Must open up a Peavey DPM3 SE to repalce battery. Have removed nearly every screw and bolt on the unit, no luck. Any suggestions?
    Novelist:
    Champion:
  • 225 Answers
Most likely secured with plastic snaps as well. PLEASE research though B-4 tugging with too much force as you could break the case. I often find additional screws hidden under labels and/or rubber/plastic feet on bottom. Good luck.
Posted on May 27, 2014
How do I open a peavey unity 2000 SM mixer
Remove all the knobs. Remove all the nuts on jacks. Lift the black pin fasteners. Remove screws on side panels. Total disassembly is required.
Apr 28, 2014 | Peavey Audio Players & Recorders
Need a digram of taking a dashboard out of a 2005 impala
  • Turn the engine of the Impala off and open its hood. Use a socket wrench to remove the negative cable from the battery.
  • Remove the four screws securing the driver's side kick panel, using a Phillips screwdriver. Use a slotted screwdriver to pry out the kick panel. Remove the passenger's side kick panel the same way.
  • Remove the metal plate from the driver's side of the vehicle under the Steering wheel by detaching its two securing bolts with a socket wrench. Pull the plate off to reveal three electrical connections. Unplug the three connections.
Glove Compartment
  • 4 Open the glove compartment and empty its contents.
  • 5 Remove the two screws at the back of the glove compartment.
  • 6 Pull the glove compartment off of the dashboard.
Center Dash Panel
  • 7 Remove the two screws securing the radio and the two screws securing the A/C unit with a Phillips screwdriver.
  • 8 Remove the four corner screws of the center dash panel faceplate with a Phillips screwdriver. Pull the faceplate off.
  • 9 Use a slotted screwdriver to pull the radio and A/C unit toward you.
  • 10 Reach behind the two devices and disconnect their connections. Pull them out of the vehicle.
Dashboard
  • 11 Remove the two screws underneath the steering wheel, using a Phillips screwdriver.
  • 12 Remove the two screws on the lower right side of the dashboard, using a Phillips screwdriver.
  • 13 Remove the 10 mm bolt from both side panels with a socket wrench.
  • 14 Remove the defroster grille by pulling it out. Remove the four screws along the top of the dash near the windshield.
  • 15 Pull the dashboard off the Impala and detach the two electrical connections. Lift up the dashboard and remove it from the vehicle.
Sep 22, 2012 | 2000 Buick LeSabre
How do I replace starter on 2002 sportster
First disconnect the battery cable. Then you'll have to pull the primary cover off the engine. Find the primary case drain plug underneath the rear of the primary case and remove it to drain the oil. Find the primary chain tensioner underneath the primary cover near the center and loosen the locknut. Turn the screw downwards to loosen the tension on the primary chain. Remove the left foot peg and take the "derby cover" off of the primary cover. Remove the spring and lock nut underneath the derby cover. Remove the bolts around the primary cover. As you gently pull the primary cover away from the engine, turn the clutch adjuster screw under the derby cover in a clockwise direction until the primary cover comes off. Remove the battery cable where it bolts onto the starter motor and the small single wire that plugs to the motor. Just above the clutch assembly there are two bolts. Remove these bolts and the starter will come off the engine. The bolts are different lengths. Make sure you mark which bolt goes where.
Good Luck
Steve
Sep 05, 2011 | Harley Davidson XL 883 Sportster...
Hi, I have own a pair of peavey impulse 1012 speakers. One of them has developed a fault in that the output is terribly owful at low volume compared to the other one but an increase in the output from the...
"terribly owful " is not a descripption we can really understand. You need to describe whether the probllem is with the bass or treble speaker... lows/highs... The only suggestion we can give is to open the unit. You will need a LONG phillips screwdriver and remove all the screws in wells around the edges from the back and then gently separate the shell. Inspect for loose wiring. You don
t mention if you are using this as bi-amped or not which we need to know. This unit has the soundguard protection of the tweeter which consists of an automotive type lamp and a polyfuse. I would open the unit and see if there is a problem with the connections or possiblly a socket problem with the lamp as that would disturb the tweeter level. If you are bi-ampong this, then verify that swapping the speakers the problem is the speaker and NOT the cable or amp... Also verify the switch on the back of the speaker is properly set.
Jul 25, 2011 | Peavey Impulse 1012 2Way Molded PA...
I have two black lines down the middle of page on Toshiba 1360. How do you clean all mirrors on this
remove the glass [two screws on the scale] very carefully clean the mirror that is near the lamp that is mirror 1 then clean the two mirrors that are nearest the side that the paper comes out that is mirrors 2+3 then remove the black lens cover i think it is held in place with two screws then clean the mirror that is there dont try to cean the mirror under it yet then open your machine and remove the cleaner unit follow the wire that goes to the unit and remove the black cover and unplug the unit, remove the toner cartridge you eill see either a black screw or a gold screw remove it slide out the unit and put one side gently.then look in the machine you will se a black cover slide your fingers in on the plate nearest you and you will feel a black screw remove the screw and then the cover will be loose remove it and clean the two mirrors there as well as the discharge lamps look in the optics cavity there are two slots near the lens, slide the two pins on the cover that you removed from the inside of the machine into them and slide upwards and retighten the black screw the rest is done in reverse good luck
Mar 16, 2011 | Toshiba 1360 Black and White Copier
I have a Peavey Valveking 112 . The standby switch is broken and I want to remove the amp to get at the switch. I've removed the 4 bolts from the top of the amp and the 2 screws at the back but it is still...
SOMETIMES the screws holding the handle go down into the amp. Sometimes there are screws from the sides also.
The LAST problem is the Tolex covering often bonds and interferes with removing AND installing the chassis...
It is best to NOT put too much force till you can tell it is free... they still can be nasty to slide out...
Sep 23, 2010 | Peavey ValveKing VK112 50W Combo Amplifier
My toshiba equium just wont except the main password, cant reboot..cant get into bios
At this time you need to cleat the BIOS password first so that you can get into BIOS. To cleat the BIOS password you need to open your laptop you just remove the battery first. Remove the screw and open the back cover. Locate the CMOS battery, all password are stored in CMOS memory.
Remove the CMOS battery to clear the stored BIOS password, Or you can remove also the CMOS jamper near the CMOS battery and turn on the unit with in 10 second and turn off. Reinsert the jamper. Now the BIOS password are already clear you can get now in BIOS to change some settings. Good luck
Oct 08, 2009 | Computers & Internet
How to changing the headlight
Take screws off the front cover about 10-20 screws Reemove cover then two screws by the headlight Pull wole healight out, Repalce bulb. Not that hard. Read the manuel. My 16 year old did it with her Dad
Nov 29, 2008 | 2006 Kia Sedona
How to repalce the battery
This is simple to do once you find the battery. Remove the rear seat (pull up on the front of it to release) to expose the battery. Then remove the Negative terminal followed by the Positive terminal. Finally remove battery hold down bolt to free the battery. ALWAYS wears eye protection when working on/near/with the battery.
Note- The seat belt configuration in the seat before removing... don't forget the seat belts when installing.
Use battery terminal protector on the terminals. Thoroughly inspect the terminals for signs of corrosion. Replace as necessary.
Oct 12, 2008 | 2002 Buick LeSabre
Peavey KB 300 amp problems
Hi there.
You have have been unfortunate enough to experience an uncommon failure. The bass driver has failed. It is a Black Widow that can have the basket/cone/voice coil assembly replaced as a complete unit. The magnet unbolts from the basket and you bolt on a new one. Classic field service designed product. You will be able to get a new basket from a Peavey equipment stockist. Just ask for a 15' Black Widow replacement basket They cost about $180 here in Australia and you can easily change it yourself. Good Luck and happy jamming.
A FixYa rating would be great for my tech tip to you. Cheers
regards
Graeme
Mar 07, 2008 | Audio Players & Recorders
115 people viewed this question
 Grubhead
Grubhead
