Question about Garden
Gyrocompass I have an SG Brown Meridian Standard Gyrocompass with Baud rate of 4800.This gyrocompass is not given me a stable heading when the jack up barge has preload and is in a fix position. Pleases what is the possible cause of this gyro malfunctions and what is the way of clearing this fault to be able to achieve a stable gyro heading while the barge is not moving
  • 24 Answers
SOURCE: change baud rate
Baud Rate is to lower the transmission speed of the fax, however these are the temp settings and once the power is off you have to reconfigure that. Follow the following steps :
From the front panel:
  1. Press and hold the * key for 3 to 5 seconds until the display screen reads Test -001+ .
  2. Enter in 620 on the key board, and press the Check Mark and the screen will read Cfg param id:
    1. Enter the parameter ____ on the key board and press the Check Mark.
    1. 159 - Receiving Fax baud rate
    • 153 - Transmitting Fax baud rate
    1. The screen will read Cfg param val: 26
    1. Enter in the value ____ and then press the Check Mark .
    1. 0 = V.17 14400
    • 2 = V.17 9600
    • 6 = V.29 9600
    • 10 = V.27 2400
    1. Screen will read Test -001+
    2. Press the Reset button until you get back to Ready
    Posted on Jan 22, 2008
    Ajkill
    • 2035 Answers
    SOURCE: baud rate
    # Lower the fax transmission speed to 14400 or even 9600 bps, as some older fax machines are not capable of receiving a fax at a high speed. To do so:
    1. Press the Fax button, then press Options untill it gets to ADVANCED FAX.
    2. Press Select.
    3. Press Options untill it getsl MAX SEND SPEED appears on the LCD display.
    4. Change it to 9600 BPS using the - (left arrow) button.
    5. Press Select.
    # Turn off ECM (Error Correction Mode) by pressing the following keys on the operator panel:
    1. Press the Fax button, then press Option untill it gets to ADVANCED FAX.
    2. Press Select.
    3. Press Options until ERROR CORRECTION appears on the LCD display.
    4. Change the setting from On to Off using the + (right arrow) button.
    5. Press Select.
    Note: Turning off this option makes it possible to receive a fax when the receiver fax machine does not support certain error correction modes.
    Posted on Mar 16, 2008
    • 30 Answers
    SOURCE: 4800 baud rate communication in vb
    You have to change it on both side!
    If you are communicating your PC with a serial device, BOTH must have the same speed (serial device: 4800, pc: 4800)
    Have you done it?
    Most devices DEFAULT settings are 9600 baud rate, N, stopbit1.
    But you can change it depending on the device...
    Posted on Jan 04, 2009
    laxmankumar
    • 191 Answers
    SOURCE: baud rate
    Please follow the steps given below to reduce the baud rate on your printer.
    1. Turn on the HP all-in-one.
    2. From the keypad, press * and # keys simultaneously.
    3. Press 1, press 2, and then press 3. Service followed by a number will be displayed on the front panel.
    4. Press the right-arrow to select System Configuration.
    5. Press Enter on the front panel.
    6. Press the right-arrow to select R/W Parameter.
    7. Press Enter. Parameter 0 will be displayed on the front panel.
    8. Press 1, press 5,press 1 (i.e,151) and then press Enter. The display should read Value followed by a number (example, Value 60).
    9. Press 2, press 6, and then press Enter. This will display Parameter 0 on the display.
    10. Press 1, press 5,press 3 (i.e,153) and then press Enter. The display should read Value followed by a number (example, Value 60).
    11. Press 0, and then press Enter. This will display
    12. Press Cancel repeatedly, until the display reads the date and time.
    Posted on May 23, 2009
    FixinFax
    • 3085 Answers
    SOURCE: adjust baud rate on Sharp UX- 700 fax machine
    It won't make any difference if you could. All fax machines are analog devices and won't work reliably on a digital phone line.
    Posted on Nov 13, 2009
    How can i test marine gyrocompass out put synchro and stepper
    SYNCHRO MOTOR HAS THREE WINDINGS LIKE A STAR SOMETHING LIKE A THREE PHASE SAY S1,S2,S3 AND ANOTHER TWO WINDINGS CALLED R1ANDR2 , WHEN YOU SUPPLY EG 110VAC ACROSS R1 AND R2 IT GIVES A SECONDARY VOLTAGE ON THE S1,S2,S3 , SO YOU CAN CHECK IN THE MULTIMETER AC RANGE ACROSS S1-S2,S2-S3 AND S3-S1 , YOU SHOULD GET SAME VOLTAGE ACROSS ALL THESE POINTS .....hope that clears the question
    Nov 22, 2014 | Boating
    What is nmea
    As Anreas said, The new standard for NAMEA is 2000 used to communicate between multiple devicsess wth multiple talkers. 0183 can only have one talker
    Jul 17, 2014 | Lowrance Elite 7x Hdi Fishfinder 50/200...
    PP8000B printer just prints garbage..and Cash drawer doesn't open have tried the O POS manager , tried almost everything .. Any suggestions welcome...HELP
    Every POS software has commands that opens the cash drawer and prints the ticket. It also controls how long the receipt ticket is, if it prints in color. Then there are two types of cables that communicate between the cash drawer and the printer to pop the drawer. Then there are dip switches in the printer that change how the printer operates according to the software. When it prints garbage, the driver that comes from the POS software is not synced with the printer. Sorry you asked. Call the POS Software company.
    Apr 10, 2011 | Posiflex PP7000 Printer
    Sir i need a service manual for gyro std 14 of raytheon where i can find the same
    I traced the std 14 gyrocompass to a website called ventville b.v. Their support email address is: info@venteville.com
    Try contacting them for information about a service manual. The only ones I can find for downloads are the 20 and 22.
    Good luck,
    I hope this helps. If it does, I would appreciate a vote or comment.
    Thanks,
    Handie Andie
    Mar 30, 2011 | Garden
    Have you done it?
    Jan 03, 2009 | Computers & Internet
    My HTC TyTN II GPS does not appear to work. I have bought the device, and when I first installed TomTom the device was able to get a GPS fix, Howeve after I ran external GPS, the device no longer seems...
    I Got it!
    I finally got my HTC TyTN II yesterday from Dubai.
    First thing I wanted to test was the GPS. It did not work with: TomTom6, Google Maps, Yahoo Go.)
    I was surfing around to find something that would help me out and have noticed that many people have the same problem.
    Many people (Like me) did not know howe to setup the GPS.
    Many people are saying: "You have to put it your GPS settings in Com 4 and the Baud rate on 4800 and it should work.
    Well mine didn't work with those settings. (Along with other people.)
    I had played with the External GPS option (Don't do this cause setting something wrongm ay cost you a HARD-Reset.)
    I Was lucky that mine worked again after a SOFT-Reset. So watch out!
    The standard GPS settings! (If you have changed it, Soft-reset your phone and set it up as these pictures show.)
    Why am I doing this?
    People buy this phone to make use of it. When something does not work why buy the phone then :S
    Hope that this may help a lot of people on here and other forums, communitys & websites.
    Here is my story of how I did get my GPS to work:
    1. Download the GPS addresses by using QuickGPS (Start -> Programs -> QuickGPS).
    (This will download info of what your GPS Reciver needs to connect to the satalites.)
    2. Download a free (Well half free, You can also buy this application it will give you some extra options, but we don't need those extra options.) tool named: GPS Test. (http://www.smartphone.net/software_detail.asp?id=3170 or at http://www.pocketpc-software-downloads.com/software/t-free-pocketpc-gps-test-download-uykfcoyy.html)
    (This program will scan all your mobiles com ports and Baud rates, To see what your real GPS settings are.
    In my case they were: COM PORT: 4 - Baud Rate: 9600 (Notice it ain't 4800. Usaly it shows your settings with a pop-up.
    When It doesn't Go to "Menu -> GPS Settings", There it will show you you're GPS settings.)
    3. Install TomTom 64. Download your free map.
    5. Go to the GPS settings.
    (Set-up: Other NMEA GPS-Reciver -> GPS-Baud Rate -> Com. (Select the Baud rate + Com port from what the GPS Test did show you.)
    6. Now wait.
    Jun 29, 2008 | GPS
    Faxing
    check weather the phone cord is connected in teh line jack on teh fax not in the extension>and set resolution-standard>and auto answer mode-o>and error correction mode-off>or u have over seas mode-it should be on>u have either any one of this>and baud rate-9600> check with band width on the pc>and reboot it>and check rate me solved if its help full
    Oct 31, 2007 | Panasonic KX-FP155 Plain Paper Thermal...
    GPS Com Port Settings
    Maybe you can try on com port 7 with baud rate 57600.
    Sep 07, 2005 | HP iPAQ hw6515 Pocket PC
    Garden Logo
    18 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
