Question about Nokia Cell Phones
Profile locked Stuck on headset profile, says profile selection is not aloowed
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 96 Answers
Restore you factory settings.If it faills go for a software update.
Posted on May 14, 2014
Stuck on Headset User profile
go check out your post on the net 10 forums. You just got a reply...
Nov 30, 2013 | Motorola Mobility W409G Prepaid Phone
LG TU500 Next G mobile phone has had a software upgrade recently. It was fine but it is now "stuck' on headset in profiles and will not let any other profiles be selected.
Hello.
Maybe you can reset it into original setting. verify the website of your stuff maybe they have upgarde solution to the bugs. if no solution i guess you restore the original softwares of your mobile. melnavz
Mar 26, 2008 | Lands Phones
How do I get my Nokia to turn off the headset icon and be able to hear my phone the normal way? I cannot hear any incoming call with the phone speaker.( i have no earbuds!!!)
Hello there,
To turn off the headset of your phone is quite simple, what you need to do is to go to the menu of the phone, select the settings of the phone ans scroll to enhancement settings, then you select the headset profile, then you select current profile, then you go to either general profile or any other profile of choice, after selecting it, accept it and go to the home page and remove the battery of your phone without turning it off, leave it for about 5 minutes then you fix it back in and turn on the phone.
The headset settings will be turned off by now.
Hope this was helpful to you.
Goodluck
Elect_Comp
Aug 09, 2011 | Nokia 6350 Cell Phone
What is the format code for micromax q75 mobile actually in profile setting showing only customize not showing activate menu and activated only headst profile i tried to change profile but when i tried to...
to change the profile first dial the code *#84666*# then u vl reciv d menu of Factory mode. nw insert yr handsfree in fon first then go to the no.14 item "Headset" & press 'On'. thus u can check yr headset that its working. after that just easily pull out yr handsfree and u vl got the General profile simply.
I tested on my fon vn i stuck by this prblm
for further help u can ask me
Sep 26, 2010 | Cell Phones
Profile automatic selected headset, I want to active general
hi,
Please try to reset yor phone to a factory settings.
Thanks
Jul 30, 2010 | Nokia N95 Cellular Phone
Nokia 6085 is stuck on headset-mode. How can I
try this: get a headset connect it then disconnect it go to settings - profiles - and select another profile. If it doesnt work try to restore factory settings if you dont know the sercurity code it should be 12345 by default
NB: pls vote
Oct 24, 2009 | Nokia 6085 Cellular Phone
Locked in headset profile
Have you attempted a factory reset? If not, but wish to try, I recommend backing up all your contacts to sim and all your files to PC, then go to the phones dial keypad and enter 3845#*990# (make sure you enter it all in the correct order the first time, it doesnt work on the # key being a finality button, but only recognizes them as a sequence, so if you make a mistake entering it you will have to start from the beginning again) this will take you to the device testing options - go down to the 8th option, factory reset but make sure you are ready before selecting it for it wont ask for confirmation when you do and will just do it.
Once this is done, the phone will restart with its factory settings, reload all your items back on to your phone and it should work fine.
May 25, 2009 | LG KU990 Viewty
N keypad sound, enhancement logo showing
The key sound problem:
Attempt the following:
1) Hit Menu
2) Go to Settings
3) Go to Profiles
4) Select General
5) Select Personalise
6) Scroll down to Keypad tones and if set to OFF select it, then using the centre button press right THREE times, then press the centre button to select.
7) Press Back
8) Go to Activate and Select.
NOTE: Follow this procedure for every profile you wish to use keypad tones for.
For the headset logo problem: (this is a temporary fix, you might need to have your phone checked or wait for another solution)
1) Hit Menu
2) Go to Settings
3) Go to Enhancement Settings
4) Select Headset
5) Select Default profile
6) Select Silent
NOTE: If this does not remove the logo, then you should follow the (instructions) above.
Regards
May 11, 2008 | Nokia 6230
Headset
it might be that the speaker/buzzer of your phone is already busted or perhaps just a lose connection. Let a phone technician inspect it. It can also be that the phone is locked to its headset state, this means that the phone always reads that the headset is connected, in this case just restart your phone. Be sure to check also if the profile is not set to headset. These are the possible causes i assume but i think its more on the hardware problem.
Please Rate Thanks
Jan 08, 2008 | Nokia 3200
X box 360
Make sure the headset connector and the headset jack on your controller are free from dirt and debris, which may interfere with sound transmission. More importantly, ask your fellow gamers and conversants to check their connectors, as the poor sound you hear may well originate from someone else's headset. 1. Examine and then clean the Xbox hardware. To do this, follow these steps:a. Examine the headset, the cord, and the connector for visible defects. b. Make sure that there is no dirt or debris on the Xbox 360 Headset connector. ? To clean the connector, use a cotton swab dipped in rubbing alcohol. c. Verify that the Xbox 360 Controller operates correctly. ? Verify that you can use the controller to turn the console on and off. d. Firmly insert the Xbox 360 Headset connector in the expansion port under the directional pad (D-pad) and the right stick on the controller. e. If this does not resolve the issue, go to step 2. 2. Test the headset. To do this, record and then listen to a new voice message. To record and then listen to a new voice message, follow these steps:a. Press the Xbox Guide button on the Xbox 360 Controller. b. Select Messages, and then press the A button. c. Select Create New, and then press the A button. d. Select Message, and then press the A button. e. Select a gamertag, and then press the A button. f. Select Add Voice, and then press the A button. g. Put on the Xbox 360 Headset. h. Select Record Message, and then press the A button to start recording a message. i. Speak clearly into the microphone and record your voice for 5 to 15 seconds. j. Press the A button to stop recording. k. Select Play Message, and then press the A button. l. Listen to your recording. ? If you can hear the recorded message, your headset is operating correctly. If the headset still does not function correctly when you use the headset on Xbox Live, you may have to configure Family Settings. Go to step 3. ? If you cannot hear the recorded message, your microphone may be muted, or the earpiece volume may set too low. Verify that the controls are adjusted correctly. 3. Configure Family Settings. Note If you set up a profile for a child on the console, Family Settings lets the owner of the parent profile control who can communicate with the child profile on Xbox Live. In Family Settings, you can enable communication in the child's profile. The default setting for gamers who are under 17 is Friends Only. To configure Family Settings, follow these steps:a. In the Xbox Dashboard, select System, and then press the A button. b. Select Family Settings, and then press the A button. c. Select Xbox Live Controls, and then press the A button. d. Select the child?s profile, and then enter the password of the parent?s profile that is associated with the child's profile. e. Select Privacy and Friends, and then press the A button. f. Select Communications, and then press the A button. g. Select one of the following options: ? Everyone This setting lets you communicate with anyone on Xbox Live. ? Friends Only This setting lets you communicate with people who are on your friends list only. ? Blocked This setting blocks all communication with the headset. Note With this setting, you can still receive new friend requests. h. After you select the option that you want, press the B button until you return to the System section.
Sep 20, 2007 | Microsoft Xbox 360 Console
Cell Phones Logo
12 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
