Question about Life Fitness X3 Elliptical Cross-Trainer with Advanced Console
I have a Life Fitness X3.
When I increase the level to level 2, the system resets. How do I fix this problem?
vpaaf
  • 115 Answers
SOURCE: 9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
Posted on May 01, 2009
bwinton
  • 83 Answers
SOURCE: life fitness treadmill display: transistor error-won't run
This error shows up if motor controller detects a failed part. This isn’t a reset-able error. Treadmill will not allow workouts until serviced.
Solution
Main motor wires/leads could be disconnected at the start of a workout. If the motor is properly connected and in working condition then the drive transistor could have failed. Check Motor Controller.
Posted on May 07, 2010
maxtreadmill
  • 832 Answers
SOURCE: life fitness 95ti belt moving to one side any way of correcting
If the walking belt has shifted to the left, use the Allen wrench to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left rear roller bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centred.
Posted on Jun 14, 2010
jyackle5
  • 8197 Answers
SOURCE: I can't increase the incline
You can get the manual on the link below to see how to increase the incline.
http://www.lifefitness.com/static/cms_workspace/manuals/F3AssemblyInstructions_12-15-06.pdf
Good Luck
Posted on Dec 05, 2010
knight_nemes
  • 11 Answers
SOURCE: Life Fitness 9100HR Treadmill won't start
Typically a non start up of any electrical Exercise equipment raises alot of red flags If this treadmill will not start Check the internal fuse MAKE SURE ITS NOT PLUGGED IN!!!! UNPLUG IT FROM THE WALL
2 If there is NO Fuse and you just bought it new Return it for an exchange.
3 Check your wall outlet for less then 5 Bucks you can buy a wall outlet tester that tells you if your Outlet is good Or Bad.4 DO NOT Attempt to service this item on your own the way they make treadmills you have to have a qualified service tech come out and fix it because the risk of serious shock or death is emminent.
Posted on May 04, 2012
The bike is locked. It's not working
could be the drive belt could be jammed either torn or other.
Aug 21, 2014 | Life Fitness X3 Elliptical Cross-Trainer...
Life fitness elliptical X3
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
The following link will take you to the information we have for the X3 by LifeFitness. Please have your serial number available.
Repair Parts for X3 Crosstrainer by LifeFitness SPORTSMITH net
Oct 23, 2013 | Exercise & Fitness
Life Fitness X3 does not turn on. So I can't set resistance nor intervals with console. Plug was checked and is fine.
follow this steps and fix it.
God bless you
  • Check power problems if the console on the elliptical machine does not light up. Make sure that the plug for the machine is secure in the outlet. If it is plugged in, ensure that the outlet is receiving power. Check the breaker to make sure it has not tripped off.
    Be sure that you are using the correct adapter that came with the elliptical machine. Because different adapters are able to handle differing amounts of energy, the wrong adapter will not transfer electricity like it should. If the adapter is pinched or damaged, this could also alter its effectiveness.
  • 2
    Make sure the correct adapter is being used if the resistance settings seem to be too hard or too easy. If the correct adapter is being used, reset the machine. To reset the machine, either switch the "On/Off" button or unplug the machine from the wall. Doing this will allow the device to reset itself to the default resistance. Turn on or plug the device back into the wall and retry all of the levels of resistance.
Sep 30, 2013 | Life Fitness X3 Elliptical Cross-Trainer...
X3 goes faster that set speed on incline
Run the software calibration for easy diagnostic and fix it.
God bless you
Jul 09, 2013 | Exercise & Fitness
I have Life Fitness X3 elliptical machine, and when I start pedalling/striding the level setting goes to
adjust the magnet, tight the bolts with wren. Test the magnet, with the magnet from refrigerator, for repel and attract, if donot, replace.
The resistance depende of it.
sincerely. God bless you
May 06, 2012 | Life Fitness X3 Elliptical Cross-Trainer...
Life fitness 95ti belt moving to one side any way of correcting
Jun 09, 2010 | Life Fitness 95Ti Treadmill 95 Ti
Error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Feb 17, 2010 | Life Fitness T3 Treadmill with Advanced...
Life fitness treadmill display: transistor error-won't run
Solution
Feb 28, 2009 | Life Fitness Remanufactured Next...
Life Fitness X3 Elliptical Cross-Trainer with Advanced Console Logo
145 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
