Question about Whirlpool WTW4800XQ Washer
Whirlpool washer inop
Ligths come on but it will not fill with water
    New Friend:
  • 24 Answers
Clean the filter
Posted on Apr 17, 2014
  • Richard Roth
    Richard Roth Apr 19, 2014
    Replace the lid switch. 99.9 percent of the no fill condition on this model is a poorly designed lid switch. Here is the switch to order.http://bit.ly/1qX9c4I
  • ABDULLA SINAN
    ABDULLA SINAN Sep 26, 2014
    check solnied wales ,Lid lock switc & Clean the filter
  • 2468 Answers
SOURCE: whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
Posted on May 10, 2010
aborcass
  • 2651 Answers
SOURCE: Whirlpool Duet washer fills with water by itself
sounds like a faulty water inlet valve, not seating properly after closing the valve.replacing the valve is the only solution to this problem, in the meantime you can turn off your water supply in between doing loads.
not a bad habit to get into!!!!
Posted on Mar 23, 2008
  • 7 Answers
SOURCE: Front load washer fills up with water
Jamesbestor,
The water fill selenoid had junk in it holding the valve open or the seat in the valve is damaged.
Turn off the power and water, remove two screws on the back of the machine and remove the lid.
On the back left top corner are the water fill selenoids. Remove these and disassemble by undoing the 6 or 8 screws ( depending upon model ) holding the unit together. Clean and reassemble, it should take care of the problem. If not, replace the selenoid.
Posted on Feb 15, 2009
honeymokey
  • 3113 Answers
SOURCE: Whirlpool Ultimate Care II washer fills with water and stops
Lid switch. Push down on lid.
Posted on Jun 18, 2009
marka19
  • 1430 Answers
SOURCE: Washer slowly fills with water when not in use.
The water inlet valve has failed. This is inexpensive and easy to replace. Try these links
http://appliancehelponline.com/washerwaterinlet.html
http://appliancehelponline.com/topwaterinletvideo.html
Posted on Jun 08, 2010
Water leak at bottom of Whirlpool Estate washer. Removed the cabinet. No leaks from the water pump, hoses or inlet valve. The tub leans a little toward the front of the machine. When filling/rinsin
It is common on Whirlpool models for the water to splash out the top when filling especially when sheets or nylon cloth is loaded in the washer. Air fills the cloth and balloons the garment up this caused water to bounce off the garment and splash out the back. This is the most common reason for those mysterious leaks. Lowering the water pressure coming into the washer can help prevent this.
Jan 25, 2015 | Whirlpool Washing Machines
Whirlpool front load washer will not fill with cold water
Sounds like your Valve is either inoperative, you have a Clog in the COLD (there is a small screened filter where the hoses connect or your board has went bad..
Jul 20, 2014 | Whirlpool Washing Machines
I have a top loading Kenmore Washing Machine. I don´t have the excat model but looks like a KENMORE HEAVY DUTY SERIES 70 AUTOMATIC WASHER, MODEL # 110.92273100. The problem presents after finishing...
You may have 2 defective parts.
First,make sure the hot and cold water hoses are connected correctly and both turned on.
If the water fill problem is the same,the water temp switch is bad.
The not filling after the wash cycle could be a bad lid switch.
Set the machine for SPIN and turn it on.
If it does not spin,replace the lid switch.
Sep 20, 2010 | Kenmore 24042 Top Load Washer
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool washer - tub drains while it fills.
Your drain is to low. Make sure that the drain that your discharge hose is going into is at least as high as the washer. If not the water will drain out as fast as you can fill it.
Aug 15, 2009 | Whirlpool Washing Machines
Washer will not rinse
SOUNDS LIKE THE INLET VALVE IS CLOGGED OR INOP. THIS CAN BE A NIGHTMARE TO REPLACE, BUT DON'T TRY TO CLEAN IT, JUST REPLACE IT. TRY FILLING FOR WASH WITH COLD ONLY TO CONFIRM. IF NO WATER FLOWS, REPLACE INLET VALVE.
Jan 28, 2009 | GE WSM2420T Top Load Stacked Washer /...
Whirlpool WTW4800XQ Washer Logo
236 people viewed this question
Dan Webster
Dan Webster
Sal De
