Question about Epson Passbook PLQ-20 Matrix Printer
Epson lpq 20 papir feed
Do not feed paper
romeo1790305
  • 17 Answers
SOURCE: Epson cx3800 paper feed problem
no you might have a paper jam somewere and mabe you ink rollers are dry you might have to tell the printer to to a pre test and clean and if there is a paper jam it should be a slot on the back by the roller should be a tap that shows the tollers look for a pice of paper jammed somewere in the roller you migh have to take the paper out to inspct it for a paper jam and if none mabe the print heads are dry and it dosent feed the paper then could be it ok clean the print heads tell the printer to to a roller clean and then after that if no paper jam no were try printing a page take all the paper out and feed it manually and if it prints then some printer want feed if you have filled the paper tray up try putting less and then try
Posted on Jan 29, 2009
SOURCE: epson r2400 won't feed paper
I had the same problem, then found these instructions for cleaning the feed roller: http://www.museofineart.com/files/RollerCleaningProcedureRev2.pdf I used the paper towel method and it's working fine now with no issues.
Posted on Mar 06, 2009
aicaxz
  • 511 Answers
SOURCE: epson c90 paper feed problem
Is the message general error? The problem is tchip. When turn on chip is recognized by printer, but when start to print, printer "read" some information from the chip. Here is the error. Some pin at the chip for redaing the existence of chip, other pin for reading the information. Check connector between chip and carriage.
Posted on May 30, 2009
  • 526 Answers
SOURCE: Epson R340 does not feed paper or feeds it crooked
two things I would do, first carefully flip the printer upside down, (anything that looks like it can flap open, tape it well), and jiggle it slightly and see if anything falls out.
second, i would clean the pickup roller with an alcoholic pad or swab, if its not easily accessible, you will probably need to take the upper an middle casing off, which I dont recommend.
thanks adi
Posted on Jan 02, 2010
  • 1121 Answers
SOURCE: Paper Feed on EPSON STYLUS SX115
go reclaim to the epson service agent or where you purchase.
Note: take all ink cardriges out. they dont need them.
Posted on Feb 09, 2010
Paper jams on epsonXP605 expression printer
Printing photos from the back feed? Using special photo paper? Try cleaning the paper rollers that feed the paper. They get slick.
Sep 03, 2014 | Epson Expression XP- 605 Inkjet...
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
Hello can you assist I can not figure out why the CX8310 Epson printer won't allow me to feed paper into it.
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right edge, behind the tabs, then slide the left edge guide against the paper. Make sure the paper is not in front of the feeder guard.
  • Don't load too many sheets at once (up to 20 sheets of photo paper, 80 sheets of Premium Bright White paper, or 100 sheets of plain paper).
    Sep 11, 2010 | Epson Stylus CX3810 All-In-One InkJet...
    Epson C88 printer will not feed paper
    Check if there are any objects blocking the way of the printhead or if there are objects down the paper feed area.
    Is your printer placed on a stable, flat surface?
    Does it happen to all the papers that you are using? Are the papers in good condition?
    Try loading only 10 to 20 sheets of regular paper.
    do a printer check to isolate the issue. Turn the printer off. Unplug the usb cable from the printer. Hold down the paper button while you turn the printer on. Keep on holding down the paper button only. Let go of the paper button when the power light starts blinking. If it does the same, there is an issue already on the gear of your printer.
    If your unit is out of warranty, log on to support.epson.com. Click on help me find a service center to the left of the page to contact the epson local servicers near your area. If your unit is under warranty, call epson.
    May 20, 2009 | Epson Stylus C88 InkJet Photo Printer
    Epson R220 paper feed.
    TRY holding all 3 bottons at the same time for 20 sec this will reset the printer
    Nov 18, 2008 | Epson Stylus Photo R220 InkJet Printer
    Paper feeds through crooked and comes out crunched
    Make sure the blue slide device on the left side of the paper holder is tight against the paper. If not, the paper will feed corrked.
    May 29, 2008 | Epson Stylus Color 740 InkJet Printer
    Printer Feed Problems
    paper too thin 80gsm is too thin..try100. hope it solves your problem...did mine cheers derek
    Mar 27, 2007 | Epson Stylus Color 1160 InkJet Printer
    Epson Passbook PLQ-20 Matrix Printer Logo
    Top Epson Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
