Question about Locks & Locksmithing
Battery change for safewell electronic safe SW2007025601
SOURCE: i have a safewell electronic safe and no keys and
hi : about the stockwell safe ex200----- 2535-EA
if the safe still has charged batteries you can deactivate any sceurity code by access through a small hole on the rear of the safe, if you can get to the rear area of the safe.. You need a long screwdriver to reach to the inside of the front of the door . Their is a reset button on the inside of the door in the lower right corner area( "B" button) on the end - not on the flat face surface of the door but on the vertical face( hing plate). You'll have to feel around and push the screwdriver sideways to push the button in.it will beep . YAHOO- YUH DID IT !!!. Then you can reset your own code.if you need further instructions call me . icq. 33819110 or echarron1@cogeco.ca
Posted on Sep 02, 2009
  • 124 Answers
SOURCE: i forgot the safewell electronic code and didnt have the key
NOTE: The safe needs to be upright and right side up or the locking mechanism
won’t work.
ELECTRONIC SAFES
To open an electronic safe the first time, press the following numbers/letters on the
electronic keypad –159B. (These numbers are preset. You should change the code as soon
as possible after opening the safe to insure proper security). After you have entered the
factory set code, you will need to turn the knob on the faceplate to open the door. You will
have 5 seconds to turn the knob before the locking mechanism is reactivated.
ENTERING YOUR SECURITY CODE
To enter your own security code you will need to follow the steps listed below:
1. After opening the electronic safe (with the pre -set factory code of 159B) locate the
small red button on the inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep.
DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW
SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits
long, and confirm your new code by pressing the letter “B” on the electronic touch pad.
Before you close the door, try the new security code to make sure the lock release the
knob so you can turn it and retract the live action locking bolts.
If you can not get this open more then likely you will have to cut it open.. One last thing to try is to email safewell sales@safewellsafe.com
Good luck
Posted on Sep 14, 2009
  • 10865 Answers
SOURCE: I have a Safewell Electronic
Hello Peter. Get some penetrating lubricating spray such as WD-40. Spray it into the key hole and onto the key. Insert the key and tap it lightly with a hammer. Turn it. If it still isnt in far enough let the penetrating lube work over night and try again. Reapply the WD-40 as needed. Joe
Posted on Nov 05, 2010
jyackle5
  • 8197 Answers
SOURCE: I bought a Safewell SE
The red button is on the inside of the safe. It is on the back of the door. Usually by the hinges
Posted on Dec 19, 2010
  • 963 Answers
SOURCE: I have a safewell safe. Batteries are dead and I have lost my keys. The reference is EX2006029121. ANY IDEAS PLEASE.
I read this elsewhere. it's worth a try...
"I had the same problem, batteries dead and i could not find the keys. I read on the internet that if you get a hairdryer, and heat up the front of the safe where the keypad is and where the spare key goes in this will work, i thought anything is worth a try. So i held the hairdryer there for a bout 15 mins and what happens is the heat slowly boosts the battery life, enabling you to open the safe. You will notice that you start to get a beep noise from the key pad. even though i was getting a beep from the pad it didnt open straight away but after about 10 mins i retried the code and it worked. Make sure you replace the batteries immediately before closing the safe again "
Posted on Feb 22, 2012
My new AA 1.5 batteries will not work in my Safewell electronic safe . Please could you help me
try changing battlers new doesnt mean free from defects --check and inspect the connections /terminals ---- if all good use back up key --notify safewell or a locksmith
Sep 06, 2017 | Computers & Internet
Safewell EX2005327788
A set of emergency keys is supplied with every Safewell safe. In case the batteries drain out, you may use the emergency key to open the safe. These keys override the digital password. Remember, never keep the emergency keys inside the safe.
Jan 14, 2015 | Home Security
Have a safewell electronic system safe ex2007126498 want to open it lost key and forgot the password
won't work.
ELECTRONIC SAFES
electronic keypad -159B. (These numbers are preset. You should change the codeicon1.png as soon
knob so you can turn it and retract the locking bolts.
Apr 22, 2014 | Computers & Internet
I hv a safewell safe. i locked the emergency key before setting my personal key inside the safe. how to open the safe now?
You'll most likely need help from a locksmith. Basically, the lock can be picked, to get the safe open. There might also be a factory pre-set code.
Aug 16, 2011 | Locks & Locksmithing
I need a replacement key EX2005138875 for my Safewell electronic safe. The batteries have failed and I cannot open the door.
I was locked out of my Honeywell safe after battery died. I ordered a replacement key from firstalert.I was required to photocopy the receipt and type out an witnessed affidavit stating I own the safe. About 3 weeks later I found my spare key,4 days after that the replacement key arrived in the mail ($10.95 money order for that key). The other two spare keys were in the safe, I did not think the batteries would die so soon. Crappy factory batteries that came with the safe.
Mar 15, 2011 | Locks & Locksmithing
I have lost our spare key - where can I buy a
HUBBIE LET SAFE BTTERIES RUN OUT THE LOST BOTH KEYS ( BOTH ON ONE KEY RING??? )
NEED KEYS FOR A ..
NUTOOL SF10 ELECTRONIC DIGITAL SAFE..
HELP NEED PASSPORTS!!!!!!
JOAN
Jan 31, 2010 | Safe International Digital Electronic Safe...
Change code
Try this
Open the safe.
press the red button on inside of door
entry the new code you want followed by B
Should be good
Nov 22, 2009 | Safe International Digital Electronic Safe...
I forgot the safewell electronic code and didnt have the key
won’t work.
ELECTRONIC SAFES
Good luck
Sep 14, 2009 | Locks & Locksmithing
I have a safewell electronic safe and no keys and lost code ex2007127402 can i have a code to over ride and open it
Jul 26, 2009 | Locks & Locksmithing
Locks & Locksmithing Logo
98 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
