Question about Kenmore Refrigerators
Water puddle from refrigerator towards back
It is a kenmore refrigerator that is almost 2 years old model number 253.7481340G
  • 25 Answers
If you have a water line running in for an ice maker check to ensure all fitings are tight. Secondly check to see if cooling coils are completely clear and free of debri (this will allow the unit to properly breath and hopefully eliminate your problem)
Posted on Jun 19, 2009
Water build up
Good Afternoon Friend,
I understand that you are getting puddles of water in the back of one of the bottom shelf and in one of the vegetable drawers in your Frigidaire refrigerator. I suggest putting the crisper drawer control on the Hi humidity setting. This should allow more moisture to escape out of the drawer and not cause as much puddling. Also, check your water filter and make sure it is not leaking, as well as any moisture from the ice maker. If further troubleshooting is needed, I ask that you please leave the model number of your washer. Typically, you can find this number inside your refrigerator on the liner walls. Hope this is helpful.
-Best Regards-
WP
May 29, 2014 | Frigidaire Refrigerators
I have a Kenmore refrigerator side-by-side with water/ice in door. Model number 363.9534783 serial number L431 12755. It is now intermitantly leaking water on the floor. A couple of days could go by with...
1. A door open partially will cause a frost build-up then thaw and run down to the floor. Check all doors for proper closure and educate other users.
2. An issue with an unhappy animal is quite common
3. Door switch intermittently causing a light to stay on ora fan to not run
4 Ice build up around ice door chute .
5. Water dripping into ice tray and overflowing. Replace water valve.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 18, 2017 | Kenmore 57029 Side by Side Refrigerator
Puddles of water in the fridge
OK that sounds like Ice may be blocking the defrost condensate drain. I will need your model number to help me to identify your model better but can leave you with some information about water leaking inside the freezer or fresh food compartment. Sears use a model number found around your door frame and looks like this for example 312.56989 Be right back with some links, Thanks Sea Breeze
Feb 19, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
We have a 2-year old Kenmore side-by-side with a "Por" Ultimate filtration system. We cannot figure out how to empty the plastic pan underneath the refrigerator that has the water drip in it. Also, we...
you shouldn't have to touch that pan the water should evaporate by itself,are you sure you don't have a blocked drain in the freezer?is there ice on the freezer floor?if so melt out the ice in the back at the bottom of the freezer wall and then pour hot water down the drain to see if it's clear if not you have to find something you can stick into the hole to clean it out,i use a steamer to unblock the drain you can get one for 40 bucks it's a shark super steamer,if that's not the problem you could have a cracked water line,you'll have to take off the back panel on the bottom,and check the lines,have someone draw a glass of water while you check out the water line or it could be from the ice maker line if you have an ice maker
Nov 24, 2009 | Kenmore 53542 / 53544 Side by Side...
Slow dripping water from top freezer into the main fridge
We just got rid of our 26 year old Kenmore for this reason. In 26 years I used a hair dryer to thaw out a tube toward the back of the refrigerator. At least in ours when the tube gets frozen shut the water had nowhere to go but in our egg tray.
Oct 23, 2008 | Whirlpool Refrigerators
Water leak From Back Of Fridge
hi that small hose is going in to the ice maker. buy a small clamp at the hardware store, and clamp the plastic hose holder. thanks the appliance doc
Oct 16, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Kenmore frigde not dispensing water
Replace the water valve.On the back at the bottom you replace the part the water line is attached to.In the pix i'll show you what a typical valve looks like.754d79f.jpg
May 29, 2008 | Kenmore 53092 / 53094 Side by Side...
Water dispenser not working
check the water valve on the ref it is in the back on the right side behind the cardboard cover
Apr 09, 2008 | Refrigerators
Kenmore 90 washer won't drain
Check first drain line or water pump to see if they are clogged.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump.
Jan 14, 2008 | Washing Machines
KENMORE REFRIGERATOR
Need a model # ... mostly likey better to just replace ice maker if that old.. 12-15 if same age as ref.
Sep 06, 2007 | Kenmore 73952 / 73954 / 73959 Top Freezer...
Refrigerators Logo
102 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
