Question about Pioneer Car Audio & Video
Bluetooth I have a Pioneer CXE2187 sterio. I had to replace the rechargable battery. Since then, I can't get the phone menu to come up which means I can't use the bluetooth. How do I get it to work again?
SOURCE: Bluetooth is failing and my GPRS network not available
You just switch off your phone for a while then switch it on again it must work.
Posted on May 12, 2008
SOURCE: bluetooth problems
Holding down the main button while my phone searched for devices found it. I entered 0000 for the passcode and it connected.
Posted on Jul 14, 2008
SOURCE: Pioneer Bluetooth
The Code to activate it is 83423
Posted on Jul 19, 2009
  • 25 Answers
SOURCE: sony k550i bluetooth problem
Hai, i too had this same problem friend.. I tried many ways and nothing worked.. Finally i got my mobile re-installed through a service center which made my bluetooth work again.. You also try the same .. Hope this solution would be help full.
Posted on Sep 19, 2009
SOURCE: my dell bluetooth mouse stopped working. I
what OS are you running, is it vista? if so, I had same problem. the dell Tech had me uninstall service pack 2 and then the mouse would activate properly
Posted on Dec 16, 2009
Big blue speaker repair
Lithium ION batteries are usually rechargeable. The use mode for these batteries is that there are a set number of recharges that equate to the life of the battery. Usually that life is approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the battery is used up, the maximum charge lessens which means where you may have had 8 hours of play time when the battery was new, you will only have 6 hours as the battery life is used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never recharge again or the max charge will be reduced to an insignificant amount of the original full charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries cannot have their batteries replaced.
If the speaker is under warranty get it replaced.
Taking the speaker apart to replace the battery will compromise or even destroy the acoustic properties of the speakers. Big Blue Live Wireless Bluetooth Speaker
Mar 09, 2015 | Brookstone Big Blue Studio Wireless...
I have a pioneer radio reciver with cd player an gps it will not come on power is getting to it nothing works what do I need to check were my problem is #rs are cxe2187 avic-u3108t
Pull the unit check for fuse on back of radio. Some units with detachable face have a reset button hole that requires a pen pushed into the hole to reset. Check for proper ground to the unit. If all checks out and no luck time for the manufacturers to repair the unit
Dec 05, 2014 | Pioneer Car Audio & Video
Bluetooth not working
follow this steps and fix it. God bless you
Check your connection. If your Bluetooth will not connect to your phone, it's possible that it isn't paired or has lost its pairing with your phone. Begin by powering off your Bluetooth by pressing the multifunction button located at the top of the device.
    • 2
On the Nokia 6555 press the center "Select" key, located in the middle of the circular navigation keypad. This takes you to the phone's main menu.
    • 3
Use the navigation key to scroll to "Settings" and press the center "Select" key.
    • 4
Scroll to "Connectivity" and press the center "Select" key.
    • 5
Scroll to "Bluetooth" and press the "Center select" key.
    • 6
Scroll to "On" and press the center "Select" key.
    • 7
On the main Bluetooth menu, scroll to "Search audio enhancements" and press the center "Select" key.
    • 8
The phone will automatically search for available Bluetooth devices. When you seen an icon that says "Philips SHB 1300," press the center "Select." Your phone will be paired or reconnected to your Bluetooth.
2. Dead Battery o 9
Another common and easy-to-solve Bluetooth problem is the headset's inability to turn on. A dead battery is the likely culprit here.
o 10
Plug your Bluetooth into the power cable that came with it.
o 11
Plug the power cable into a wall outlet.
o 12
Allow your Bluetooth to charge for three hours.
o 13
Recharging the battery will give you about seven hours of talk time or up to 200 hours of standby time before you'll have to charge it again
Oct 29, 2013 | HTC Sensation XE Z715E Beats Audio...
Hello Can you pls advice how to change the battery
You don't replace the battery, it is a rechargeable battery and can not be replaced. All you can do is recharge it. To do this read the directions in the manual. If you don't have a manual you can read the one at this link:
https://motorola-global-portal-en-ca.custhelp.com/ci/fattach/get/593369/1361470436/redirect/1/session/L2F2LzEvdGltZS8xMzgzMzAxNzk4L3NpZC9YekRHM2ZFbA==/filename/S9_User_Guide.pdf
Oct 26, 2013 | Motorola Mobility MOTOROKR S9 Wireless...
Pioneer Model: DEH-P8400BH
Press and hold the source button until the CD Receiver turns off. Press and hold the center of the volume knob top bring up the settings menu rotate the volume knob until Clear memory is displayed and then press the center of the volume knob Clear memory YES will be displayed, press the center of the volume knob to confirm. The display will change from Clearing to Cleared
Aug 07, 2012 | Pioneer Deh-p8400bh Cd/mp3/ Receiver W/...
Pairing protocal for pioneer car sterio
it is Bluetooth music player what happen u unable to pair via bluetooth
May 20, 2012 | Pioneer Car Audio & Video
I have a pioneer cxe2187 car stereo/navigation system. The GPS is stuck at the last input destination and wouldn't accept any new input. What should I do to reset the system?
For the pioneer cxe2187 car stereo/navigation system, there is a very tiny reset button on the front of the screen just below the bluetooth light. Push it with the end of a paperclip and hold for 10 seconds then release. It will reset the system without loosing anything!!
Apr 09, 2011 | Pioneer Car Audio & Video
My n95 8gb the battery only lasted 8hrs before i have to recharge?
Try charging the battery with the phone shut off - overnight (if you don't already do that). Check the phone out for a day and nothing changes then look into replacing the battery(out of pocket $40-$60 usually for a brand name battery) . If the phone is under a year old and you received it new from your wireless carrier, the phone would be covered under a factory warranty. What that means is you can contact the phone manufacture and get a free replacement battery within the first year. A thought to keep in mind however, if you use your phones extra's like bluetooth or wireless connections if available - this can affect battery life as well. If you haven't already - try setting your bluetooth (if you use it) to the setting that it only works when you power on your bluetooth headset if the phone allows this.
Sep 30, 2009 | Nokia N95 Cellular Phone
Weird Symbol
It means that your bluetooth is turned on. If you don't know what bluetooth is its nothing to worry about its just a way to send information back and forth to other phones. It may slightly make your battery die quicker and you will have to recharge it. But there is nothing wrong with your phone :)
Oct 29, 2008 | LG Shine KE970 Cellular Phone
Car Audio & Video Logo
49 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
