Question about Samsung Dishwashers
Normal, heavy, delicate lights stuck on--cant power on or off
These three lights stuck on at same time. Cant get them to go off. Machine wont power up or off.
  • Samsung Master
  • 3,247 Answers
If you have tried to unplug from mains power and there is no difference then you will need to provide the actual model number of your dishwasher in comments field.
The Samsung error codes for Normal, Heavy , Delicate lights stuck is not listed. The closest is Normal, Heavy, Quick which relates to a Low Water level. Also confirm which lights are stuck in your case and whether these are flashing or not.
Posted on Apr 24, 2014
5 Suggested Answers
SOURCE: The front panel is cycling through a bunch of
Open the front panel, loosen the processor board, remove the "chassis Harness" and reattach. That fixed it.
Posted on Jan 10, 2010
Testimonial: "Very helpful, but I did it myself, I am not an expert."
  • 3247 Answers
SOURCE: Three cycles On
Take a clean damp cloth and wipe the touch swithes and the side and top edges of the dishwasher drawer.
please post a comment to report back if anything changed. Will try to solve it for you.
Posted on Feb 11, 2010
SOURCE: the dishes are not cleaning properly and at the
heater
Posted on Jan 08, 2011
Why does the Lanier get stuck and can't start the machine.
Hi Theresa,
Have you tried cleaning the lanier? wipe it down lightly with a cotton swab, and check to see if there is light lubrication on the rail.
Normally over time the light grease tends to get sticky and causes the same problem. 3 -1 machine oil would work as well.
Hope it helps
Sep 28, 2014 | Office Equipment & Supplies
How do you reset a KitchenAid dishwasher model: KUDE70FXSS4?
Press High Temp Scrub and Dry Heat option buttons in quick succession one after the other for about 6 sec until all the lights come on. Then press Cancel button. This should reset the dishwasher. Press equivalent buttons on the panel if the actual ones above are not there.
Make sure the dishwasher detergent dispenser lid is shut and the dishwasher door is shut before you start the above reset sequence.
Jan 02, 2013 | KitchenAid Dishwashers
All my lights on the front of the dishwasher are blinking at me & stops running after 3 minutes into the cycle. What is the cause of this & of course, I am two months past my warranty. Help.
If three lights are blinking (normal, heavy, quick)... I just had this same problem, and I think I figured it out. There was water on the bottom from the last cycle, so I pressed HEAVY and DELICATE at the same time for 3 seconds (you'll see it printed on the control panel), and the unit drained. I was then able to start the new cycle normally without the error. Hope that helps!
Jan 27, 2012 | Samsung DMT300RFW Builtin Dishwasher
Timer only works on heavy cycle not on normal model #11024632300
Could be a bad timer or loose contacts.
Unplug the washer.
Open the control console.
Remove the wire harness connector from the timer and re-insert it.
Also advance your timer manually 360 degrees around several times. This can cause stuck contacts to work correctly.
If this does not correct your problem you will need a new timer.
Feb 14, 2010 | Kenmore 24632 Top Load Washer
No agitation in the delicate and regular modes.
does you washer have a delicate, or normal speed adjustment switch, if it does make sure its not between setting or it will sound like a machine gun......you may need to replace that switch
Dec 18, 2008 | Kenmore 24032\24036 Top Load Washer
Dishwashers Logo
379 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
