Question about Hunt 73126: Rapid 20EX Personal Electric Stapler
My Rapid 20EX electric stapler has jammed - how do I unjam it?
How do I prevent Rapid 5080e stapler from jamming
Make sure that the tray for the staples is clean and LIGHTLY oiled, Staples are held together with glue. IT could also be an issue with the wear on the staple head driver. If you use it a lot, the unit might be worn to the point that it is out of spec.
Aug 28, 2015 | Rapid 5080E HEAVY-DUTY FLAT CLINCH...
How do you fix a P22 Stapler
You may have to use pliers to remove the bit of broken staple jamming it.
Jun 09, 2014 | Heavy Duty 133751 Arrow, P22, Plier Type...
Spring to stapler fell out
Hello, Go to this website for support phone numbers and too download manuals for this product. Bostitch Office Products Staplers Pencil Sharpeners Hole Punchers Tools...
Mar 03, 2014 | Stanley Black & Decker Bostitch 20SUITE...
Stapler malfunction
I don't know, but check how frequently the stapler jams.
Dec 10, 2013 | Panasonic AS-302NN Electric Stapler Heavy...
How to unjam
UNDO THE POWER SORCE AND OPEN THE STAPLE FEED PRY OUT THE JAMMED STAPLES "SMALL SCREWDRIVER SHOULD DO THE TRICK"
Dec 18, 2012 | Swingline 48209 Optima ® 45 Electric...
Panasonic DP 3520 J62 only when using stapler
The stapler mechanism may be jammed. try to make sure it works freely. It has to "crimp" the staples similar to a car crushing machine. They usually give the customers a little tool to unjam the staple unit. Good luck.
Jun 26, 2012 | Panasonic Workio DP-3520 Copier
Jammed the machine too many papers. how can i get it unjammed
Unplug the unit ! Remove the cover if possible then carefully use pliers or vise grips to turn the gears that drive the punch cam backwards to get the paper out.
Dec 17, 2010 | Gbc ® 24-Sheet 3230ST Electric Two- and...
Ihave a office max electric stapler and it got jammed and I removed staples, but now all it does is buz when I try to staple
You have to unscrew the screws at the bottom of stapler and then manu ally move gears to unjam stapler.
Oct 14, 2009 | Staples Tools & Hardware - Others
Instructions on unjamming swingline electric stapler model 270; jam is at the front of the stapler; staplers come out either broken, flaten or crooked and does not secure document.
First, are you using the recommended staples for this stapler? Many heavy duty electric staplers don't use "standard" desk staples. Second, try unplugging the stapler, unloading the staples, and if possible, reach a couple of fingers into the stapler and try manually pushing up on the staple head to see if you can get the driver blade to come down. Does it come down smoothly, or does it seem like there is something stuck in there? If you aren't sure about disassembling the unit (my usual method-but I'd recommend having the parts diagram handy), try using a flashlight to look at the underside of the staple head, where the staples come out - can you see anything stuck in there? If so, you might be able to use a small knife blade or small dental pick to get jammed staple pieces out.
Mar 03, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Hunt 73126: Rapid 20EX Personal Electric Stapler Logo
152 people viewed this question
Top Hunt Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Hunt Office Equipment and Supply Expert? Answer questions, earn points and help others
