Question about Goldstar MV-1526 Microwave Oven
Completely stopped working
I was heating something for 30 seconds in this microwave (Goldstar MV1526B) when it just stopped. now nothing works. it doesnt do anything. the light is out, the time display is out and nothing happens when you press any of the buttons.
  • jenkslauren Jun 19, 2009
    How would i go about fixing that?
    Sergeant:
  • 249 Answers
Sounds like you blew the fuse inside
Posted on Jun 19, 2009
What would cause my Goldstar microwave to stop heating and the tray to stop revolving?
if timer and all other controls seem to work correctly id say a loss of high voltage section in microwave power generation part there can be several reasons for this a profesional serviceman can find more about why ?
Sep 09, 2014 | Microwave Ovens
Tip
DANGER WARNING! Potential Hazard if your microwave was working and now doesn't...
If you have this model microwave and it was working fine, then one day it stopped heating items placed inside there are a handful of different issues that could be the problem. In my case it was intermittent, over a period of a few days it would sometimes work (heat) and sometimes not. NO MATTER if this is what your's is doing or if it stopped heating all together. If you decide to let it dry out, or not use it for a while to see if it was a one time occurrence, or whatever the reason, the first time you put something in and probably for the next 10 times at least (this assumes it starts to work again), make sure you are right there with it while it is cooking. Don't assume you can put something in, go do something and come back when the timer is beeping. There is a chance (as this happened to me) that your food inside will CATCH FIRE! Normal food item placed inside, no metal, nothing different than the numerous times before when this had been cooked but when we smelled smoke we came running. Fortunately it started and finished inside the microwave but that's not a guarantee, it could spread. Play it safe. Never had a problem like this before and never heard of a microwave cooking something until it caught on fire (especially since the time entered for the cook was 30 seconds) but it did.
on Sep 23, 2013 | GE JVM1850SMSS Microwave Oven
I have a goldstar model mv1526b microwave it has a weird hum and wont heat. Everything else seems ok.
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Feb 25, 2011 | Goldstar MV-1526 Microwave Oven
I have an old Goldstar microwave (MV1140T) that just stopped heating. The fan still works but the food won't heat up. What can I do?
The problem is caused by a bad magnetron, "common problem" or the high voltage capacitor and diode, all three work together to heat the food. The repair cost for parts and labor will be high enough to consider buying a new microwave oven.
Feb 23, 2011 | Goldstar MV-1501 Microwave Oven
Goldstar GMV1540TB Microwave is not heating. Timer works but the tray is not rotating. If pushing the door up the oven can heat but easy to stop heating.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101=-=-=--
Jul 14, 2010 | Goldstar MV-1526 Microwave Oven
My goldstar mv1501B won't heat anything. What' wrong?
everything works except the heating system what shell i do?
Mar 25, 2009 | Goldstar MV-1501 Microwave Oven
Goldstar MIcrowave stopped working when light bulb blew out.
when that happen to me i change the bulb and the fuse in of the microwave f the don't work send it to the company that made it and they should tell what wrong.
Mar 11, 2009 | Goldstar MV-1501 Microwave Oven
Goldstar microwave oven stop heating
microwave ovens have a special Magntron fuse that is inside the body of the microwave its much bigger than a normal fuse, if its blown the microwave wont work.
Jul 30, 2017 | Goldstar Microwave Ovens
Just quit working...but not everything.
Hi , open the cover with philips screw driver , b sure unplug it first , If you have continuety tester check the fuse if open replace it , are available in electronics center brings that sample and insert it.
Apr 16, 2008 | Kenmore 62702 Microwave Oven
Goldstar MV-1526 Microwave Oven Logo
484 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Mike
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
