Question about Craftsman 675 Series 190cc 22" Briggs Stratton Rear Bag Front Propelled Lawn Mower ()
It is leaking gas on the side
I pour gas in and it leaks gas
  • 655 Answers
Check your fuel lines first ! ! Slight crack might be the problem. If it has sat for a long time, the needle valve may be stuck open, causing the fuel to spill out of the carburetor . You would need to remove the fuel bowl and spray a little carb cleaner in there to loosen the needle valve.... Good Luck
Posted on Apr 17, 2014
Gas is pouring out of new generator. It seems to leak at point where gas goes into filter.Tightened hose. Still pours. Any ideas
Sometimes gas leaks appears to be leaking in one place when it is actually leaking from another place. I assume that the fuel feed is by gravity from the tank to the filter and to the carburettor. Did you check the hose that is attached to the bottom of the tank? it may be ruptured; check both clamps and make sure that there are no shavings to the hose.
good luck
Apr 23, 2016 | Lifan Energy Storm 2200 Portable RV...
Fuel in filter and start pouring gas in carb, but won't stay running
Make and Model, year of vehicle?
I'm assuming the vehicle won't run unless you pour gas into the intake. If the vehicle will start and run while manually feeding gas to the engine, you can rule out spark and timing issues. Usual suspects in fuel system are dead fuel pump (electrical or mechanical?) clogged delivery system ( fuel line, filter, injector or jet) or intake leak (bad gasket or seal, vacuum leak, stuck valve). 25310438-za4bqvjhdrn3arnyccyp5xaz-5-0.jpg
Dec 06, 2014 | Cars & Trucks
Fuel pump leak
Looks like it may be a fuel return line from the fuel manifold . It may be split or loose . Probably both . Get a new section of fuel hose and some good clips and replace it
Feb 22, 2014 | Acura Cars & Trucks
Leaking gas 2005 Chevy Impala
look under the hood while vehicle is running, this will be the easiest way to find it. it may be something as simple as a dry rotted rubber fuel line.
Feb 02, 2013 | 2005 Chevrolet Impala
Oster water kettle leaking from bottom of unit when pouring?
If you're not just simply missing the opening a little as you're pouring then I'd assume it's cheaper to replace than to repair, sorry.
If it's leaking from the side-glass you might get by with filling your kettle just under the lower end of the side-glass.
May 29, 2012 | Oster 5965 Electric Kettle
Gas leak
Coil packs are absolutely not the problem...the problem is a mixture of the float valves not closing correctly and a sticking vacuum fuel tap.
May 22, 2012 | 2002 kawasaki ZX-6R
I have gas spewing under my hood on my 2005 cavalier,the fumes are bad inside the car an when the hood is lifted you can see the gas pouring all over, what could this be? an what does this normally cost to...
sounds like u either have a loose hose or a broken hose
look for hose going from gas tank to engine
check for any breaks or loose connections
if you find nothing than check carb for any leaks
if broken hose u can replace it for around $2.00 to $10.00
depending on how much hose and clamps u need
if it's not the hose then it could be carb-check bottom of carb and sides for any gas leaking out
do all this with motor turned off
once u find problem-start engine and see if u have any other leaks
Aug 23, 2010 | 1995 Chevrolet Cavalier
I have a Homelite Super XL chain saw model 100454. Gas leaking around cap when turned on side to cut. Cork gasket look fine and surface is flat where cap in screwed on. Any help?
Just because that cork gasket "looks fine" does not mean it is working properly. Replace it with a polypropylene (oil and gas resistant rubber) gasket. That will clear up your fuel leak problem.
Dec 15, 2009 | Garden
My gas tank is significantly leaking only when almost full.
it could be that it has or is getting air in the tank in the form of vapors i know that it may seem unlikely but it does happen so next time that you go to fill up try opening up the tank cap while you go pay let ventilate and when you put the nozzle in do not shove it all the way in just enough for the vapor guard to cover the mouth and use the control of flow method.
Jul 05, 2009 | 2002 Jeep Grand Cherokee
BUNN BT10B carafe leaks from spout down side while pouring
I emailed the company again and they are replacing the thermal carafe at no charge. Thanks!
Nov 15, 2008 | Bunn BT10B Coffee Maker
Craftsman 675 Series 190cc 22" Briggs  Stratton Rear Bag Front Propelled Lawn Mower () Logo
70 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
