Question about Jeep 2004 Grand Cherokee Limited 4WD
How do you fix a 2004 jeep grand cherokee keyless remote issue
SOURCE: how to change fog light bulb on 2004 jeep grand cherokee
There's a small space behind inside fender. You can get your hand in there to grab and twist the back of the bulb to release it. You need a flashlight.
Posted on Mar 08, 2009
SOURCE: windows and lock wont operate on a 2004 Jeep Grand Cherokee
I just had the same with mine, pull the rubber boot back on the drivers side front door and look for a severed wire, mine was black...simply spliced the wires back together and problem solved!
Posted on Mar 23, 2009
ZJLimited
  • 17970 Answers
SOURCE: how do i program a keyless remote for my 2001 jeep
Review this information:
- Self-Programming Sentry PROGRAM
- RKE (Remote Keyless Entry Trasmitter)
Good luck... and remember rate my help!!!
Posted on Aug 05, 2009
  • 295 Answers
SOURCE: how do i program my keyless entry remote for my
The dealer would have to do this. Or you can rent a DRBIII at techautority.com and it will guide you through the program.
Posted on Oct 25, 2009
  • 94 Answers
SOURCE: 2004 Jeep Grand Cherokee. Keeps stalling, engine
P0505 means the whole Idle Control system, not only the IAM. Check all related sensors (i.e. crankshaft sensor). Check with a voltmeter direct at the connector of the IAM if you get any signal. Remove the IAM from the TB, connect him, let someone switch your ignition key to ON. The IAM need to drive in/out for a short time to find the right position. Hold the IAM near a hard part, that they cant drive out completely! If IAM works fine, check the fuel pressure, check and clean your TB ( if not done yet). If that doesn't work, come back again please
Posted on Oct 27, 2009
The remote keyless entry stop working, batteries have been changed in key fob.
Unfortunately MOST battery operated key fobs are poorly built. Its very common for one of the battery contact solder joints inside the fob to break loose. I've repaired more than 30 of them so far. Check the solder joints and re-solder as needed.
Nov 05, 2014 | 2004 Jeep Grand Cherokee
1996 jeep keyless remote receiver
on my cherokee its in the dome light housing google it
or google grand cherokee forums
Feb 02, 2013 | 1996 Jeep Grand Cherokee
How do you program a keyless entry remote for 1998 Jeep Grand Cherokee
someof them you cant you have to take it to the dealership
Jan 17, 2012 | 1998 Jeep Grand Cherokee
I have a 2004 Jeep Grand Ckerokee Limited, and I can't get any of the windows to roll up. The keyless remote will lock and unlock the doors, and the memory system for keyless # 1 & 2 settings work when...
same thing happened to me. I was told this is common in jeeps and 90% of the time this is the solutuion. There is a rubber housing inbetween the drivers side door hinge and fuse panel with wires in it. Unhook your battery first then roll the rubber back and there will be broken wires in there. Strip the wires and reconnect them with connectors and you will be good to go. If tthe wires are broke on the drivers side panel no other windows in the jeep will work. these wires also control the mirrors.
Aug 23, 2010 | 2004 Jeep Grand Cherokee
Remote mirrows, electric windows, door locks will not work.
The problem is a either a brokern ground wire or orange wire between the drivers side body and the drivers side door. This is a common issue with 2004 Jeep Grand Cherokee's. It's difficult, but you can pop the rubber boot and check for broken wires. The fix is to re-solder them and tape them off.
Jul 06, 2010 | 2004 Jeep Grand Cherokee
My keyless remote for my 2000 jeep grand cherokee wont unlock the
go to autozone and use the remote tester on the counter to make sure that the remote itself is functioning or not, could be a dead battery. On some vehicles it is possible to reset the keyless entry by turning the ignition switch from off to run (right before the starter activates) 3 times or so, if you try this and the door locks activate then press the lock button on your remotes. good luck
Jun 03, 2009 | 2001 Chevrolet Blazer
Keyless remote transmitter programming
You will have to have a Jeep/Chrysler/Dodge service tech hook up their programed OBD2 scanner to reset.
Jan 27, 2009 | 2002 Jeep Grand Cherokee
2004 Jeep Grand Cherokee Limited Doors Keep locking
The locks are programed to lock at 17 mph.
You can change this through the computer setup.
Sep 08, 2008 | 2004 Jeep Grand Cherokee
Jeep 2004 Grand Cherokee Limited 4WD Logo
24 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Oloyede Monsuru
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
