Question about Refrigerators
Gsh25sgpass fridge freezer
My freezer isn't freezing and I took the evaporator cover off and noticed that the bottom coil has thick layer of frost and also the copper tube leading into it. How do I fix this issue?
    Novelist:
  • 150 Answers
If the bottom rung of the evap coil is the only part frosted, or frozen and no other parts of the evap coil contain frost, you are most likely low or out of freon. An experienced repair company should be called out to verify this. If the freon is actually low, recharging the unit is not a plausible option because there is a leak. A repair or replacement of the fridge is needed. Pleazer Appliance...
Posted on Apr 20, 2014
applianceboy
  • 77 Answers
SOURCE: FRIGIDAIRE FRS22ZRGD2
you may need to clean the drain tube again. the only other place that water may come from is the ice maker if it is over flowing. this however would be very obvious. use some thing like a length of cloths line cable to "snake" the drain after you defrost it. the fastest way to defrost it is to use hot water and a turkey baister. good luck.
Posted on Sep 26, 2007
aborcass
  • 2651 Answers
SOURCE: fridge freezing
a defrost problem, is gonna cause excessive ice build up in hte frezzer lower compartment. for somereaon the hdefrost heater was not energized. most common reason is a bad defrost thermostat, clipped on one of hte evaporator coils has gone bad,
Posted on Mar 22, 2008
  • 143 Answers
SOURCE: Maytag Model MZD2766GEW iced coils
This sounds like a defrosting problem. There is a defrost timer, a heater element, and a therm-o- disk thing that shuts the heater off when the frost is melted. These are the things to check, but it's usually the heater that is burnt out.
Posted on Jul 23, 2008
Bat1956
  • 585 Answers
SOURCE: Kenmore Coldspot side by side fridge/freezer no longer cold.
The black thing is the compressor. It should run warm but not hot. This usually indicates it's time to clean the condenser coils under the refrigerator. Try using a long soft brush and your vacuum cleaner.
Posted on May 09, 2009
Bat1956
  • 585 Answers
SOURCE: drip pan needs emptying; had repairman out for other issues, now fridge keeps overflowing
The accumulated ice you saw is of course the source of the water. The refrigerator will eventually rid itself of the excess ice and the problem will therefore disappear on it's own after a while. The drip pan is normally filled with only a small amount of water, and that is dried up by the condenser cooling fan under the fridge. The pan is removable from most units, but not without making a mess. I suppose you can make and clean up the mess one time and be done with it.
Posted on May 20, 2009
Where is the evaporator fan motor? My Freezer and fridge would quit cooling/freezing. I took the back panel off in the freezer a week ago and the evaporator coils were completely frozen over with ice. I...
I do not believe the problem is the fan. sounds like the frig. is low on Freon this is what will cause the ice build up. you need to find the leak, you can do this by spraying soapy water on coil tubes & watch for bubbles. repair leak & recharge.
May 25, 2015 | Samsung RS261MDBP Side by Side...
Westinghouse Fridge/freezer RJ340M. Not freezing cold.
Could be several problems, it may have a leak in the coolant system, the compressor may be bad, or the control system may be malfunctioning.
Mar 17, 2013 | Refrigerators
The refrigerator not cooling the freezer evaporator coil freezing the damper working but the fan tested good but would not come on the compressor is working find . why the fan not coming on?
Some models require the door to be shut for the fan to operate. Push the door switch in and see if the fan works. When you say the freezer coils are freezing. Are the frozen or ins there a layer of frost on them. Ice is bad if covering the coils. It prevents air circulation into the fridge. The freezer will also sometimes not activate the fan until freezer section is cold enough. It will than allow air to go into fridge compartment.
If you have any more questions please feel free to comment me back.
Jul 27, 2011 | Refrigerators
The fridge is not working. The freeze is working fine. The fridge is not producing any cold air.
Hi shannon_sell,
You can start addressing this issue by looking at the back panel inside the freezer. If you notice frost covering the back panel, you have defrost problem. What happens when you have a malfunction in the defrost system is tha air cannot circulate from the freezer to the fresh food section. Also, excess frost builds up within the coils inside the freezer. This is what is blocking the air flow to the fresh food section. The defrost system consists the defrost control or timer, thermostat and heater. Also, you need to check if the evaporator fan is working.
Hope it helps.
Thank you for using FixYa.
Jan 17, 2011 | LG LBC22520S (224 cu ft) Bottom Freezer...
Fridge was off for 5 months it was turned on and the same day and next day i put food in it been going one week and not freezing and not cool enough in the refrigerator
It probally has a leak in the sealed system. To do a quick check remove the back panel and check the frost pattern on the evaporator coil. It should have a light layer of frost over the whole thing. If it is only partialy covered it is low on freon. Fridges tend to leak faster when they are not running.
Jun 11, 2010 | Kenmore 64802 Top Freezer Refrigerator
I have a lg fridge/freezer model grb218juda. The freezer is at the bottom and a thick layer of ice keeps forming which i have to scrape away monthly. the seal is not worn and this appliance is 3 years old
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Take a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Jan 18, 2010 | Refrigerators
2000 Amana BX21Vl fridge: ice maker and freezer not working.
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of. after the freezer freezes again, your ice maker will work again.
Aug 18, 2009 | Refrigerators
Freezer not freezing
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 11, 2009 | GE Refrigerators
Ice build up in bottom of freezer
Check the ice maker. sometimes they get cracked a will leak water into the freezer compartment. Also check the ice maker fill tube for leaks or someone could have spilled something. Although this is tipical of a clogged drain. What happens is when the fridge go into derfost, it will melt all the frost that is on the evaporator, turning it into water. The water drains down to a trough under the evaporator and down a drain hole in the trough ( this trough is behind the evaporator cover ) Removing the melted frost from the freezer. If that drain is clogged, the water cannot leave the freezer. Then when the fridge starts back up ,it will freez the water that was not drained. After repeated defrosting the water will fill this trough and run off into the bottom of the freezer to be frozzen when the fridge starts to cool again.
Nov 16, 2008 | Refrigerators
Refrigerator
It sounds like you found it. Change the defrost timer.
Jan 16, 2008 | Amana DLE330RAW Electric Dryer
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
