
    Follow the steps below to clean the rollers or separator pad.
    1.Lift the cover of the automatic document feeder. This allows access to the rollers and the separator pad.
    2.Lightly dampen a clean, lint-free cloth with distilled water, then squeeze any excess liquid from the cloth.
    3.Use the damp cloth to wipe any residue off of the rollers or the separator pad.
    4.Close the cover of the automatic document feeder.
    This should solve the problem. Cheers!
    Apr 25, 2009 | HP Officejet 6310 All-In-One InkJet...
    Document Feeder won't work
    hello! check and look to see if there is anything blocking the paper feed area, if all is good, get some denatured alcahol and clean the paper feed roller as it may have a build up of paper dust good luck brother sr tech
    Jan 14, 2009 | Brother MFC-8460N All-In-One Printer
    Ricoh C21SF Automatic Document Feeder (ADF)
    Take a little soap and a little water and clean the gray feed tire that is located in the document feeder. Check for any paper obstructions. If the machine has had a lot of prints I would replace the feed tire.
    http://www.websitetoolbox.com/mb/copierquestions
    Sep 25, 2008 | Ricoh Aficio SP-C210SF Printer
    Vertical paper feeder for the copier not grabbing next original sheet
    I'm having a similiar problem. Can't consistantly feed one sheet at time. If i load several sheets it pulls all through, etc
    Sep 03, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
    Jams but only w/sheet feeder
    Theres is a spring clutch in the adf that goes out. Once that is fixed it should work just fine.
    Aug 13, 2008 | Sharp AR-507 Copier
    Can not copy from tray/drawer, but get copy from multi-bypass tray
    Regular copy paper that I got from the Staples. Same paper in the paper tray/drawer as in the multi-bypass tray. Thanks.
    Jun 25, 2008 | Sharp AL 1631 Copier
    Coping from Canon MP610
    Unfortunately this model does not have document feeder on top. So you can only do it one sheet at a time. I think the 31ppm indicates that you can print 31 copies of one document in one minute. The models above this tend to have document feeders for this purpose but not the mp610.
    Good luck.
    Please rate my advice, good or bad.
    Feb 01, 2008 | Canon MP610 Photo All-In-One Printer
    HP Photosmart 7510 Logo
    20 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
