Question about Palm Treo 650 Handheld
Treo 650 keeps shutting itself down
when i am on a call, my treo 650 sometimes shuts itself down without warning. It will end the call and shut itself off.
This has happended to me a few times now.
Please advise of reason for the problem and solution.
Thanks and Regards,
    Problem Solver:
  • 10 Answers
Hi muchlove,
Please backup your palm to memory card using palm backup application or hotsync it to your computer, then you do a zero-reset. Here's the step by step how to zero-reset:
http://tinyurl.com/babb7
If this solve the problem than it caused by software conflict. Please let me know the result.
Posted on Nov 10, 2007
Windows keeps shutting down unexpectedly
Your computer is overheating, it is shutting itself down to prevent damage to the internal components.
Your computer should be serviced by a computer technician. He/she will clean the components and chassis of dust. This will increase airflow over the components, meaning your system will be stable and will not shut down unexpectedly.
Take care!
damnor01
Apr 28, 2012 | Microsoft Computers & Internet
My computer is on but no picture. It says windows was not shut down properly
Hello Pattiaknight,Make a desktop shortcut to shutdown and include a switch that forces all open apps to shut down without warning.
Just right click the desktop, New, Shortcut, type:
Shutdown -f
Shutdown -f closes any open programs without warning.
Now instead of shutting down the usual way, just use that shortcut to shutdown. If the error stops it means some program wasnt shutting down properly on occasion.
Please let me know if you any further questions or concerns.Also please rate it if you like the answer,it helps alot.
Thanks.
Apr 19, 2012 | Sony Computers & Internet
When i turn off the car the fan continues to run?
Many cars have this feature. The fan will run for a few minutes at a time until the coolant in the radiator drops below a certain temperature. Most vehicles with this feature will have a warning label on the radiator shroud indicating that the fan may start without warning when the engine or radiator is still hot. The only time you would need to be concerned would be if the fan continues to run without turning itself off, and causing the battery to be drained.
Feb 19, 2011 | 2003 Jaguar X-Type
Why does my computer keep shutting down?
Is Windows crashing or is it just shutting down without warning? If it is without warning, then I would suspect a failing power supply. May want to look at getting a replacement power supply.
Sep 02, 2010 | Acer Computers & Internet
My laptop shut down after powering out with no warning and will not restart.... Toshiba L550 screen stays black but when I hit the enter key it beeps........any suggestions
“My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.” This complaint we hear from our customers over and over again. About 15-20% of all Toshiba laptops we get for repair, suffer from an overheating problem. Yep, OVERHEATING!
This is one of the most common problems with Toshiba laptops we deal with.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
May 04, 2010 | Toshiba Computers & Internet
My laptop gets heat and shutdown
Solution:
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes you have to open the laptop case all the way down.
Feb 27, 2010 | Compaq Evo N610C Notebook
Computer keeps shutting off without warning
If the PC doesnt show the shutting down dialogue, then hardware proble if it does then its a software problem. Try to replace the powersupply, abnormal voltage sometimes causes this problem, memory and motherboard errors can cause your PC hangs up or blue screen but will not shut off.
Oct 21, 2009 | Computers & Internet
Palm Treo 650 is not turning ON
Try a new battery - if you have had it for a while and not kept it charged up then it could be that it has lost its capacity to hold charge.
Good luck
Megan
Jan 29, 2008 | Palm Treo 650 Handheld
Palm Treo 650
the phone has a flie on it that the phone dont agree with. you can get a virus on your smart phone.
Jan 03, 2008 | Palm Treo 650 Handheld
Palm Treo 650 Handheld Logo
93 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
