Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Won't read burned discs
I have a 1999 Wurlitzer OMT. When I bought my new computer the Wurlitzer would no longer read newly burned CDs. Tried different formats with no luck.
    Filmmaker:
    Uploaded 5 video answers.
  • 26 Answers
Some players will not read CDR's at all. Some are hit and miss. And some are actually designed in a way that they will read CDR. It is listed in their product specs. You likely have the fussy player. You could try changing all of the MP3's that you are about to burn into WAV files. then burn them at the SLOWEST speed possible. But it's likely the angle of the laser that is now different from your old computer.
Hope this was helpful
Ed
Posted on Jan 17, 2015
  • phil Jun 12, 2015
    maybe the brand of disc you are using
5 Suggested Answers
SOURCE: Wurlitzer arm keeps running
check the white plastic actuator next to the gear box, it is probably broken and not actuating the microswitch underneath it, these often fail, it may look ok,, but it actually is loose and the set screw on top of it is not clamping it to the rod.
Posted on Aug 25, 2008
  • 211 Answers
SOURCE: I have a Wurlitzer 1015 OMT 50-Disc model. Is it
It is possible.
If it is a 100 cd carousel then it is a simple computer setting.
If it is a 50 cd carousel you need a credit computer able to recognise 100 selections, a 100 slot carousel and a latch bracket for a 100 cd carousel.
I have never done it but it is definitely possible.
Posted on Jan 13, 2010
  • 98 Answers
SOURCE: wurlitzer omt K99 the cd will stop during play
The problem can be either the player or the CD Control board under the player. I am available to help troubleshoot this problem and can handle repairing or replacing the player or CD Control board. Please feel free to email tech@wurlitzer-ohio.com
Posted on Feb 19, 2010
  • 5 Answers
SOURCE: Wurlitzer 1015 OMT Disc spins, then stops....
Spoke with "Doctor Jukebox" from Folsom, CA about a similar problem I had. You can find him on craigslist.
I did NOT have the "2222" display issue.
Root cause: The laser isn't "seeing" the CD and interprets inability to see as being the end of the track, therefore, puts the CD back into the carousel.
Solutions:
1) Clean the lens. Be careful to use an appropriate lens cleaning solution. The lens is made of plastic and may cloud up if a harsh solution is used. Use a Q-tip dipped into the cleaning solution and gently clean the lens using a side-to-side motion, not a front-to-back motion. Wait for a bit until the lens is completely dry, then try playing a CD. (note: this fixed the problem for me)
If that doesn't work...
2) Replace the laser module. It's easy to remove with a torx. Be gentle when disconnecting and reconnecting the ribbon cable and/or other connections so you don't bend the leads. Laser modules cost a few hundred dollars, so try Solution 1) above before replacing the module.
Posted on May 22, 2010
My Box Was Damaged in shipping, Where can I buy Replacement Plastics and Bubble Tubes.
If you google for "cd jukebox parts" you can find a list of suppliers of all kinds of jukeboxes. You check with a few that work for Wurlitzer and I think you can find what you need.
Mar 16, 2015 | Wurlitzer Jukebox 1015 One More Time...
I purchased a used Wurlitzer 1015, question When selecting number 51 is a code number 82 and does not play can you explain me this, what the problem is thanks
The number of Cds in the carousel can be set on the Credit unit to stop it playing fresh air if for example you only have 50 Cds and not a whole 100. Sounds like yours is set to 50 so won't play anything over 50.
I 'think' this is what you do.
On the computer credit unit...
Service Switch ON...Press LT button.
Press 5 on the keyboard once.
Enter 0000
Service Switch off.
Press LT or turn machine off/on.
Aug 03, 2011 | Wurlitzer Jukebox 1015 One More Time...
IM TRYING TO COVERT MY WURLITZER 1015 OMT CD JUKEBOX TO PLAY MY IPOD WHAT DO I NEED TO GET.
To make the jukebox automatically switch between jukebox CDs and the IPOD source, you'll need the background music adaptor. I have these in stock, but need to know which amplifier is in your machine, as different amplifier types require different BGM units. Please email tech@wurlitzer-ohio.com
Oct 13, 2010 | Wurlitzer Jukebox 1015 One More Time...
Im looking for laser for model omt cd 100
You are looking for a CDM12 or CDMPro or CDM Pro2
Mar 20, 2009 | Wurlitzer Jukebox 1015 One More Time...
Aug 18, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer omt
If it shows just 8 in the LED display then it is caused by the amplifier being distorted (set too loud) and/or fuse Si3 on the amplifier panel requiring changing.
Nov 20, 2007 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
155 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
