Question about Echo Garden
Echo gt 200r
The string an head dont move but its start ok an run
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Echo Master
  • 1,917 Answers
Spring drive shaft broke
Posted on Jun 07, 2014
panilling9
  • 284 Answers
SOURCE: My Echo GT-200R will not start.
you need to make sure your plug is sparking
and if it is wet then the engine is flooded with fuel
press your primer bulb 5 or 6 times and use no choke and hold throttle open when trying to start it
Posted on May 26, 2009
#1 Taper
  • 1041 Answers
SOURCE: echo gt 2000 does not have spark and will not start
Your ignition module is probably bad. The part may be as much as $35, but you might want to double check.
Jim
Posted on Jun 21, 2009
If you have not had a solution by now (I know it's been a month since your post...), I just read on another help site that by cleaning the exhaust port would solve the problem. That port gets gunked up and the motor won't work if it can't "exhale" correctly. Good luck.
Posted on Jun 26, 2009
jdlipscomb41
  • 157 Answers
SOURCE: Primer bulb stays in after depressing it.
sounds as though fuel lines are incorrectly hooked up
Posted on Sep 18, 2009
Testimonial: "Echo GT 200R Grass Trimmer.Fuel lines were correct.I had purge base gaskets on wrong side of carb.I replaced gaskets but still won't start.Carb cleane"
rycgl
  • 1545 Answers
SOURCE: How do i take apart the string head on my echo
See how the head is installed on page 9 of the Rapidloader manual. Removal would be in reverse order of installation. You can probably use a Phillips screwdriver for the locking tool mentioned.
http://dl.owneriq.net/a/a19727c4-b4e6-466f-8b8e-635e716636c1.pdf
Posted on Oct 19, 2010
How to restring drum on Echo 210 gas trimmer
Pull the head off by turning the inner hub counter clockwise while holding the outer head still. Once the inner head pops out, turn it over and look for the string rotation arrow. If you can't find the string winding directional arrow, start the trimmer and determine shaft rotation direction (generally counter clockwise) and wind the string in the same direction as the head rotates when installed.
Pull about 5 arm lengths of string out of a string spool and cut it off. Place the inner trimmer head on an object that will hold it while you pull the string to even lengths through the winding hole (the support brackets of a pickup truck tail gate work well for holding the inner head while doing this).
Begin wrapping the string double wraps in the proper direction, laying them evenly and closely to the previous wrap, working it back and forth as the string begins to build up. Avoid crossing the string over itself more than necessary, the string can weld itself together if the strands cross to awkwardly. Once the string is wound, hold the head with one hand and slide the string through the outer head holes, avoid letting the string come unwrapped.
Carefully place the inner head down into the outer header. Avoid letting the string get caught between the inner and outer head. Once the heads are together lock the inner head onto the outer head by turning it and locking the round knobs into the outer head slots.
You can trim the string or let the trimmer guard do it. If the string doesn't feed it is either wound the wrong way, tangled between the inner/outer head or welded to itself.
Aug 19, 2014 | Echo Garden
I'm writing about cleaning the String trimer head of my 19.2 volt string trimmer. Is water from the garden hose nozzle O.K.?
i use WD40 to clean also spray head before use this keeps the head clean at least it does with my strimmer
Jul 02, 2013 | managemylife.com
TB70ss Trimmer runs but does not turn the string
Remove the angle drive gearbox near the string head and spin it to see if everything is moving properly. You may have stripped the gears out of it.
Sep 16, 2012 | Troy Bilt Tb70ss Gas Trimmer
HOW DO I INSTALL A NEW STRING IN A PRO CUT 11 for Ryobi RLT30CD trimmer
LINE REPLACEMENT (Fig. 8) (For Reel EasyTM Head) Use 2.4mm monofilament string. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Cut one piece of string approximately 7.6m in length. n Rotate knob on string head until line on knob aligns with arrows on top of string head. n Insert one end of string into eyelet located on the side of the string head and push until string comes out through eyelet on the other side. Continue to push string through the string head until the middle section of the string is inside the string head and string outside the string head is evenly divided on each side. n Rotate the knob counterclockwise on the string head to wind the string. Wind the string until approximately 20cm remains protruding from the string head. INSTALLING STRING IN PRO CUT II STRING HEAD Use monofilament string between 2.4 mm and 2.7 mm diameter. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Gather two of the pre-cut lengths of trimmer line provided or cut two pieces of trimmer line, in 28 cm lengths. n Insert the strings into the slots located on the sides of the string head. String should be pushed in until approximately 2 cm protrudes from the holes on the top of the string head. n Remove old string by pulling it from the holes located on the top of the string head. http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Oct 29, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I bought this poulan weed eater on 4-2-10 at walmart in westworth village . the trimmer head does ok at any spped for a 2 or 3 minutes then it just goes real slow with the speed at cutting speed . the two...
new doesnt mean free from defects sounds like the shaft is binding can be from a kink or not lubed correctly-- its new so bring back to walmart and replace or return
Apr 14, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Our Singing Bing Crosby Santa doesn't move his mouth any longer, but his head and microphone still move while he's singing. Can we get his mouth repaired somewhere????
I have had the same trouble. I had to take his head apart and there is a string that is attached to the motor that works his mouth. The string has come unattached and needs fixed. The head is put on with a type of staple around the neck.Take them out and you will see what I mean.
Dec 14, 2009 | Gemmy Bing Crosby Big Head Doll
How do you Replace string on the trimmer head spool
Take the spool off and turn it up side down take out the centre and wind the left side 6 times to the left and the right side 6 turns to the right then put the ends through the holes and refit to stud and screw on butter fly nut...
Dont try winding them both the same way as when you try to get more out 1 side will come out and the other will go inside so you will be back were you started
Sep 27, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
String Runs Out
You are most likely keep bumping the head on the ground, causing the string to unwind. Hold weedtrimmer off the ground.
Jun 02, 2009 | Black & Decker String Trimmer Cordless 12"...
Gemmy Santa Bear mouth does not move
I would like to first tell you what the problem is with either your Bing or Bear head. Inside the head is a motor that works the mouth. On this rotating motor is a pulley type system, which has a twine or you could call a heavy string piece. It is attached to the motor, and when the is activated it rotates the thread round the spindle on the motor and the mouth operates.. It is quite a difficult to take this head apart. I worked on my Bing for some time to find out this problem.. The string comes away with use and of course time, that is is why the mouth no longer moves. If you wish to try and repair, you first have to remove the head from the base. If you look there are 4 heavy duty staples just round the collar neck area. They will come out with a small head screwdriver or something pointed. Just work it slowly under till staple raises up, then just pull it out. Once they are all removed the head should be loose. This is only to give you access to seeing the internals firstly. Now comes the hardest part. The soft moving part of the mouth needs to be removed. You need to work it of slowly as there is a glue base on it, so care is needed here and can take time. If you managed this all is left is the metal pin it was on. Now inside is the plastic unit that moves the mouth this is glued in which is the main problem. And this is the issue, it is pushed on and the only way is to remove is to have a precision head screwdriver and work it off... Best done by someone who is quite good with their hands and very patienced. Because it may break. Took me severals hours to remove. When you get it off the internal workings will come out of the head. There is no other way of doing this. Having the head loose allows you to look at the piece and the workings. A small torchlight held by someone is best as you work out the mouth fitting.....As i said it is no easy job and took me long periods of time to get to this point. I wish you all the luck in achieving this.......
Dec 15, 2008 | Gemmy Rocky Balboa Big Head Animated...
Open Questions:
Garden Logo
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
