Question about Minolta Office Equipment & Supplies
The section indicated by is open - Minolta Office Equipment & Supplies
  • Minolta Master
  • 6,168 Answers
DO you have extra paper draws? In the back of the machine is a plug for the extra paper draws is it installed? Also check all the doors that can open do you have a finisher/ ensure plug in
What Model sir.
Posted on Dec 30, 2014
The section indicated is open
Apr 17, 2014 | Minolta EP4000/5000 CS/PRO Copier
Everything is freezing in the vegetable drawer
For this problem, its indicating towards problem with damper assembly.----------
The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is remained open, its not closing.Due to this the cool air from freezer section is running in to fridge section non-stop.Due to this the vegetables and other food in the bottom drawer freezing.--------- In this problem the damper assembly needs to be replaced.---------------
This should help.Thanks.Helpmech.
Oct 31, 2011 | Kenmore Refrigerators
I just got home earlier and when i want to watch TV i opened the TV and after 4~5mins it starts to blink and then it turns off and even if i unplug and keep on powering the TV it wont open anymore...its a...
In most cases the standby light might blink with different rapidity to indicate a fault relevant to the processor. It is possible that most of these indicate that there are errors in the processing section . Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multimeter to check the continuity or shorting in components, if so detach from circuit and test . If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail.
The processor must have the +5 voltage to the function properly , the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail.
If tapping the top of the set brings back the picture then it can be that the main board has dry soldering.
Jul 12, 2011 | Televison & Video
The meat and veg drawers freeze the meat and veggies no matter what setting the temp. is on.
Freezing meat,vegetables. Problem with damper.
You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Jul 08, 2011 | Kenmore 56829 Side by Side Refrigerator
Error c630 cual es elfusor
you have to clear Resetting the fusing problem dataDescription
Resets the detection of a service call code indicating a problem in the fusing section.
When a service call concerning the fusing section occurs, turn the power switch off and open the front cover.
Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
Purpose
To prevent accidents due to an abnormally high fusing temperature.
Method
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020,
C6050, and C6400 are reset.)
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
Jan 19, 2011 | Kyocera Mita KMR-1810P Laser Printer
The freezer section of my whirlpool double door refrigerator becomes too cool while refrigerator section does not cool lower than 56 deg F. Setting of Freezer section is at minimum cool (extreme left)...
when you open the freezer door you should hear a fan running, that's what cools your refrigerator section. If you don't hear that fan, that may be the problem. Also if there is frost on the back panel of the freezer that also may indicate a defrost problem, which could cause the same problems
Aug 22, 2010 | Refrigerators
Blinking red and green
How to connect the Bluetooth device to the computer loadTOCNode(3, 'moreinformation');
  1. Press and hold the Connect button on the bottom of the mouse. If your device has a battery indication light, it will blink and alternate between red and green to indicate that the device is discoverable.
  2. On the computer, open the Bluetooth software. The Bluetooth software is typically located in Control Panel. For more information about opening the Bluetooth software, see the "How to open the Bluetooth software" section.
  3. Click the Devices tab, and then click Add.
  4. Follow the instructions that appear on the screen.
Oct 28, 2009 | Microsoft Bluetooth 5000 Mouse
My DCR-HC30 Mini DV Camcorder keeps giving me the "cover not open" indication when the cover is actually open. What can I do to resolve problem?
There is small switch located at front circuit board that is not working properly and causing "cover not open" message.
Take off LCD cabinet section then remove front cabinet section, remove screws on circuit board and turn it to see that switch.
There can be lose connection on switch terminals or switch is not being pressed properly with lens cover lever. Please check it carefully.
Thanks.
Oct 22, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
Electrical problems with 1996 lexus ls 400
Check all your fuses. Sounds like one is blown.
Dec 28, 2008 | 1996 Lexus LS 400
15 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
