Question about Knoll Lamp for HD225 Projector
Projector will not power on
Projector wil not power on by manual button or by remote. No power issues in fuse panel...
I have a Epson lcd projector mp-x3 the lamp light is blinking so I replaced the lamp and the lamp light is still blinking and there is no light do I need to reset the lamp if so How do I do thatMukrray
Connect the power cable, power on the projector and then press the [Menu] button on the remote control. The configuration menu will be displayed.
Select Reset Lamp Timer from the About menu, and then either press the [Enter] button on the remote control or the [Auto/Enter] button on the projector's control panel.
Select Yes, and then press either the [Enter] button on the remote control or the [Auto/Enter] button on the projector's control panel.
The lamp operating time will then be reset.
Aug 11, 2011 | Epson EMP-X3 LCD Projector
How to reset sony projector vpl-es2 without remote control cause the panel key is lock?
Turn the projector on and leave in standby mode. To do this press the power on button for 10 seconds until the projector comes on.
To unlock the main panel keys, press the MENU button for 10 seconds.
Aug 05, 2011 | Sony VPL-CS7 Multimedia Projector
I changed the bulb and the power lights wont come on
Certain Mitsubishi projectors have a built in bulb life timer, and are programmed to not allow a projector to power on unless the bulb is replaced and the bulb life timer is reset. Its a simple process:
1) Make sure your projector is plugged in.
2) Make sure the main power switch is on.
3) Hold the left arrow, right arrow, and power button on the control panel of the projector (not remote) for 3-5 seconds.
4) Release...
This will reset the bulb life timer to 0000 and allow for normal power up barring any other unforeseen issues.
Mar 07, 2011 | Mitsubishi HC3000U Multimedia Projector
Infocus 250 will not turn on at all.
The power button is solid green? try to turn on whit the remote control. Try to clean the surface on the Main board, uder the contro panel.
May 31, 2010 | InFocus LP 240 Multimedia Projector
Projector appears to be in lock-out (exceeding 2000hrs on bulb)
1) Press the RESET button on projector for 3 seconds or remote control TIMER button for 3 seconds and display the total lamp used time. 2) Press the RESET button on projector or remote control MENU ON button during displaying the lamp used time. 3) Select the ?0? on the screen using the MENU ( ) button or DISK PAD.
Aug 12, 2009 | Hitachi CP840/940LAMP Projector Lamp for...
Reset Lamp Hours Timer
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
Oct 13, 2007 | Toshiba TLP S30 Multimedia Projector
Won't power off when pressing power button, just goes to standby mode
With most projectors you have to press the power button twice to confirm that you want to turn it off. When you press it the first time it waits for a bit and then turns itself back on assuming you hit the power button on accident.
Jul 23, 2007 | Compaq iPAQ MP2810 Multimedia Projector
Whatever button i press the status light flashes and nothing happens?
hi 1) Check that the power cable is plugged in and that the power button on the projector cabinet or the remote control is on. See pages E-16 and 17 in the manual http://www.fixya.com/user-guide/p155892,m5221,gm34/NEC-VT460-Multimedia-Projector.aspx 2) Ensure that the lamp cover or lamp housing is installed correctly. See page E-30. 3) Check to see if the projector has overheated or the lamp has reached the end of its usable life. If there is insufficient ventilation around the projector or if the room where you?re presenting is particularly warm, move the projector to a cooler location 4) You have pressed control panel key when Control Key Lock is enabled good luck
Apr 20, 2006 | NEC VT460 Multimedia Projector
Knoll Lamp for HD225 Projector Logo
Top Knoll Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Knoll Office Equipment and Supply Expert? Answer questions, earn points and help others
