Question about Ovens
Oven temperature conrol not wrking
We had a 1980's wall type oven that would not control the heat any longer. It had an electronic digital control board , the clock worked fine. To replace the oven new was like $700. We had a Sears repair guy come and he said to use the internet to find a replacement control board. After extensive research using the numbers on the board itself I found a company in Canada that does repairs, (there were a couple of companies offering this service, I can't remember why I picked the Canadian company) they explained that using a new replacement may just give you another board with the same weakness built in. This made sense to me so I took a chance and mailed them the board (shipping to Canada was a bit high) got it back in a couple of weeks, took 5 minutes to re-install and its working great. The repair was just under $140 plus shipping.
Posted on Apr 17, 2014
Need a contol board for frigidaire cfeb786jgb3 oven
Contact your mfr and they can send them to you or even let you know of a dealer in the area that as the parts.
Feb 25, 2013 | Ovens
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
Can not set touch conrol panel
we need the brand name and model
Jun 11, 2011 | Ovens
Hello. I have an HEV 434350 (in Barcelona). It's suddenly stopped heating. The fan works, the display works. The child safety device seems not to work (I press it for far longer than 4 seconds, and nothing...
Sounds like a faulty oven element, if the fan is wrking o/k, then I suggest you fit a new oven element, usually located at the rear of the oven compartment behind a removeable cover.
Nov 05, 2010 | Bosch Ovens
We have error code EE214 &M214,we changed conrol board,still same proble,please help us
I also have this same problem. Just got the new (expensive!) control panel in and it didn't help a thing.
Oct 08, 2010 | Jenn-Air Ovens
The oven has a digital mode for the temperature and timer. However, it shuts down by itself on temps higher than 350º in 30-50 minutes. If it is on a higher temp, like 400-450º, it will shut...
The ribbin connection terminal betweenth control board and the display is losing electrical connection with heat. Try pushing the ribboin connectors deeper into the recepticles on both the display and the conrol board.
It may just be that the ribbon electrical strip itself is failing at temp and separating. You should be able to go to a serious elctronics supply store / maybe even radio shack and get a ribbon strip that you can cut to length and install. Ask for assistance as you also may need to make adapters on both ends of the ribbon to go from ribbon recepticles to PCB recepticles. MUCH cheaper than P2500 / $200 US for sure.
Thanks for using FixYa.
Kelly
Mar 20, 2010 | Ovens
Good evening i have a BT2431SS baumatic cooker,i have no heat in main oven yet i have the hob and the grill that work ok.
If it is a fan assisted electric oven, and the fan is wrking o/k, then it will probably be a faulty oven element.
This is located at the rear of the oven compartment behind a removeable cover.
Please rate my solution.
Thanks.
Nov 24, 2009 | Baumatic Ovens
NUMBERS WIPED OFF ON CONROL PANEL
I TRY TO DO EFFORT IN PROBLEM NEAR TO THAT SITUATION IN ANOTHER BRAND
ALL I CAN TO SAY :
CHANG THE CONTROL PANEL BY SAME PART NUMBER
THANKS
Jun 18, 2009 | Ovens
Beko Cooker dvc565
once you take of the back of the oven there are some wires going from the cooker to the back cover on one of the wires you will see a microtemp thermal fuse protector this connects the two wires (the white wire) this needs replacing you can get them from tdspares.co.uk we will be getting 121c degree. Hopes this helps
Feb 10, 2008 | Ovens
F3 code and beeping
F3 - F4 Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Nov 17, 2007 | GE Profile Advantium SCB2001KSS Stainless...
Ovens Logo
44 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
