Question about Gaggia Titanium Espresso Machine
Machine stuck in self test mode at switch on
On power up machine takes a long time (30mins+) to come out of 'self test' mode
My canon imagerunner 6000 hangs on starting the machine. It just says wait.....
Most copiers and printers have a mode called power save mode. If the Machine is not in use it saves energy and powers down to a lower level. Once it receives a print job it takes a bit for it to warm up. It can take up to a couple minutes on some machines to do their self test while powering up. As long as it gets to the ready mode to unit is good. On some unit you can disable the power save mode or make the between going into power save mode longer.
Printer Repair Service in Miami and Fort Lauderdale FL
Jan 15, 2016 | Canon Office Equipment & Supplies
JGBP35 "LOCKED DOOR" light will not turn off
Try below link for the manual. Hope this helps... http://products.geappliances.com/ApplProducts/images/t07/0000017/r17643v-1.pdf
Sep 06, 2007 | GE Spectra JGBP35 Gas Kitchen Range
The printer continues in Self Test, the printer is stuck at this point as it tries to continue to cycle through the power up.
Try to power on the printer without the toner kit and the waste toner box. If the printer stacks again at self test. Next step.... remove one part at time and check if the printer displays any message. First remove the developer unit and power on the machine (normal message "Missing Developer Unit"). Then pull out the fuser unit and power on the machine (normal message "Close Rear Cover"). And finally, remove the Drum Unit and power on the printer (normal message "Call Service 7410").
If the printer still stacks at Self Test, then that is not a good sign. Try to upgrade the printer' s firmware (system + engine). There is a possibility to go further from Self Test.
If it does not, then you have to replace the main pwb.
Oct 28, 2014 | Kyocera Fs-3920dn Laser Printer
Navana Fault POWER MODULE TIME OUT. Cannot start machine
yes. when one of the phase is out, the other two power module is usually overloaded and burnt. swap it.
May 19, 2014 | Ingersoll Air Tools & Compressors
Our xerox workcentre 4150 is stuck in a self test mode. We have turned off the machine and unplugged it several times, and it keeps going back to the message Please wait....Machine self test in progress....
You will either have to take off the back cover and remove the memory battery. One of those round lithium batteries and reinstall it or go to xerox.com, download the newest level of firmware and load it to the machine.
You may also want to try turning the machine off. unplugging the hard drive and see if it works like that.If it works without the hard drive replace it. If all those steps do not work replace the main board.
Aug 13, 2010 | Xerox WorkCentre 4150 Black and White...
Have the machine in self test mode and dont know what each button
Just read your machine user manual.you will find detail info.about all the button.
NOTE: Do not skip ''self test". because during self test mode machine check it self & make sure that it is working properly.
Jun 15, 2010 | Robinair Cool Tech 34700Z Recovery,...
Problem diagnosis please
touch pad is stuck on the control panel machine putits self in self test
Mar 03, 2008 | Washing Machines
DVD recorder DMR-E55
You can try a factory reset (reboot).Here are the steps..
The following will set your recorder to the Factory defaults.
(Will not format HD on DMRE80).
With power off (stand-by mode/CLOCK DISPLAY SHOWING):
1)Press and hold [skip reverse] [Time Slip] [Eject] buttons for about 10 sec
2)Display will show 'L1 TEST'
3)Now power off DURING TEST
4)Clock should be fashing 12:00
5)Turn power on and language menu will be displayed on TV
Use for
DMRE50
DMRE55
DMRE85
For the DMRE75V press both [dub] buttons and [eject].
Hope this helps.
Nov 20, 2007 | Panasonic DMR-E55 DVD Recorder
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
89 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
