Question about Life Fitness X3 Elliptical Cross-Trainer with Advanced Console
I have life fitness x3.
As soon as I increase the level, the system rests. How do I fix this problem?
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: I have Life Fitness X3 elliptical machine, and when I start pedalling/striding the level setting goes to
adjust the magnet, tight the bolts with wren. Test the magnet, with the magnet from refrigerator, for repel and attract, if donot, replace.
The resistance depende of it.
sincerely. God bless you
Posted on May 07, 2012
Tip
Increase Your Laptop Battery Life
Hey Guys!!! wanna know a secret on how to increase life of your laptop battery...
It's too simple but most of us do this mistake which results in declining life of the battery...
Let me tell you what not to do....Never overcharge your laptop battery, ya u heard it correct whenever extra charge goes into your battery it really affects your battery life and performance...In other words as soon as your battery is charged unplug the charger immediately ...
on Feb 02, 2010 | Computers & Internet
Have a code P1138 on 2003 Toyota Tundra - how do I fix ?
Swirl Control Valve Control System Performance Repair Importance Level: 3/3 Repair Difficulty Level: 2/3 Possible causes - Faulty Swirl Control Valve Control Position Sensor - Swirl Control Valve Control Position Sensor harness is open or shorted - Swirl Control Valve Control Position Sensor circuit poor electrical connection - Faulty Swirl Control Valve What does this mean? Possible symptoms - Engine Light ON (or Service Engine Soon Warning Light) P1138 Description While idling and during low engine coolant temperature, the swirl control valve closes, Thus the velocity of the air in the intake passage increases, promoting the vaporization of the fuel and producing a swirl in the combustion chamber. Because of this operation, this system tends to increase the burning speed of the gas mixture, improve fuel consumption, and increase the stability in running conditions. Also, except when idling and during low engine coolant temperature, this system opens the swirl control valve. In this condition, this system tends to increase power by improving intake efficiency via reduction of intake flow resistance, intake flow. The swirl control valve is operated by the Engine Control Module (ECM).
Read more: http://www.autocodes.com/p1138.html
Oct 02, 2016 | 2003 Toyota Tundra
Life fitness elliptical X3
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
The following link will take you to the information we have for the X3 by LifeFitness. Please have your serial number available.
Repair Parts for X3 Crosstrainer by LifeFitness SPORTSMITH net
Oct 23, 2013 | Exercise & Fitness
Life Fitness X3 does not turn on. So I can't set resistance nor intervals with console. Plug was checked and is fine.
follow this steps and fix it.
God bless you
  • Check power problems if the console on the elliptical machine does not light up. Make sure that the plug for the machine is secure in the outlet. If it is plugged in, ensure that the outlet is receiving power. Check the breaker to make sure it has not tripped off.
    Be sure that you are using the correct adapter that came with the elliptical machine. Because different adapters are able to handle differing amounts of energy, the wrong adapter will not transfer electricity like it should. If the adapter is pinched or damaged, this could also alter its effectiveness.
  • 2
    Make sure the correct adapter is being used if the resistance settings seem to be too hard or too easy. If the correct adapter is being used, reset the machine. To reset the machine, either switch the "On/Off" button or unplug the machine from the wall. Doing this will allow the device to reset itself to the default resistance. Turn on or plug the device back into the wall and retry all of the levels of resistance.
Sep 30, 2013 | Life Fitness X3 Elliptical Cross-Trainer...
X3 goes faster that set speed on incline
Run the software calibration for easy diagnostic and fix it.
God bless you
Jul 09, 2013 | Exercise & Fitness
Diesel mixed with engine oil increasing level of engine oil
Usually if outside o rings fail the its often soon after the inside rings and seals go to. injector pump overhaul the solution. You could just remove the pump and replace the front seal but it would only be a short term fix as the bushings in pump are likly worn
Dec 10, 2012 | Cars & Trucks
May 06, 2012 | Life Fitness X3 Elliptical Cross-Trainer...
Life Fitness X3 Elliptical Cross-Trainer with Advanced Console Logo
51 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
Craig Butler
Craig Butler
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
