Question about Sentry S0891 FIRE-SAFE personal safe
I have a Sentry S0891 safe and when I put in my code it keeps beeping and the red error light keeps flashing. Someone tried to enter the wrong code multiple times and I don't know how to reset it
  • 726 Answers
SOURCE: this is a fireproof sentry
well is the batterys ok?
in the safe
to get in just grind it or there is no other way
someone might have known the code and changed it
Posted on Jul 29, 2008
SOURCE: factory code will not open model # DA3831 safe
i am a locksmith that has worked on several of these. The safe is manufactuered with three types of lock mechanisms 1. combo dial 2. digital 3. advanced digital the advanced digital is what you have there are no green lights on it. look at the manual carefully there are 2 seperate sections on the digital key pads yours will be the second.
Posted on Dec 18, 2009
SOURCE: sentry safe, enter codes and nothing
These safe are easily opened by a good locksmith. So if you have items in the safe you need to get out a safe and vault tech could drill it open and repair it for a small fee. I really don't think it is the chip probably just a stuck solinoid.
Posted on Aug 08, 2010
  • 412 Answers
SOURCE: sentry 1610 safe - battery is dying?
I have 2 Sentry 1610 Safes. A fresh alkaline battery MAY open the safe once (maybe twice), and then the same problem. I have a variable DC power supply that I hook up to the battery terminals, set to 9 volts and increase the current until the keypad responds & the deadbolt releases. Sentry has no solution for this problem, as this model is too old & they have no parts or troubleshooting. If you know someone with a small DC Power Supply, you can get your safe open / closed.
Posted on Nov 02, 2010
SOURCE: csw3607 sentry safe will not open. when i use my 5
I hate to tell you, I just had this same problem on a brand new safe (x-mas present) and ended up having to crack it open. Unfortunately, from my extensive research on this problem on Sentry Safes it turns out that they use an encoded IC chip on the solenoid and if either a serial wire breaks going to the board or the IC chip fails, you get the 5 beep-of-death error. Needless to say, I'm thoroughly disappointed in Sentry and will discourage anyone from purchasing their products!
Posted on Jan 04, 2011
Can't open safe!
If it still doesn't open after you replace the batteries then it is probably do to it being Jamed. I'd suggest tapping it with a bit of force but if it still doesn't open to go and see if someone can fix it.
Aug 12, 2016 | Sentry Safe Fire-Safe Home/Office Safe
Trying to open safe but each time I enter it beeps with a red light
When you change batteries the combination that you programmed into the the Sentry Safe will delete and you will get the red light error signal. At A1 Locksmith Service we recommend that you use the original master code that came with the Sentry Safe. If you can not find your owners manual with the master combination. Addtional help can be provided at A1 Quality Safe. (650) 240-5505
Aug 04, 2014 | Sentry Fireproof Safe
I have a Sentry safe S3877 the batteries were replaced with new it still gives the error beeps for batteries need to be replaced the safe will not open, how can I get the safe to open?
A1 Locksmith Burlingame CA Once you get the error light that means you are entering a user code that was deleted when the batteries went dead . Simply replace the batteries then use the master code in your owners manual to open the safe. Reprogram new user code instructions bottom of this page.
Apr 17, 2013 | Sentry Fireproof Safe
We have a Sentry safe model number SC 3877. We just changed the batteries. We are imutting the correct code, the light turns green but does not give the 1 beep and we cannot open the safe. If we put in...
http://callitout.com/quotes/index.php/kick-it-to-the-curb/55/sentry-fire-safe-wont-open-its-broken/
Its the most reazonable answer and it worked!!!!!!! dial the code and tap on the handle so it would get lose
Jan 16, 2011 | Sentry Fireproof Safe
Csw3607 sentry safe will not open. when i use my 5 digit code the red light beeps 5 times. when i use the factory code it does the same thing. Sentry has told me to take it to a locksmith and have them cut...
Dec 10, 2010 | Sentry Fire Safe - Safe - DS3607
I need to change the combination on my sentry S 3517
Locksmiths recommend
two ways to program a user code.A
1. Press the Program key.
2. Enter the Factory Code. The green LED remains ON while you enter the 5-digit user code of your choice.
After 5 digits are entered the green LED turns OFF.
(To enter a new User Code, repeat these steps.)
B 1. Press the red button inside the safe. The lock will “beep” and the green LED will come on.
2. Enter a 5-digit user code. (To enter a new User Code, repeat these steps.)
Keep your new user code secure.
Nov 13, 2009 | Sentry Fireproof Safe
Lost instructions for sandleford E.S.20 safe
The operating instructions on the ES20 as per the crappy manual:
Open safe using emergency key provided
Insert batteries in the box inside the door
Opening the safe
a. pre-set factory code 159
b. input 159 (the yellow light will flash and the buzzer will beep), then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened
Closing the safe: close the door, input the code (the green light will flash for 5 secs). Turn the knob anti clockwise, the control system will activate and the safe will be locked
Changing the code: open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code (1-8 digits), then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Emergency Key - store in secure place NOT inside the safe. Remove the override cover in the centre of the face of Safe (its a silver plastic panel with Sandleford Electronic Safe ES20 on it), insert override key (a cyclinder key) - hidden underneath the override cover panel - and turn anti clockwise, rotate the knob clockwise to open door
Changing the Battery - If the red and green light are on this indicates that the batteries are low and require changing. To ensure the batteries have been installed correctly test before closing the door
References:
1. Operating instructions EA Electronic Safe
2. http://www.secustar.com/products-en/estype-safe.htm
Jan 09, 2009 | Sentry Fireproof Safe
Error light comes on when keying combination code
Try new batterys ,also sometimes if too full ,you will have to hit it hard to get the stuff off the lock bars that keep them from moving .
Dec 17, 2008 | Sentry Fireproof Safe
Factory code will not open model # DA3831 safe
Nov 23, 2008 | Sentry Fireproof Safe
Sentry S0891 FIRE-SAFE personal safe Logo
104 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Hannah Johnson
Level 1 Expert
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
